• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Problem importing expressions after merging model the genesis 9 in blender
LanternLantern Posts: 26
January 25 edited January 26 in Blender Discussion
It turns out that when importing the model into Blender using the “Diffeomorphic” add-on, when I import the facial model expressions after merging the eyebrow, eyelash, eye, and mouth models from the “CJ Raine” model with the facial model, some expressions stop working or break
The model I am using is CJ Raine HD For Genesis 9
https://www.daz3d.com/cj-raine-hd-for-genesis-9?srsltid=AfmBOoqd1A4lSLlK660GOmUPszFlRYVj7RgYZTzkPHqHU1JqGxOlt8KG
However, when I import the expressions from the "CJ Raine" facial model, but with the eyebrow, eyelash, eye, mouth, and face models unmerged, the facial expressions and others work fine when separated
I don't know if it's something related to the model or if I'm doing something wrong
Post edited by Lantern on January 26
  • PadonePadone Posts: 4,171
    January 28 edited January 28
    diffeomorphic 5.1.0.2792, blender 5.0.1
    Seems to work fine here. What do you mean by "merging" ? I mean merging rigs is ok and it is done by default in "easy import", while merging the geometries of course will break the daz morphs and it's not to be done. An exception is geografts where geometries are merged with a special tool preserving the morphs.
    Post edited by Padone on January 28
  • LanternLantern Posts: 26
    Now that you mention the Blender version and diffeomorphic, I have updated my Blender version to the latest one and everything seems to be working fine.
    By merging models, I mean this
    Step 1: I select all the skeletons of the models and choose the “merge rig” option from the Daz Studio panel
    Step 2: After merging the skeletons, I select several models at once in Blender, right-click, and select the option called “merge.”
    As for what you mention at the end, “there is a special function that preserves the morphs,” what do you mean by that? Or better yet, where can I find that tool?
    Post edited by Lantern on January 28
    January 29 edited January 29
    To merge geografts there's the option in easy import, or the command in setup > finishing. But this only works for geografts, not for other meshes.
    There's no "merge" command in the rmb menu, perhaps you mean "join" that's what you should avoid as the daz morphs may break this way.
    p.s. As a second thought, in version 5 Thomas stores the original mesh data in extra structures so that the user can modify the mesh then load extra morphs there, so may be join can work, but personally I'd not risk unless necessary. Also if we finalize the meshes the extra stuctures are removed.
    p.s. I never used it but I believe I found what you need. This should preserve the daz morphs and update the extra structures.
    setup > mesh > merge meshes
    p.s. However, keep in mind that different meshes have different uv maps and those are merged as well, which may not work fine in some cases as tiles or offsets. So in general it is best not to merge meshes.
    Post edited by Padone on January 29
    That's right, I was referring to the “join” option. I use autocorrect when I write, and maybe it changed the word ‘join’ to “merge.”
    As for what you mentioned about “UV maps,” it's true, I had a problem related to that, but luckily in Blender you can copy and paste “UV maps” to other models (although this will depend on the model's vertices).
    Forgive my ignorance. Regarding the process you mentioned, I'm talking about “Settings > Mesh > Combine Meshes.” In which program is that process found, in DAZ Studio or in Blender? Where would it be located?
    Post edited by Lantern on January 29
    January 29
    I'm referring to the tools available in diffeomorphic, of course. In general you can't use the blender tools or other softwares to deal with the setup as it is quite complex.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
