• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
G9 MHX - weird toe twists with feet in high heels pose
DrGonzo62DrGonzo62 Posts: 402
December 2025 in Blender Discussion
Hi,
When I Easy Import a G9 figure with the feet in high heels position and convert it to MHX, I'm getting strange twists of the toe.fk.R (or L) bones once I hit "Snap FK all".
I don't have that issue with G8 and the feet in high heels position.
Anyone else having this issue?
Thanks!
A: Default G9 DAZ setup
B: Imported with Diffeo
C: FK controllers after import
D: After "Set FK All"
E: After "Snap FK All"
  • PadonePadone Posts: 4,171
    December 2025 edited December 2025
    I can't reproduce the issue here, tried with a heel pose by 30 degrees on foot and toes. Unless it happens only with a specific heel pose. Eventually you can upload the heel pose for us to test.
    my steps:
    1. in daz studio load G9 and make a heel pose by 30 degrees on foot and toes
    2. import in blender and convert to mhx
    3. set fk all
    4. snap fk all
    update. Oops .. I see you posted settings for the heel pose in the first picture, tried with your settings but again works fine here, unless there's specific steps. Be sure to update both diffeomorphic and the MHX runtime.
    https://diffeomorphic.blogspot.com/2025/12/diffeomorphic-add-ons-version-500.html
    433 x 202 - 12K
    Post edited by Padone on December 2025
  • DrGonzo62DrGonzo62 Posts: 402
    Thanks for checking, Padone!
    I just tried it on a different machine using only the Heeled shoe pose control and I'm getting the same result after I click "Snap FK All".
    I'm still on 4.5.1, so I'll update one of my systems to Blender 5 and see if that is indeed the issue.
    I've also added the DAZ scene I used for the import in case things go wrong for me in DAZ already.
    As always - thanks for your feedback!
    There are so many moving parts in all of this that an outside perspective is invaluable.
    592 x 229 - 26K
    591 x 421 - 22K
    duf
    duf
    DAZ Heel Pose G9 SC 01.duf
    1M
    Post edited by DrGonzo62 on December 2025
    Tried your test pose on blender 4.5.5 and 5.0, with the latest diffeomorphic version I linked above, it works fine here, no idea what may be wrong on your side. Tried with and without jcms. Again unless there's specific steps to follow to trigger the issue.
    What are your global settings and import options ?
    December 2025
    Thanks to your feedback I was able to track the issue down to my current Blender 4.5 preferences.
    A clean 5.0 install without importing preferences does not have this issue anymore.
    Thanks to you I knew where to look and getting it fixed.
    Not sure how my preferences keep getting messed up. Not too long ago I had to start over because I couldn't get the hand-dialups to import properly.
    Could be another addon causing issues I suppose.
    December 2025
    I'm assuming that you usually leave Tweak Bones off when converting to MHX?
    Because that is what was causing the issue for me. If I leave it unchecked, it's fine.
    That was a rough one...  ;^)
    866 x 487 - 68K
    From your picture I can tell you're using a old version of the addon, again please update as there's many recent fixes for mhx and rigify, you need to update both the addon and the mhx runtime. Tried here with tweak bones and works fine.
    p.s. Also it is no more necessary to keep the daz rig as mhx alone works fine to export back to daz, while rigify is more limited to import daz poses but works fine for export. In both cases the figure needs to be unlocked in daz studio to be able to import the IK features.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Setup/Rigging
    I had installed the latest Blender and Diffeo and was getting the same twist error with the toes.
    And I need the DAZ rig to apply DAZ poses onto my characters AFAIK. I don't go back to DAZ thank god.
    Oh well, I just leave that unchecked from now on.
    872 x 640 - 87K
    904 x 607 - 89K
    886 x 632 - 98K
    921 x 618 - 92K
    December 2025
    You have 4.5.0.2698, the latest is 5.0.0.2734 from the link I provided above, twice. The daz poses are always loaded directly on mhx, wether you keep the daz rig or not. To keep the daz rig was only necessary to save daz presets, before 5.0, as explained in the wiki I linked above.
    Oh, I didn't know that the DAZ rig isn't needed to import poses. Great - thanks!
    Yeah, I don't know how Diffeo 4.5 snuck in there again. However, I'm still getting that toe twist with Diffeo 5
    That's fine though. I'll just leave it off.
    Picture on the right is G8 with Tweak Bones checked and "Snap FK All".
    No FK toe twist is happening with G8.
    852 x 571 - 98K
    882 x 538 - 73K
    940 x 613 - 85K
    Ok I was finally able to trigger the issue, it's a combination of jcms and tweak bones with the G9 twist bones. As a workaround if you uncheck "keep G9 twist bones" then you can use the tweak bones. As the tooltip explains, "keep G9 twist bones" is only necessary to export back to daz, so if you work in blender you don't need it, while you may like the tweak bones to deform the mesh.
    Now reported to Thomas.
    https://bitbucket.org/Diffeomorphic/import_daz/issues/2600/
    December 2025
    Great news - thanks Padone!
    I'll leave "keep G9 twist bones" unchecked then.
    Lots of moving parts in all of this...
    December 2025
    Yes Thomas usually provides lots and lots of options. The good side is the user can customize a lot. The bad side is it may be confusing at first to understand what options to use, and it may be more difficult to make all the options work fine together at the code side.
    December 2025
    Thomas is doing a great job with it.
    The functionality of this addon has to take into account changes made to DAZ & Blender and compensate for those.
    All the while adding new functionality that isn't in either of those programs to begin with.
    Not an easy task.
    December 2025
    update. This is fixed in the last commit.
    https://bitbucket.org/Diffeomorphic/import_daz/downloads/
    December 2025
    Great!
    Thanks for bringing it up to Thomas, Padone.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
