Adding to Cart…
I think the best bet for targeting Linux (from a developer point of view I mean) would be to target the biggest core base in use. I mean, look how popular Ubuntu and its derivatives are, and then consider that Ubuntu itself is also based upon the Debian core. So I can't help but think that if DAZ were to at least aim for base Debian compatibility, then it would at least work on most of the most popular distros by default.
Either way, I'm in full agreement with everyone desparately wanting to see a native Linux installation of DAZ Studio. To be honest, I think DAZ are doing themselves a massive disservice by not doing so. I think to ignore Linux would be a big mistake that will, to put it as politely as possible, come back to bite them on the backside big-time if they don't learn to read the room!
The amount of discontent I'm seeing online due to the practices of Microsoft as of late, is absolutely relentless now, I think it's very telling, and it's sending people over to Linux in their droves!
Why not use nvidia-smi and judge by the wattage?
@vrba79
@3DIO
There are many ways of distributing Linux applications which essentially make them distro agnostic: Flatpaks, snaps, appimages and others. There are advantages and disadvantages for each of these methods but the downsides are mainly the larger download and installation size due to these packages containing all of the system files needed for them to run. It's not quite an accurate analogy but think of portable apps for Windows which contain the .dll, .ini, .json files et.al. that are needed for them to run; any update of Windows which changes those .dlls and others won't affect a portable app and the same is true for Linux distros. The only restriction is generally that the user must be using a Linux distro with a kernel at least as new as the distro used to create the distribution file.
There may well be one but I can't think of a reasonably modern (last 5 years or so) and somewhat mainstream Linux distro that won't run Blender natively for example. I don't think that's an issue.
We don't know if Nvidia's agreement with Daz is restricted to official Windows distributions only (there have been some well-publicised heated disagreements between Nvidia and Linux developers), we don't know if Daz is concerned about an explosion of support tickets even if they released it as an unsupported version, we don't know most things because Daz doesn't really communicate with its user base. All they've said about this is that there will be no native Linux version and, for now, I would take them at their word.
If you want Studio on Linux, and it will work on any reasonably recent distro of Linux, you can get the Windows executables for both the current 4.24.x release and the 6.x Beta running through WINE with no indepth knowledge or arcane coding tricks required. All you need to be able to do is follow instructions accurately. It takes about 15 minutes + however long it takes for DIM and Studio to download and install. Just be prepared to start learning again because you'll want more from your OS than just running Daz Studio!
Well that sounds absolutely fan-bloody-tastic! But where, pray tell, is this solution to be found?
@TimberWolf
Hi.
I've had similar a experience; plain vanilla WINE got DIM running well enough to install and run with only very minor annoyances related to window behavior. But without the GPU.
I haven't tried it recently, but are you saying that these days, even the GPU just works? That's stupendous news, if so...
Agreed. Just wait for the Steambox. When people discover that the "water is fine", I think it'll start a trend.
Also, I think Red Hat Enterprise Linux is already synonymous with Linux in the 3D world and the only oddball outlier I can think of that insists on Ubuntu, and a specific version and a specific GPU even is move.ai, And so most any RPM based distro can be coerced into working. And back in the day, I even got Maya running on Ubuntu without too much trouble.
@TheMysteryIsThePoint
Yep, GPUs and multi-GPUs work absolutely fine under Linux. Debian-based distros lose the ability to use the built-in denoiser for reasons I have yet to figure out, but it's related to Optix; the translation layer in WINE under Debian doesn't seem to be able to handle it properly. However, Fedora and Arch-based distros work perfectly, including the denoiser. Desktop compatibility varies from distro to distro but having spent the best part of a week installing, testing and uninstalling a wide variety of distros I would suggest using the KDE-Plasma desktop if it is available for whichever distro you prefer - I've found zero problems with it. However, Studio will work with most desktops and windows managers (Gnome, Cosmic and Cinnammon to name but a few) but you may find the odd UI glitch that wouldn't be present in KDE.
To get your GPU(s) working, you'll need a WINE version >= 10 and you'll also need to download a small additional package from Github after you've got it all up and running. To avoid filling the thread with a repeat of information, have a look through the last three or four pages - all the info and links you need are there. The Beta requires one additional tiny .dll to be downloaded and inserted into the WINE prefix as it is required by 6.x and is not part of the official WINE repository.
Give it a whirl - you'll be pleasantly surprised :)
@3DIO
If you have zero or limited experience of Linux I suggest you try out a few distros using a spare drive if you have one. It may take you a number of installations to find a distro that clicks with you and has the features you need, but there is one out there with your name on it. After you've picked one, or if you already know what distro you would like to use, pop back here with the details of the OS and desktop you've picked and I'll give you a step-by-step guide to getting it running.
It isn't possible to produce a generic guide that covers all possible combinations of distro and desktop unfortunately - the process can differ quite widely depending on what you want to install.
If you use Adobe products to any great extent you'll find that, with one or two exceptions due to their availability on Steam, none of them will install and work well under Linux (or even work at all) so do check what else you need from your OS as well.
Agreed, and hopefully so. With STEAM being as big and influential as it is, I think that new STEAM box could trigger a huge surge in people taking up a Linux desktop!
@TImberWolf
That's very kind of you, cheers! I'll have to take you up on that, and if I'm understanding you correctly, ideally, I need a KDE-based distro that also has WINE 10 or higher installed. I've tried many distros over recent years, so many in fact I've lost count, but if I recall, the problem I tend to have with KDE-based distros is that they never seem to allow you to pick and choose packages at installation. So can you recommend a KDE-based distro that has a 'known-to-be-working' version of WINE built-in, but also allows a very minimal install aside from that?
Can't do it right now, but I'll probably get around to it at the weekend if you have a specific recommendation for me. Basically, apart from the bare-bones OS and the KDE environment, I don't want anything installing apart from the correct version of WINE, so that Daz Studio will work. Once I have that, I'm sorted, because everything else I use already has an official Linux release anyway.
@TimberWolf
I don't render in DAZ Studio at all, but it would be nice to run dForce. Think I'll give it a try based on your encouragement. Thanks!
@3DIO
Whilst there is nothing I know of that meets *all* of your requirements, I would recommend Nobara Linux with the KDE desktop. It's Fedora-based (so every Studio feature works), very easy to work with and is specifically geared towards content creation and gaming. Whilst you can always install anything that's missing or upgrade WINE, Nobara comes with the latest Nvidia drivers as part of the installation package and these can be a bit of a hassle in some distros. It does, however, come pre-loaded with other software and you're going to find every distro does that. Unless you decide to howl at the moon and install something like Gentoo, mainstream distros are always packaged with apps that reflect how their creators believe they will be used. Nobara comes with Steam, some streaming packages, that kind of thing but they can all be removed at a later point.
Earlier in this thread someone has written a guide to getting Daz Studio running on it. I highly recommend you don't follow it because, whilst it works, that method will probably cause them and you problems further down the line when you install other software but if you just wanted to try it out and see if it suits you, go for it, but I'd recommend then nuking the installation and starting again afterwards. We'll be using a WINE manager (Lutris) to sandbox a WINE setup so that it does not affect, and is not affected by, any additional software you want to install in the future. Best practice and all that good stuff. Seriously though, it is worth setting these things up properly in any version of Linux.
https://nobaraproject.org
https://wiki.nobaraproject.org/en/new-user-guide-general-guidelines *do have a read of this before you start as there are a couple of points worth noting.
I would suggest either the Official-NV or the KDE-NV downloads which come with basically everything ready to go. Have a read and decide which one suits you best. Or try both! Do note the disclaimer that states this distro is a 'hobby project' - Nobara is highly rated and very stable but the creators are making sure you understand that if you intend to use this OS commercially they are not liable for any losses you may incur due to issues with Nobara.
The only other thing I would suggest to you is to have a quick check to determine if any additional hardware beyond the usual fitted to your PC will still work. I'm talking about internal or external soundcards, wifi dongles, video capture cards etc - the categories of hardware most people don't have. Check compatibility with any printer or scanner you own as well. 99% will work natively with Fedora but it's worth making sure that you're not going to find yourself locked out of something you need before you start!
My experience is that the GPU doesn't just work. I installed Daz Studio on Commodore OS Vision and Iray works with CPU rendering but it can't see my RTX 4070S. I haven't got into the details of configuring Wine yet.
Commodore OS Vision ... first time I've heard of it! I had to do some research into this. Just to confirm, you're system is x86_64 PC with Nvidia RTX 4070S commonly available on the market, not the cool Retro Commodore 64, right? Gosh, seeing the other retro Commodore, the Commodore Ultimate 64, brought to life -- on a Xilinx FPGA -- reminded me of the old IBM PC from the early 80s.
Cheers!
Yes, it is an x86 64 bit PC with Nvidia RTX 4070S dual booted with Windows 11 Pro and Commodore OS Vision. The Commodore OS is Linux, I think it is based on Mint, with a lot of display tweaks, emulators and a load of free games for what it's creators think a modern Commodore OS might look like. I've also got The C64 made by Retro Games and both Amiga Forever and C64 Forever on Windows. I haven't looked at the Ultimate 64 but I think I have as much Commodore emulation as I need for now.
@TimberWolf
I was sure I'd heard the name "Nobara" before, but it's something I never followed up on. Spent pretty much all last night looking into it after seeing your recommendation (cheers), and have decided to give it go. As far as I can tell, it's pretty damn good in allowing you to decide what you want installed. So I don't mind that. Plus, I would need to install STEAM anyway, so that's a bonus for me. To top it all off it's even set-up out of the box to accept the official Linux release of DaVinci Resolve Studio, which is the icing on the cake really!
I'm personally not worried about denoising, and I'm more familiar with GNOME than KDE so I'll probably go for the GNOME version first, but either way I'll let you know when I have it installed. If it works as expected then I'm sorted, because other than Daz Studio, there's absolutely nothing else I use Windows for.
I've attached a video in case others are curious. It's three years old this one, but it shows the post-install driver selection and auto-installation functionality:
On second thoughts I'll download and install the "Official" version (as shown in the video).
Might as well since that too is based on GNOME.
I'll report back once I get it installed.
TimberWolf,
That's the morning-after hangover, right? Getting the Daz3D-Wine-Linux stack up and running is only the first steps. Learning about the Linux operating system is the next leg of the journey.
I've been asked what Linux skills and know-how a beginner should aim for. At the least: grasping the concepts of the UNIX shell (pretty much Bash these days) and its rudimentary commands; user accounts and file system organization and permissions (SUDO do's and do nots); and networks and firewalls.
It can be argued that Wine hides much of the underlying Linux complexity, but Daz relies on system components -- network and GPU -- that call for an understanding of Linux runtime libraries and device drivers. These modular pieces coordinate by means of configuration files that set requisite file paths and shell environment variables. Knowledge is a useful tool, especially when things don't play nice with one another.
Here are a couple of examples to highlight what I mean:
I remember the day, eons ago. when a visiting professor showed up with several boxes of 3.5 inch disk. It was Slackware Linux, pre-1.0, and when he laid out the installation disks the stack was as long as his forearm. He came prepared to spend the night at the computing lab to deploy Linux on a disused 386 PC. Whew! Since then, Linux has come a *very* long way.
Invariably, the more casual users adopt Linux, the more they're exposed to the tech and the homebrew-hacker culture around which Linux grew up. Not everyone needs to be a comp sci grad or know POSIX and such, but some basic level of know how and caveats are needed. Armed with that, folks moving from Windows would have a more pleasant experience working with Daz3D in Linux.
Cheers!
I've downloaded it, written it to a bootable USB, and just took a look at it in live mode. The version I downloaded is "Nobara-43-Official-2026-01-25" which I wrongly assumed was the official version based on GNOME. But it isn't, it's based on KDE now, so it looks as if they made changes and decided to use KDE as the offical version since that video was made.
Nevertheless, I took a look at in running in live mode from the USB. Way too much pre-installed stuff for my liking to be honest, but if it gets Daz Studio working I will at least take the time to download the other versions and see which I prefer the most. So I'm ready when you are. I haven't installed it yet, just in case there was something you specifically wanted me to do during installation, or something you specifically do or don't want me to install during the process.
Getting a bit late now to be installing it tonight (it's around 9:15 PM as I write this), but I can play tomorrow, or really whenever you have your instructions ready.
@3DIO
Just fire away and install it. I can't tell you how Nobara/Gnome will play with Studio because I haven't tried that combination. Gnome is Wayland-based now so it should be ok (and Gnome worked fine with other distros) but there's no way of really knowing until you try. I can guarantee that the KDE desktop has zero glitches or oddities, works well with multiple monitors, including 4K, and copes with mixed resolution setups. It performs just as well as on Windows - the choice is yours as the process of installing Studio is identical.
The pre-installed applications you don't want can be removed at some convenient point btw - there is nothing uninstallable which is more than can be said for Windows...
Anyway, all I'll assume is that you've got a functional installation with the supplied Nvidia drivers installed.
In addition, after installation you will need to download the following - just drop them into the default Download folder or wherever you prefer:
1 - The Windows executable for the Daz install manager - DIM.
2 - https://github.com/SveSop/nvidia-libs/releases/download/v1.0.1/nvidia-libs-v1.0.1.tar.xz
* Required for 4.24.x and 6.x Beta
3 - https://www.dll-files.com/icuuc.dll.html
* If you intend to install the 6.x Beta for 50xx support you will need the very last file on this page (0.61Mb) or, if you're dual booting with Win10/11, copy it from your /syswow64 directory onto your Linux drive.
Let me know what combo of distro and desktop you picked so I can grab the same version, and which version(s) of Studio you're installing, and we can get started. The OS installation is the hardest part of this!
@csaa
Happily, the days of shell commands being named after the creator's girlfriend/dog/hamster and having zero relevance to the actual function being performed are long over! I don't think Linux has even been more available to the casual user than now; stable kernels, Windows-esque UIs, YouTube channels full of very helpful and knowledgable people who actually know how to teach and not just show off their superior technical skills. If all you need is email, a browser and some office software, which I would guess covers a large percentage of PC users, you could install any modern Linux distro and never have to touch the console or understand how the OS is actually structured.
More and more applications are being released with native Linux support, hardware drivers without OEM support are built into the kernel - I could go on and on.
This is all great until you want to go off-piste a bit (like installing Daz Studio and getting it to actually work properly) or the utterly inevitable moment when the whole installation keels over for no discernible reason. All they did was run an update... It's at this point you really need some level of understanding as you describe or you're going to be spending a long evening reinstalling everything.
I think the main issue I've seen with Linux distros is people assuming that it's 'Free Windows' and works the same. My father renamed the desktop links I had set up for him on his laptop, just as you would in any version of Windows - right click, select rename, type the new name. He renamed the lot. Everything. All the Libre Office links, the Thunderbird link, the browser links. Perplexed as to why they had suddenly become white squares instead of nice icons and no longer worked, I got the phone call. I do understand this; it looks similar, it behaves similarly and yet desktop 'shortcuts' on Linux do not work remotely the same as in the MS offerings. And you cannot just rename them in some flavours of Linux - it's text editor time :)
ChatGPT and AI-based search results are the utter bane of Linux forums everywhere at the moment. 'I asked ChatGPT and it told me to do this, so with no understanding of what I was cutting and pasting, I dutifully obeyed.' You might get lucky. Probably not, though. This is perhaps the biggest problem that needs to be overcome - realigning expectations. Any version of Linux really isn't Windows in any way, shape or form but it's going to be hard for people not to bring their preconceptions with them when it all seems, initially anyway, so easy.
What I would say to anyone who is reading this thread and who doesn't fancy agentic AI being shoved into their faces by Microsoft, increasingly ridiculous minimum hardware requirements coupled with ads and data harvesting, and is thinking of switching to Linux - do it. But do your research and invest some time in learning and understanding what you are moving to. The post by csaa is a great pointer to where to start your search. It's not rocket science but it is very, very different.
@TimberWolf
The one I dowloaded is "Nobara-43-Official-2026-01-25" which at the time of writing is the first one in the list if you click on "Standard Images". After watching that video again I decided to download "Official" since I was under the impression that it was based on GNOME. Unfortunately, I didn't pay enough attention to the updated description on the website, because if I had, I would have realised they're using KDE for the "Official" version now (it used to be GNOME when that video was made). So it's ready to install, and assuming I'm understanding it correctly, this version will allow me to pick and choose which drivers to install (again, as in the video).
Something I should point out is that I'm on an AMD system, and when I say AMD I mean AMD head-to-toe so to speak. AMD CPU, AMD GPU, and even the chipset of the motherboard is AMD. I suppose in some ways this makes it easier to get going, since I cannot use my GPU even on Windows. All that really matters to me is to get Daz Studio running so that I can make use of it on the CPU, not GPU.
Just one other thing, again in that video, you will notice that there are two versions of AMD drivers available to install. There's the proprietory ones and there's another version which, if you look at the description in the video next to the on screen options, suggests it's the version preferred by Blender. So although the GPU drivers are (hopefully) irrelevant in so far as getting Daz Studio running on a CPU, I still would like to install the AMD drivers recommended for Blender (but only if you ok it).
I can tell you that running it in live mode without even installing a GPU driver, it performed smooth as silk. The graphics felt super snappy and smooth as if it already knew my GPU anyway. So what I could do is install the version I downloaded, and pause there before doing anything else or installing any drivers.
I await your instructions, and again, a big thanks to you for helping like this!
OK. This info might have been useful earlier on! I'm going to guess that you'd like to at least have dForce running in Studio and this is somewhat outside my experience. I don't have any AMD hardware at home or my office but I've called a friend who has a 9060XT; I'm bringing the wine and we're going to see what we can conjure up later this evening. You'll see in the comments above that someone very experienced is having problems doing just this so I'm not hugely hopeful that this is going to be successful. Just installing Daz Studio will not be an issue but you might be left having to do everything in Blender, including cloth simulation. If you can hold on a day or so, I'll let you know what we could or couldn't do.
This will be an interesting exercise anyway because I'm sure there are plenty of people who have AMD hardware and use a Studio/Blender combination.
Ah man, sorry about that. I haven't read anywhere near all of the thread to be honest. But just so you know, using dForce in Daz Studio is still perfectly possible for us AMD users using the CPU. It's basically the same situation as with the renderer, in so far as everything works exactly the same as with an Nvidia card, but obviously not as fast since it uses the CPU cores instead of CUDA cores.
But yes, best I wait to see what you find out first. For me it's really more about just ensuring that Daz Studio works fully from a CPU standpoint. I have a suspicion that the AMD drivers won't make any difference for me other than with Blender, and like I said, it does offer auto-installation of Blender-preferred AMD drivers anyway. It's really the correct steps needed (in the correct order) to install Daz Studio that I think I would need to get right. This is why I downloaded the version I did, because (as far as I'm aware) that version doesn't install any drivers by default.
My Linux knowledge is way out of date, but why do you care about KDE vs GNOME?
