Daz Studio and Linux
16364656668
  • 3DIO3DIO Posts: 499
    edited May 17
    Exactly, that's what I mean.  In my reply to TimberWolf some posts back, I was pointing out the runtimes, and that it's using "Steam Linux Runtime 4.0".
    This time I've attached the screenshot of both the page itself, and the actual compatibility setting I'm using.  I'm not so sure now after your post, but as far as I was concerned, it already was running natively on Linux  :-D
    Since CachyOS is Linux and I'm running a native Linux version of Steam on Linux, and the licence Steam is showing me is (as far as I'm aware) my perpetual "SteamOS" licence for Substance Painter.  I just assumed it must be running natively on Linux.  Also bear in mind that I'm not having crashes.  Perhaps this is why.  Perhaps you're running in a different mode to me.  But yup, as can be seen in the screenshots, it does state (even in brackets) that it's running on "Steam Linux Runtime Version 4.0" .
    1920 x 1080 - 419K
    842 x 601 - 36K
    Post edited by 3DIO on
  • bluejauntebluejaunte Posts: 2,222
    edited May 17
    Steam Linux Runtime 4.0 is not native. That's the whole Proton/Wine layer. You need to select "Legacy Runtime 1.0" to get the native Linux version.
    I think we can safely assume you were NOT running a native Linux version. Why do you think a Windows regedit change got rid of an error message in Substance Painter? wink
    Post edited by bluejaunte on
    edited May 17
    True, but how confusing then to label a Windows Runtime as a "Linux Runtime".
    Legacy Runtime 1.0 won't even run the software, it just cancels itself out.
    As I said that time when I gave DSP as an example, I think logically, which is why I don't get along with Linux in a technical sense.  Linux to me is just pure nightmare fuel in a technical sense.  I honestly cannot think of anything more confusing to learn than Linux, but at the same time, I'm damn glad it exists!
    Anyway, I just did the RegEdit thing for the Paging File and unfortunately it hasn't worked.  I set the minimum to 20000 MB and the max to 120000  MB assuming those settings will give access to between 2 GB and 12 GB (approx).  The message in Substance Painter however is exactly the same, telling me the minimum allowable value is around 18000 MB.
    I'm surprised though, cause I thought it would work after the success of the other RegEdit operation.
    Might need a restart, not sure editing a page file in the registry would instantly work in Windows either. Try restarting Linux or maybe this works
    wineboot --restart
    I' already do a hard restart by default when messing with this stuff.
    I think I'm going to play around with Substance Painter a few days.
    At least it does work, and that's the main thing.
  • DareshiranuDareshiranu Posts: 330
    I have to say that I've been quite eager to try out Linux once more after a years long hiatus, wanting to use Daz within. But I recently tried converting an arcade PC over to Batocera from Windows and oddly experienced some regret. After some exploration, I discovered that there are things like Windows Atlas OS and its ilk, but then I found that there is something ever more remarkable - a version of Windows 11 that is largely but not completely without the bloat and telemetry that's included with the Home/Pro versions that you can have without using something to strip out everything that's unnecessary. It's Windows 11 Education, and I put it on my arcade machine. Incredibly, it does come with copilot but by default it's turned off. There isn't much bloat at all and I'm given to understand that there is still a bit that can be stripped out should I wish, and group policies are relatively easily managed to control things. So for now I think I'm still going to shelve my sojurn into Linux, even though I was going to test it out first on my arcade machine with Batocera, then my Virtual Pinball with Ubuntu and go from there on my other rigs. Now I'm just going to go with this new thing I've discovered and can be more comfortable and compatible with. I still hope to one day see more support for Linux from Daz... or any really. But this is a quite good thread, I just wanted to mention what I'd discovered so recently, not disuade anyone from going the Linux route.
    @Dareshiranu
    You gave me an idea.  I'm back on my Windows 10 install for the first time in what feels like two months now.  Since I witnesed first-hand what Windows 10 was doing without my permission, I've found some information that will hopefully prevent it happening again.  I implemented the measures just now, and will find out soon whether they work or not.
    So I'm back on Windows 10, and I've read many times that Windows 10 can be made good, but I do believe you are completely wasting your time with Windows 11 since I read it is literally designed to be a datamining OS for Microsoft's AI, and has been butchered in such a way to make it impossible to remove such "features".
    3DIO said:
    @Dareshiranu
    Nah, there are some excellent resources for stripping out 11 if you know where to look. But I'm lazy, which is why I was so taken with the idea of the Education version, which has so much stripped away already but can have more removed easily enough. It's so far looking to be quite lighter and far less intrusive than my main rig's 11 Pro that I plan on converting soon enough.
    That's quite different to what I read about Windows 11, so rather you than me!
  • Robert FreiseRobert Freise Posts: 4,690
    edited May 19
    Beware W11 has a tendency to put everything back as it updates ignoring your settings regarding when and what updates take place
    The only way to stop it is no Wifi or ethnet capability not just turned off in the bios as W11 has been changeing settings in the bios
    Post edited by Robert Freise on
  • TimberWolfTimberWolf Posts: 377
    Bit of a reality check. CachyOS and Arch in general just pushed out a fairly major update to WINE and the Nvidia drivers over the last 48 hours which completely nuked my Daz Studio setup. You can rollback your installation but eventually you're going to have to bite the bullet and update everything so I just reinstalled everything Daz-related. If you've backed up your layouts, plugins and anything else pertinent to how you use Studio then it's no big deal. 15 minutes later it was all back up and running but if you're brand new to Linux, this may not be the distro you're looking for. I mention this because Cachy has dominated the discussion over the last few pages and I do not think it is the best starting point for new Linux users; on a day-to-day basis it's as usable as Windows and you'll get away with not really understanding how it's screwed together. Until you don't get away with it and are facing a complete OS reinstall because you lack the experience and knowledge to fix it. Arch Linux distros update daily which means you always get the latest and greatest but you also have to accept that this will break things occasionally. And because these installations are unique I can almost guarantee this didn't happen to someone else with almost the same setup. Shrug.
    If you want stability and peace of mind, look to Debian and Fedora-based distros like Ubuntu (and derivatives), Pop, Nobara and Linux Mint which are updated as complete releases. All of these and many more will happily run Daz Studio, both 4.x and 6.x although, as I've mentioned before, you will lose the Nvidia Optix denoiser if you use Debian distros. I haven't been able to find a fix for that but one may exist.
    Dual boot if you need the Adobe Suite or cannot use a substitute for MS Office. Everything else pretty much just works.
    What got nuked exactly? I'm on latest updates and not noticing any issues in Daz Studio.
    What stopped functioning was the WINE prefixes managed by Lutris. Studio, K-Cycles, and three other misc. Windows applications. It was related to  (sandboxed) environment wine variables all of which ceased to exist after the update and I couldn't trace the problem - it's firewalled and they all croaked. The point really was not that x or y stopped working because these issues will vary depending on our own individual setups, but that Arch Linux might not be the best choice for people dipping their toes into Linux. At some point in the future I can guarantee you'll have a problem with an update and I won't.
    Right, agree to a point. Though my solution to that, which I think I pointed out some pages ago, is to have a daily backup solution you can fall back to if things explode. In your case I don't really know if down the line these issues would've gotten fixed by more updates but generally this seems to be the case. If something doesn't work, restore a backup, wait a few days/weeks and update again. Would this issue not have happened on Fedora you think?
    Also there's no need to update every day either. I guess that's also important to point out? Just because it's Arch based you don't have to update.
    edited May 21
    @TimberWolf
    Thanks for the heads up on this, and to be honest I have serious suspicions about CachyOS anyway.
    As my posts demonstrate, my preference was always for Debian with a GNOME interface.  After using CachyOS, Debian/GNOME is still my preference and is what I'll be going back to once I sort my hardware out.  I won't go into why I have suspicions about CachyOS, but there are many (none of which exist for Debian/GNOME).
    Anyway, I was offered the keys to my new flat this morning, so I'll be paying an admiring visit tomorrow and moving in on Monday.  So I finally have a proper council flat in a nice (mainly elderly-inhabited) area, well away from this over-priced, private hell-hole!
    When I get back to the forum, I'll be trying what is shown in the video shown here, since he has DirectML working on the AMD RX580 (the video comments look promising as well).  With a bit of luck, that'll keep me happy while I save the cash for the Nvidia card I pointed out on the previous page:
    edited May 21
    Oops, sorry, I pulled the Windows 10 version from my bookmarks there (a temporary option I could go for), but here's the Linux version (Including ROCm on old AMD cards), and don't forget, ROCm drivers mean dForce for Daz Studio on Linux!
    @bluejaunte
    I tend to update at start-up and shutdown. The fewer the packages that are installed if an issue arises, the smaller the search area. I don't think there's any right or wrong way to do this, just whatever suits your workflow. I do agree the issue may have been fixed if I'd left it for a few days or so but there's no guarantee. With proper backups and a good working knowledge of your OS, it's not really an issue. I don't do image backups because you end up reliant on your specific issue having been sorted at some indeterminate point in the future when you inevitably have to update. I just backup key directories and accept that if the OS is broken beyond my ability to repair it then I'm doing a full reinstall which will take longer than restoring an image. Again, no right or wrong way here I think, just whatever suits.
    I think this would have been far less likely to happen on Fedora. I've expanded on this further below.
    @3DIO
    There is nothing to be 'suspicious' about re. CachyOS. It does exactly what it says on the tin. Running Arch as your only OS is for really very knowledgeable people only and I don't include myself in that category. I know enough, but I'm no guru. Both myself and bluejaunte have Windows as our ultimate fallback if it all goes really pear-shaped.
    If you want to run a Linux OS as your only OS you need to look at something which has proper professional, rather than community, backing. CachyOS is not that. One that is: Red Hat Enterprise Linux is used by militaries and contractors worldwide, by the National Health Service in the UK, by a load of blue-chip corpos. It's more stable and bug-free than any Windows distro. If you see the words 'stable' and 'Linux' in the same sentence though, you can mentally substitute the word 'old'. RHEL is the Z80 of operating systems. It's been around forever, it's thoroughly understood, has proper professional support, requires a subscription and you won't be playing games on it or running Studio. (You can get a free version if you sign up as a developer but, really, don't!)
    Downstream from that is Fedora - same code, newer packages with rigorous testing. It's not as straightofrward to install and setup as something like Linux Mint or Ubuntu (both recommended for new folks), but it is more reliable.
    That's what I would recommend to you and most people. Debian is fine but it's another community effort. There is a minimalist install of Fedora (although your definition of 'bloat' is peculiar to you - most of us would describe it as software we don't want which impacts system performance *which we can't uninstall*. Windows Edge. Windows telemetry. That's bloat. Not a software package you can remove in a few seconds and doesn't magically reinstall itself after an update) but I suspect you will do your own thing as usual :)
    Also, once again, the ROCm stack will not provide dForce in Studio with your GPU. You'll need elements of it for Studio to see the card but beyond that, no. Re-read the conversations!
    @TimberWolf
    Just to be clear though, you're saying the second video would be of no use to me, but not the first?  The first is actually Windows 10, and from the sounds of it I can expect to get my AMD RX580 running that way if all else fails.  Important to note that either way, it's not intended as a permanent solution.  I reckon me buying a new card is at least a year away now since I've got to put aside some cash for carpet, curtains and blinds for at least the living room to be going on with.
    So I really hope that at least the first video will work for me, otherwise I can't play with AI at all until I get the new card.
    Anyway, things are going to get pretty hectic for me from tomorrow.  I'll be reading the forums now and then, but intentionally not logging in so as to not get distracted until I'm settled in.  Gonna be at least a month until I get back to the computer stuff I reckon, but the move is worth it so I'm not complaining!
  • Good afternoon.  I installed Daz Studio 4.24 from Daz Install Manager and had it running well on Fedora 43 through WINE for several months.  I have an older NVIDIA 1070 but I was able to get GPU rendering and DForce to work.  I saw that Daz Studio 6 was available in Daz Install Manager and installed it the same way I did 4.24.  When I select the Studio 6 icon from the Apps list, nothing happens.  Has anyone tried to and been successful installing Studio 6 on Linux.  Thank you for your feedback.
    edited June 18
    This one keeps cropping up, so I'll just cut and paste part of my previous post. If you dual boot with Windows, you can copy the required file from your existing Windows installation rather than downloading one. It says 'Alpha' but it'll work for the Beta and the general release.
    I've just got Studio Alpha to run in CachyOS and I expect you should be able to do the same in Tuxedo and many others with little difficulty. If you can get Daz Studio 4 running, you can get the Alpha running. You'll have to install DIM via Lutris if you haven't already and the process is identical. On startup it fails miserably and the logs are a lengthy and somewhat disappointing list of failures of various DLLs to load which initially confused me because they are all present. It's just one Windows System DLL that's missing and that sets off a cascading failure: icuuc.dll
    Grab it from here - https://www.dll-files.com/icuuc.dll.html - it's the very last one, the larger of the two 64-bit libraries. Drop it into /windows/syswow64 or the same directory the Alpha dazstudio.exe is in in your wine prefix (it shouldn't matter) and it will fire up and create the usual set of files on its first run. Symlink the Nvidia DLLs, symlink your libraries again and it should work just as well as 4.24.x.
    The viewport performance is possibly worse than in Windows but the rendering times on my benchmark scene were about 10% faster. However, because they are so quick with multiple GPUs I'd say that's within a margin of error - it may not actually be quicker but the logs say it is. It's more than usable as a platform to launch your scene for rendering (or to kick it across to a local Iray server) but it would be a miserable experience to try and actually build a big scene or use strand/curves hair.
    Post edited by TimberWolf on
  • I ran into the same issue and got Daz Studio 6 Public Build working under Linux Mint with Bottles/Wine.
    The important part is that this is not primarily a Vulkan problem. In my case Studio 6 failed before the UI could start because its Qt6 runtime chain was incomplete or not being found correctly.
    The first visible symptom was a long list of errors such as:
    Qt6Core.dll not foundicuuc.dll not foundQt6Gui.dll not founddzcore.dll not found
    Those are mostly cascading errors. Qt6Core.dll itself may be present, but it cannot load if its ICU dependencies are missing.
    For a 64-bit Studio 6 installation, I would not use SysWOW64. The safest place is directly beside DAZStudio.exe in the Studio 6 program folder, for example:
    C:\Program Files\DAZ 3D\DAZStudio6 Public Build\
    In my case the following compatible 64-bit ICU files had to be present together, from the same legitimate Windows/DAZ source:
    icu.dllicuuc.dllicuin.dllicudt53.dll
    Do not mix random ICU versions from unrelated downloads. They need to match each other.
    After that, I still had a second startup blocker:
    msvcp140_2.dll.__std_smf_hypot3f
    The fix was to install the current Microsoft Visual C++ 2015-2022 x64 Redistributable in the Wine prefix and make Wine prefer the native VC++ DLLs for the Studio 6 launch:
    msvcp140msvcp140_1msvcp140_2vcruntime140vcruntime140_1concrt140
    with the override order set to:
    native, builtin
    The final detail was starting Studio 6 from its own program directory, rather than relying only on a generic desktop shortcut. A launcher/wrapper that sets the correct Wine prefix, changes into the Studio 6 directory, applies the VC++ overrides, and then starts DAZStudio.exe solved it for me.
    My working setup now has all three applications in the same Bottle/prefix:
    • Daz Studio 4.24
    • Daz Studio 6 Public Build
    • Daz Install Manager
    However, I use a separate launcher for Studio 6 because it has the Qt6/ICU requirements. Studio 4 should not inherit the Studio-6-specific Qt/ICU path settings.
    So, for the original Fedora/Wine issue, I would suggest this order:
    1. Start Studio 6 from a terminal and inspect the first DLL errors.
    2. Check whether icuuc.dll is missing.
    3. Place a matching 64-bit ICU set next to DAZStudio.exe, not in SysWOW64.
    4. Install the current VC++ 2015-2022 x64 redistributable in the prefix.
    5. Prefer native VC++ DLLs for the Studio 6 launch.
    6. Launch Studio 6 with its program folder as the working directory.
    That brought Studio 6 up normally for me, including the full Qt6 interface and normal scene loading.
    Which is why I still recommend Lutris for people new to Linux as it avoids all the complications you had to work around. There are many ways to work around these issues but, from this thread's history, most people are using Linux for the first time and just want Daz software to work with the minimum amount of hassle. You can use Bottles, you can use Steam, you can just launch the executable and let system WINE take over - these methods all require further interventions that range from fairly straightforward to reasonably complex.
    Or you can install Lutris, install the Daz software, copy one .dll and be done with it. No deep-dives required.
    It is good to see a Bottles solution though. That package basically fought me every step of the way with Daz and other software so I have never felt the urge to revisit it.
  • Anyone know how to get Dforce working on Linux? I think Svesop's nvlibs files are outdated or something. I tried this on cachy and bazzite and had the same result. "No opencl device found" Under the advanced tab. In both distros I am using driver version 610 or something like that. Iray works perfectly though. I can render with my gpu just no Dforce.
  • Forgot to mention, I'm using a 4080s, Daz studio6, and Lutris with the cachy runner.
  • brainmuffinbrainmuffin Posts: 1,324
    I was able to get it to work under Mint and Lutris previously. It was a driver issue. I'll have to check that it still works.
    I found out driver 610 is bleeding edge or the experimental driver. I think the nvlibs only works on the whql driver which I think was 590 or 595. I switched to bazzite thinking it was using the normal drivers. I'm going to try and roll back to the non experimental driver tonight. Hopefully that will fix it but if not I will probably just go back to windows until there is an update.
    Read back in this thread a little. There's plenty of dForce discussions.
    edited June 25
    @mordeomortem
    The latest updates to the proton-cachyos runner are the problem. Switch your runner to System (should be 11.something) and you should find it magically springs to life. It works fine with the 610 drivers at my end.
    1348 x 1121 - 209K
  • TimberWolf said:
    @mordeomortem
    Thanks that actually did work! I actually installed Kubuntu which gave me full control over my gpu drivers. I downgraded to 580 which I learned was not the problem. I tried every runner on lutris except the system runner lol. Finally after AI took me down about 50 rabbit holes I tried the system runner. It took a few tries to get both the dforce and Iray stuff working but it's finally working! Now I can ditch Windows for good! I hope...
  • mycohlmycohl Posts: 1
    edited July 24
    Haven't had any luck searching this thread, so I figured I would ask.
    The problem I am having is that after an Iray render, the viewport stops updating completely. It doesn't update when changing cameras/views, viewport render/shading setting, or loading a new scene.
    The only "fix" is to completely restart DAZ. It wasn't doing this the last time I used it (several months ago) and I'm not exactly sure what has changed.
    My current setup is:
    Ubuntu 24.04 (X11)
    nvidia-driver-580 (was also happening on versions up to 595)
    DAZ Studio 4.24
    WINE devel 10.20
    DXVK 2.7.1
    VKD3D 2.14.1
    nvidia-libs 1.0.2
    Has anyone else experienced this problem, and if so, were you able to find a solution?
    EDIT: The other thing I notice is that there is pretty extreme graphical corruption when I start DAZ, which wasn't happening before, as far as I can recall. Pic attached.
    Updated to specify that I am not running Wayland, I have already tested multiple versions of the nvidia driver, no other software seems to be having graphical issues, the nVidia device is not my primary display device, and I will not be reinstalling my operating system. Thank you for whatever this was, I will look for help elsewhere.
    1872 x 1082 - 307K
    Post edited by mycohl on
