How can I git rid of noise in my render of indoor scenes? Is this casused by the lighting?
When my render is finished, on an indoor scene, I have noise instead of a smooth finish. What causes this, i[s it lighting] and how do I fix this so I get a smooth render?
  • merrygrannydemerrygrannyde Posts: 25
    OK this is the render,
    3000 x 3000 - 2M
  • Richard HaseltineRichard Haseltine Posts: 111,958
    Probably lack of lightyes, not quantity but rather having lights that can easily reach into the scene - the more you rely on light bouncing around to hit a surface the longer it will take to reach a settled value. As it is some pixels are showing areas that have hit a light beam several times and others are areas that have rarely if ever met a light beam, so the tonal value varies a lot.
    Thank you. I found a tutorial online that shows how to use the denoiser & it also said deleting stuff like unseen walls & props will help with the lighting. I'm trying that now so will see how it turns out
    I know I had to sometimes delete walls in Poser when I was working in that program
    Thank you for your help, I got it pretty good using what to do in DS & then I fixed it better in Paint Shop Pro
    The trouble with deleting walls etc. is that the results can look unnatural, depending on what you are aiming for. With rooms you generally want to use local lights (points, spots, and light-emitting objects) rather than distant lights or an HDRI environment.
  • ChezjuanChezjuan Posts: 548
    One thing you can also try, especially for scenes where you want it to be dark, is to go to render settings, select progressive render, then increase the Max Samples and Max Time sliders. This allows Iray to process more iterations whick will get rid of the noise without using denoisers. Depending on the render I sometimes find tha tthe denoiser (either internal or external) can make it look a little off.
    I currently set my values to 15000 iterations and 36000 seconds (10 hours). With my system I have never had a render go that long - it hits the max iterations way before then.
  • felisfelis Posts: 6,626
    I would suggest to add a weak area light, could be a point light with geometry or my ever used emissive planes, and then increase Tone Mapping in Render Settings, to keep it dark.
  • Jan_ScrapperJan_Scrapper Posts: 798
    edited May 9
    I agree with this advice so much!!!
    First of all, your art is great that you have shown us!!!  I just don't think you let it "Process" long enough.  Daz Studio must take it's time to process your art with many factors.  If you have a computer that is not very powerful like I do, you must be patient.
    My art is slowly getting better since I changed my render settings and you can see for yourself  in my gallery that I rarely have noise!
    This is the best advice I ever got for rendering and I did NOT list who told me :(
    Personally, I crank min samples all the
    way up, unlock max samples and add a few zeros
    and crank that all the way up, move quality
    into the hundreds, set time to zero, and cook
    it until I think it looks good. A lot of times
    I set it to rendering, then watch a movie or
    workout or something, come back and give it a
    look every 20 mins or so so I am not feeling
    like I am waiting forever. Usually I render
    large at at least 3k pixels for the shorter
    length, and average it takes 45 minutes or
    so to finish to my liking on my gtx 1070,
    unless it's outdoors and lit mostly or
    fully with HDRI,
    then it can be as little as 20 minutes.
     turn off "Render Quality" and let it run a
    specifig
     no of samples.
    Control the render with the max samples
    setting
    (I use 5000 but you may want higher depending)
    and remember you can always stop it when it
     looks
    good enough for you.
    Edit:  Another thing I try to do is render at 2x
    the desired resolution and resize/down sample in
    an image editing package like photoshop or
    gimp.
    A couple of things to keep in mind — in an
    Iray
    render, the surface materials and the lighting
    setup is even more important than in a 3Delight
    render, and even more sensitive to getting it
    "not quite right", so you will end up tweaking
    settings a lot. Also, an Iray render doesn't run
    once and it's finished, it keeps running until it
    hits one of the three stop condition limits (time,
    iterations and convergence %). The render will stop
     whether or not the materials and lighting are "not
    quite right" enough to prevent the render from
    looking good.
    Hit cancel or Esc key to stop rendering.  Let it finish
    or you will lose your render.
    I let my renders run all night :)  My computer is old, but hanging in there.
    Please try this before purchasing expensive lights!!
    Also, go into Daz Studio Environment under Render Settings.
    Change the Environment Mode to Sun-Sky as I have circled in the attached.
    Play with the Time of Day to adjust the lighting.
    I am understanding the power of Daz Studio more and more every day!!!
    827 x 1145 - 114K
    840 x 1116 - 119K
    Post edited by Jan_Scrapper on
  • jmucchiellojmucchiello Posts: 2,570
    I always bump ISO Film in tone mapping to 200 (or more). It increases brightness without washing out. (Well, really high values will wash out but 200 is only double the default.
    I also have a bunch of emissives I've created.
    Create a radial gradient where the center is white and edges are black. Apply that to the luminance field as a mask. Works great for planes, and not much else.
    Or
    create a plane with 5 division. In geometry editor, delete (1,2), (1,4), (3,2), (3,4), (5,2); (5,4), and all of rows and columns 2 and 4. Allows for scaling up to light a big scene without having meters and meters of light. (also works with 7 divisions and deleting 2, 3, 5, and 6)
  • AgitatedRiotAgitatedRiot Posts: 4,768
    edited May 10
    Or
    That's one way; another way is to increase or decrease exposure value. tonemapper.
    Post edited by AgitatedRiot on
  • neomanneoman Posts: 85
    There are several ways to deal with your issue.  I hope these help!
    https://youtu.be/WQpAETDf7xQ
    https://youtu.be/xyyL5FDZwLw
    https://youtu.be/cEteLW7e-CQ
    https://youtu.be/Cuc3AHF2DH4
  • PrefoXPrefoX Posts: 336
    edited June 18
    the tonemapper should have zero impact on the noise, because its post process / after the image was rendered.
    A great image denoiser would help a lot, intel is developing the best one at the moment and its open source. DAZ could implement it
    https://www.openimagedenoise.org/
    its possible to use it without a DAZ Studio implementation but then it doesnt take the normal maps etc in account.
    Post edited by PrefoX on
  • TheLionTheLion Posts: 49
    You could try to add some more light, perhaps even render the scene out a little brighter than what you have in mind, then adjust it in Photoshop/Gimp/Affinity to make it slightly darker. Increasing the iterations and the path length (or setting the path length to -1) might help as well. It will increase render time though.
    Usually fireflies / noise like that is due to either not giving the render enough time (either cancelling it early, or having settings that decides it's finished too early) or not having enough light. For an evening scene you can even use a blue colored light to give the impression of darkness even if the scene is actually fairly well lit.
    Something you could try is placing a ghost light plane in the top / roof of the bed, about the same size as the "roof" of the bed (or the ceiling of the room itself if the bed is open), and make it shine downward. Even a fairly dim ghost light might resolve your issue. It's often that there isn't enough light and the little light that is present needs to bounce too much to fill the scene that results in these fireflies. So adding an ambient light that fakes light bounce from ceilings often helps. If there's a bedroom window, or you want to fake one, you can also place a ghost light rectangle where the window is and make it shine into the room, faking light from outside. (something similar could be done with the opening at the bottom of the door in your scene, but not sure how realistic that would look if you add too much light emission from there).
    Love the scene and the render though! smiley
    edited July 6
    Hope the tutorials are helpful
    Post edited by neoman on
