• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Geometry Shell breaking after rigging❗
YuiYui Posts: 18
February 26 edited February 26 in Blender Discussion
How can I stop this from happening⁉️
Post edited by Yui on February 26
  • PadonePadone Posts: 4,083
    February 27 edited February 27
    It looks like the rig conversion changes the rest pose and the geoshell doesn't follow. Perhaps the rig conversion expects a single geometry, especially if it is for a game engine, if this is the case you can try to join the geometries before conversion.
    object > join
    p.s. Of course more details about what you're doing can help, for example how you imported the figure and what rig conversion you're talking about.
    Post edited by Padone on February 27
  • YuiYui Posts: 18
    February 27 edited February 28
    object > join
    Tried that before; didn't work. But I think I figured out (2) workarounds that may work... The only problem is, how?
    Solution 1
    • In Daz, Export the character as a OBJ. {This should nullify the geoshell.}
    • Import the OBJ into Daz with the original model.
    • Convert the OBJ using Convert Prop to Figure.
    • Extract the skeleton from the original model using Extract Donor Figure.
    • Transfer Rigging not working!
    Solution 2
    • In blender, delete the original model; leaving only the skeleton.
    • Import the OBJ.
    • How do I merge the skeleton & OBJ!?
    Tried searching yt for both mergers, but none were helpful.
    Converting Daz skeleton to a [proper] UE5 skeleton. Of course I can using any Non-geoshell clothing, and be done with it. But I want to use these!
    Post edited by Yui on February 28
    February 28
    Sorry I know nothing of UE5, apart it is a game engine. If you're using the daz bridge I guess you should report the issue on github.
    https://github.com/daz3d/DazToUnreal/issues
  • YuiYui Posts: 18
    February 28 edited February 28
    All I need to know is how to merge the skeleton & OBJ!?
    I followed alone with this simple video, but as usual; something went wrong! I got this error message on the very last step!
    Bone Heat Weighting: Failed to find solution for 1 or more bones
    For that error you can try to scale up the whole figure, autoweight in blender expects a low poly geometry and too close vertices can confuse it, scaling up we increase the vertices distance. Then you can scale back down after autoweight. However, autoweight will be different than daz so not sure it's a solution for the shell, unless you autoweight everything thus losing the daz weights.
    p.s. Or you can also try to transfer the weightmaps from the figure to the shell, if the shell has no weightmaps. But from your description I'm not sure it is a weightmap problem, it may be something else as a limitation in the rig conversion.
    object > transfer data > mesh data > vertex groups
    Post edited by Padone on February 28
  • YuiYui Posts: 18
    February 28
    Yeah, it's like you said; there's something else causing the problem. I tried both of your suggestions, and still got the same error. I'll figure something out... ¯\_(-_-)_/¯
    Thanks for trying to help.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
