New Year, New Sales Thread: Report Issues Here 4 "Reporting Only"
1101113151674
  • FrankTheTankFrankTheTank Posts: 1,624
    I didn't see this MAD-LOYAL coupon code until 5 minutes before the store changeover (It was only shown in DIM when I logged in). Now I can't use it. Why would Daz send a code like this only through DIM? I didn't see the code in my email or in my Daz site mail.
    499 x 434 - 232K
  • Richard HaseltineRichard Haseltine Posts: 111,154
    I think it was a matter of not removing the incorrect information from the DIM notification - they had removed the need to apply the coupon early in the day so that people didn't use it for the character and miss the other discount. I certainly seemed to have an equivalent discount on my cart yesterday, without needing to use a coupon code.
  • Cybersox said:
    Um... March Madness is supposed to be over.  So why do all of the featured artists stores still have a cutoff excluding any products newer than 2024?  Is that a new DAZ policy going forward or did someone forget to change a setting?
    +1 to this question
  • jmucchiellojmucchiello Posts: 1,935
    I think sending any coupon through DIM is weird. I doubt anyone leaves DIM running all the time. I only launch it after a purchase, not before. If I hadn't seen people mentioning the coupon on the forum, I'd never have known it existed until it was almost impossible to use since I'd have already checked out wtihout it. (I did get to use it. Thanks forum folks.)
    It was originally on the promo page too, but once it was removed as a requirement (it just checked for a purchase on those days) it was removed from the promo page but not from DIM. If it still gave you another 20% off your order then you had an unplanned windfall, as far as I know.
  • LeanaLeana Posts: 13,473
    felis said:
    Why am I set to earn 0 tokens, when I am buying above 10 dollar?
    It's not above 10$ without taxes.
    I didn't see any extra discount. I checked out first with the free character, and then later made one last big cart before my Premier expires today. So I lost out on that extra 20% discount.
    I didn't make additional orders to be certain, but I think the 20% applied throughout the day - it wasn't linked to having the free character in the cart.
  • HavosHavos Posts: 5,692
    The 20% off did not work for me without a coupon code, and I checked out 6 hours or so before the end of the DAZ day. If it had worked without the coupon, I would have used the other coupon that took 30% off 3 items, since I already owned all 5 of the bundling items. I was swapping between the two tokens, so I could see the 20% discount vanished when the MAD-LOYAL coupon was removed.
    This was my experience, too. Since I didn't own all 5 of the bundle, I saved money not spending $3 for 30% of 3 versus 20% off 10 or 11 items.
  • SilverGirlSilverGirl Posts: 3,831
    Issues with the sale page today:
    Under "TACK OR TAX", fine print says "minimum price $2.99 after discount" which makes no sense considering that the code gives you a free item
    Featured artist store formatting is wonky. Little boxes all on the left side of the page.
  • Cris PalominoCris Palomino Posts: 12,933
    Inquiry sent.
    The item does end up being free in the cart making the "minimum $2.99 text" very out of place.
  • vwranglervwrangler Posts: 5,037
    edited April 15
    Daz might consider editing the text on Matthew for Genesis 9.
    https://www.daz3d.com/matthew-for-genesis-9
    Literally every direct reference in the "What's included" section talks about "Andy for Genesis 9", not Matthew.
    Either the text is wrong or the character name is wrong.
    Post edited by vwrangler on
    edited April 15
    Also, the display of the Tacks Artists is broken, in both Firefox and Chromium browsers on Windows 11. I can't imagine it's supposed to be a truncated single column with teeny icons like that.
    tacks artists
    1343 x 851 - 58K
    tacks artists
    will report
  • MonkeMonke Posts: 69
    How do you get the TACKLE coupon code to work?
    If I create a new cart and put two Tack new releases in there, then try to use the code, it says it's invalid.
    It says, "items must be simultaneously in cart for discount to apply." so I assume you need 2+ new releases in the same cart.
  • genarisgenaris Posts: 373
    +1 from me, also. So tired of weeks or more of only seeing the same old set of products to pick through in the artists stores that I have already picked through for what seems like forever -instead of being able to see the things that fall into that gap and which haven't been in the sale categories but are well past their introductory blackout period.
    XtraDimensional said:
    +1 to this question
    It didn't work for me, either, just said not valid code. But it did work to help me realize that $2 off isn't so much a discount as an insult. LOL!
  • memcneil70memcneil70 Posts: 6,029
    I also have two new TACK items in my cart and the code TACKLE doesn't work.
  • Charlie JudgeCharlie Judge Posts: 13,613
    The TACKLE coupon is not working for me also. Please fix.
    edited April 15
    I think a file is missing from LI The Magic Rug - Columns & Grounds Prefab, SKU 114999. I finished my download in DIM and only 11 preset scenes showed up in Environments, but no props as the promos showed. I clicked on one of the scenes and got this:
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch HP - Band Ver 1 24x48/LI TMR X - Column Arch HP - Band Ver 1 24x48.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch HP - Band Ver 1 24x48/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch LP - Rec 400 24x48 HE/LI TMR X - Column Arch LP - Rec 400 24x48 HE.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch LP - Rec 400 24x48 HE/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch LP - Trim Ver 2 24x48/LI TMR X - Column Arch LP - Trim Ver 2 24x48.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Arch LP - Trim Ver 2 24x48/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Base HP - Dec 240 100x100 V1/LI TMR X - Column Base HP - Dec 240 100x100 V1.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Base HP - Dec 240 100x100 V1/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling HP - Dec Emitter 09x09/LI TMR X - Column Ceiling HP - Dec Emitter 09x09.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling HP - Dec Emitter 09x09/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling HP - Dec Glass 09x09/LI TMR X - Column Ceiling HP - Dec Glass 09x09.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling HP - Dec Glass 09x09/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling LP - Dec Inset 09x09/LI TMR X - Column Ceiling LP - Dec Inset 09x09.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling LP - Dec Inset 09x09/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling LP - Sq 400 24x24 HE/LI TMR X - Column Ceiling LP - Sq 400 24x24 HE.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ceiling LP - Sq 400 24x24 HE/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/Morphs/Laticis Imagery/Base/LI TMR X Floor Tile Rig - Tiles Distortion 02.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/Morphs/Laticis Imagery/Base/LI TMR X Floor Tile Rig - Tiles Irregularity 01.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/Morphs/Laticis Imagery/Base/LI TMR X Floor Tile Rig - Tiles Irregularity 02.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/Morphs/Laticis Imagery/Base/LI TMR X Floor Tile Rig - Tiles Smoother Edges.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor HP - Tile Rig 030 24x24 x16 TO/UV Sets/Laticis Imagery/Base/-0xa8aaecb.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor LP - Sq 400 24x24 HE/LI TMR X - Column Floor LP - Sq 400 24x24 HE.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Floor LP - Sq 400 24x24 HE/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ring - Ver 10/LI TMR X - Column Ring - Ver 10.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Ring - Ver 10/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Shaft - Cir 06x48/LI TMR X - Column Shaft - Cir 06x48.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Shaft - Cir 06x48/UV Sets/Laticis Imagery/Base/default.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Wall LP - Rec 400 24x48 HE/LI TMR X - Column Wall LP - Rec 400 24x48 HE.dsf
    /data/Laticis Imagery/LI The Magic Rug/LI TMR X - Column Wall LP - Rec 400 24x48 HE/UV Sets/Laticis Imagery/Base/default.dsf
    and:
    I am attaching an image of what the Product Library shows at this time.
    2292 x 2008 - 548K
    Post edited by memcneil70 on
    Reported.
    and:
    Reported.
    Thank you very much Cris.
    Mary
    Cris Palomino said:
    Reported.
    Is there any response on this? The coupon still is not working for me.
    edited April 15
    These items are new today but are not included in the "Tacks" new releases and therefore are not receiving the same discounts as "Tacks" new releases (ie 'the 20% discount for owning all of the 'Best of Bundling ').
    https://www.daz3d.com/li-the-magic-rug--columns-01
    https://www.daz3d.com/li-the-magic-rug--grounds-columns-01
    Shouldn't they be included in the "Tacks" new releases and therfore receive the discounts?
    Post edited by Charlie Judge on
    Was just coming to check on this question myself.
    This being dealt with
    edited April 15
    Charlie Judge said:
    Cris Palomino said:
    Reported.
    Fixed now, though it discoiunts the items uniformly rather tyhan taking $2 off one of them - but my test cart's total was right..
