Detraingulate Error
I keep getting this error when using the "Detraingulate" function.
I googled the error warning and got nothing on my search
To be clear, the item its selected when I apply Detraingulate
Also, I keep getting this error with any clothing item thats triangulated, its not just this particular item
Thanks in advance!
  • felisfelis Posts: 6,440
    Is the clothing made of triangulated quads?
    And what are you trying to obtain?
  • BejaymacBejaymac Posts: 1,993
    edited November 2025
    The mesh is tri poly and the OP is trying to detriangulate it into a quad poly mesh.
    In the industry that is what "detriangulate" means, joining two tri poly together to form a quad poly.
    Yet that "feature" in DS doesn't appear to do anything when you give it a tri poly mesh to work on, and yes I have tried it with several of my own ancient tri poly models and I get the same message as the OP.
    So does this "feature" work or does it do something other than what it's called.
    Post edited by Bejaymac on
    Yes, the clothing its made of tris
    What im trying to do its to quadrify the whole character, for the project that Im currently working on I need the whole character to be modelled in quads
    I just cant allow to have a character basemesh in quads, some clothing items in quads and some others in tris. Its just not professional
    I need the whole enchilada to be in quads, in short
    This error keeps happening with any item thats on tris, not just the "Gwen Shirt"
    If the warning its not readable in the screengrabs, here it is
    You must select an object in the scene with geometry consisting of triangulated quadrilaterals to perform this action
    Yes, exacly, glad to see that Im not the only one having this issue
    This function its called "Untriangulate" in Cinema 4D and "Quadrify" in Autodesk products
  • crosswindcrosswind Posts: 10,052
    Check this : http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/geometry/geometry_detriangulate/start
    Detriangulate can just reverse Triangulate operation done on a figure or object in DS without breaking UVs...  rather than remesh tris to quads, AFAIK ~
    Could the meaning be literally that the object mesh must be quads that were triangles being put back to quads as opposed to converting any set of tris to quads?
    No, the guide clearly states it requires : ....adjacent triangles (both visually and in order of facet indices) ~  For instance:
    In screenshot 1, the Cube on the left is formed by adjacent tris (sequential facet index), so it can be Detriangulated.
    In screenshot 2, I made a Cube in Blender with non-adjacent tris (Triangulated with Fixed quad method), which is on the right. It cannot be Detriangulated.
    In screenshot 3, I modified the facet index of the "problematic Cube" in DUF... to make them in order. Then it can be Detriangulated.
    If an object meets the above requirement, it can be Detriangulated successfully. (screenshot 4)
    Edit: Suggest you seek other ways of remesh / retopo if you want to keep the UVs of those garments. For instance, with Blender + Retopo Planes (search Retopo Planes on https://superhivemarket.com)
    2560 x 1392 - 484K
    2560 x 1392 - 463K
    2560 x 1392 - 392K
    2560 x 1392 - 1M
    Post edited by crosswind on
  • A slightly more dramatic example would be to create a torus, triangulate it, and detriangulate it. But in general going from an arbitrary triangular mesh to quads is not a simple algorithm.
