New Year, New Sales Thread: Report Issues Here 3 "Reporting Only"
15556586061100
  • junkjunk Posts: 1,548
    edited December 2025
    I see people talking about the 70%, 80%, 90% but didn't see that anyone noticed that the URL's OR the wording are incorrect.
    All three, point to a smaller subset than what the URL says.
    - The 100 points to a 50 list
    - The 200 points to a 100 list
    - The 400 points to a 200 list
    And for testing, I added stuff from the 200 list since I qualify for it with a debut product (non BUNDLE). It did not drop in price. Therefore the title of "TOP 200" is incorrect.
    IGNORE: The url says top 100 but it actually has 200 products within it. Just lazy coding.
    604 x 461 - 42K
    Post edited by junk on
  • FizzleMyth said:
    jmucchiello said:
    It's been worded exactly the same way for the last couple sales. The wording is ambiguous. Neither interpretation is "the only interpretation".
    Hence my use of the words “again” (as in this is not the first time) and “confusing”. When there are multiple interpretations of a phrase, as you suggest, the phrase can be said to be not clear—which is what I was raising a concern about.
    It would not be unreasonable to look at the phrasing of the sale, “90% off* with a Debut or Still New Release Bundle”, follow the link on the word “Debut” which takes one to a list of items with no bundles, and conclude that any Debut item should qualify.
    It wastes customers’ time when we end up trying to get a cart to work with items that seem like they should qualify but do not. (And I would not be surprised if some give up in frustration—costing Daz some sales.) It would be good if the Daz folks could instead use accurate wording in these promotions.
    But you need a plain Debut or Still New for the 80% discount - if the 90% was (Debut New) or (Still New Bundle) the requirement would be the same for both offers, how would that work?
    My point is that, if you look at the description for the 90% sale category, it says both “Debut” and “Still New Release Bundle”—when there are no Debut bundles. It even links to the Debut section (that has a bunch of items, but no bundles), which implies (incorrectly) that those items may qualify.
  • Charlie JudgeCharlie Judge Posts: 13,615
    I am almost out of bundles to use. When I run out of bundles how will I be able to trigger the 90% discounts? Repurchasing the bundle won't work because it becomes $0.00 in the cart and therefore doesn't trigger the discount
    Post edited by Charlie Judge on
  • gwp15gwp15 Posts: 77
    Has anyone gotten the "2025-TOP-HNT" coupon to work and give 80% off one of the "TOP 200 HAIRS & TOOLS" items? I put a Debut New Release in my cart and then added one of the TOP 200 items (Princess Series Oriental Updo) to my cart, but this item only shows the 40% off that I get from being a Prime member with three punches, not the promised 80% off, and at the top of the page is the feared (and incorrect in my opinion) "Coupon code is not valid" red flag.
    From https://www.daz3d.com/top-100-effects ? I tried with https://www.daz3d.com/dforce-strand-based-fe-braided-jellyfish-hair-for-genesis-9-and-8 and it worked.
  • There is little ambiguity in the phrasing. If I told you not to open "the Red or Green Box", would you think I was telling not to open the Green Box and also not to open something just called Red? Using and/or between adjectives that all relate to the same noun is very common. I have an older and younger sister; nobody thinks that "older" is a standalone word in that sentence. It's pretty obvious by the simple layout of the page that the difference between the 80% and 90% options is that the bigger discount specifically requires bundles
    The 2025-TOP-HNT coupon now works on the 80% off items.
    The 90% items  require a bundle new rlease, still or debut (but there aren't any debut).
  • FJM1977FJM1977 Posts: 344
    The :"Huddle Room" freebie doesn't exist
  • MichaelisMichaelis Posts: 34
    Category for the NICE-LIST-FINALISTS code is empty sans one item. Edit to add: Advent calendar also broken.
    1080 x 2340 - 191K
    1080 x 2340 - 579K
    1080 x 2340 - 720K
    Post edited by Michaelis on
  • Maybe the site was in slow to changeover. I see items in both on the nice list categories and the freebies as free.
  • ElorElor Posts: 4,053
    Same problem here, the advent calendar is not displaying the two items as it did previous days:
    319 x 326 - 17K
    Post edited by Elor on
  • Nice list is working after hard refresh but advent calendar isn't.
  • jmucchiellojmucchiello Posts: 1,949
    I'm having the advent calendar issue as well. Was about to post the same image.
    Advent Calendar worked for me.
  • Advent Calendar not working for me, Freebie item doesn't exist.
  • Hurdy3DHurdy3D Posts: 1,109
    NICE-LIST-FINALISTS is not working.
    I'm Premier with one Punch and five of the qualified items in thr card.
    Did you pick the items from the correct list?
    https://www.daz3d.com/certified-nice-list
    None of them were previously on the nice list and they are all Daz Originals by Pandygirl.
  • AinmAinm Posts: 764
    Is the extra 30% off still new releases with a debut new in the cart working for anyone else? I seem to be getting punch plus base 30% off only.
  • Advent Calendar is borked AND Huddle Room does not exist.
    You can get to its page by clicking on the picture:
    https://www.daz3d.com/huddle-room
    I tested it on something from yesterday and from something as old as possible and in both cases, having a debut new (I first checked with a Zeddicuss product, then, with the tennis dress) did applied a higher discount on the Still News.
  • Phoenix1966Phoenix1966 Posts: 1,999
    Anyone get 2025-WITH-A-BANG to work?
  • Advent calendar not working !
    Could not get it to work. Tested several items from my wishlist....
    I could not get it to work despite items being from the FAS and my wishlist.
  • zombietaggerungzombietaggerung Posts: 3,937
    Oh good, I'm glad I'm not the only one who's last advent day is massively broken.
    410 x 377 - 109K
    Post edited by zombietaggerung on
  • I've reported the advent calendar. Since it's different for everyone, sounds like it works for some and not others.
  • Reported 2025-WITH-A-BANG
