Genesis 3 and 8 to 9 Pose Converter (Commercial)
1…67891012»
  • mmdestinymmdestiny Posts: 198
    edited May 2025
    Is there a way to only uncheck figure limits for affected bones in the pose that exceeded them?  Having every bone get its limit turned off can be frustrating, as then when I'm making tweaks etc I can't see how close I am to the natural limit on bones that weren't previously exceeding it.
    Post edited by mmdestiny on
  • Hexdrake21Hexdrake21 Posts: 116
    Hi, are there plans for updating my favorite pose converter? I get this error in the log when trying to run it in Daz Alpha:
    Script: G:/Documents/DAZ 3D/Studio/My Daz 3D Library/scripts/genesis 3 & 8 to 9 pose converter/genesis 3 & 8 to 9 pose converter.dse
    2025-05-14 04:25:23.952 [WARNING] :: Script Error (G:/Documents/DAZ 3D/Studio/My Daz 3D Library/scripts/genesis 3 & 8 to 9 pose converter/genesis 3 & 8 to 9 pose converter.dse): Line 7865
    2025-05-14 04:25:23.952 [WARNING] :: TypeError: Cannot call method 'findSubMenu' of null
    2025-05-14 04:25:23.952 [WARNING] :: Error in script execution: G:/Documents/DAZ 3D/Studio/My Daz 3D Library/scripts/genesis 3 & 8 to 9 pose converter/genesis 3 & 8 to 9 pose converter.dsm
    S: Windows 11 Version 24H2
    Bit Architecture: 64
    DS Version: 6.25.2025.16407
    DS Edition: Pro
    DS Release Cycle: Public Build
    RKEY: 8g04fc99-c405-4dc7-90e4-d165b5a28991
    Script: G:/Documents/DAZ 3D/Studio/My Daz 3D Library/scripts/genesis 3 & 8 to 9 pose converter/Genesis 3 & 8 To 9 Pose Converter.dse
    2025-06-17 00:12:44.852 [WARNING] :: Script Error (G:/Documents/DAZ 3D/Studio/My Daz 3D Library/scripts/genesis 3 & 8 to 9 pose converter/Genesis 3 & 8 To 9 Pose Converter.dse): Line 7865
    2025-06-17 00:12:44.852 [WARNING] :: TypeError: Cannot call method 'findSubMenu' of null
    I am getting the same error.
  • i get an error occured when i try to run the script after i manually installed this product. any help ???
  • It was working well before.  I moved the main DAZ library's location drive because of getting free disk space.
    Then everything else looked fine as before except Genesis 3 and 8 to 9 Pose Converter and Genesis 9 to 3 and 8 Pose Converter.
    They do not work anymore.  Nothing happens when you execute the script from menu bar.
    I tried uninstalling and reinstalling them, and even uninstalling with deleting files physically from the drive, but shows no change.
  • wsterdanwsterdan Posts: 3,647
    edited October 2025
    Not much help to anyone else, I'm afraid, but it's working very well for me on a MacBook Pro M4 Pro using the DAZ Stuido ALPHA.
    I just finished converting 8567 poses in a single session (my Genesis 3 i3 folder). Very hapy with this product.
    Post edited by wsterdan on
  • MunemanMuneman Posts: 225
    This hasn't worked for me since I had to reinstall Windows. The Batch Pose Converter works just fine, but the Pose Converter keeps trying to call from the D drive, but I have all my content on the E Drive.
    2025-10-23 13:11:07.955 [WARNING] :: \src\sdksource\interface\actions\dzaction.cpp(2877): Could not find script file: "D:/DAZ 3D/Content/Scripts/Genesis 3 & 8 to 9 Pose Converter/Genesis 3 & 8 To 9 Pose Converter.dse"
    2025-10-23 13:11:08.945 [WARNING] :: \src\sdksource\interface\actions\dzaction.cpp(2877): Could not find script file: "D:/DAZ 3D/Content/Scripts/Genesis 3 & 8 to 9 Pose Converter/Genesis 3 & 8 To 9 Pose Converter.dse"
    I'd modify this manually myself, but I don't know where I can do that.
  • QuriosytyQuriosyty Posts: 26
    I'm having exactly the same problem as Muneman (see above). No matter how hard I try I cannot get the keyboard shortcut to recognise that my content is on E: drive and not D: drive. Any ideas?
  • I just bought this and i am having issue, I am not able to run the script at all the pc can not find it I have included a screenshot of the issue
  • Richard HaseltineRichard Haseltine Posts: 111,972
    edited May 12
    Image removed as it was showinf nudity.
    Excatly which product did you buy, and how did you install it? I suspect you have this https://www.daz3d.com/genesis-3-and-8-to-9-batch-pose-converter, which is an expansion, rather than the base product https://www.daz3d.com/genesis-3-and-8-to-9-pose-converter
  • is there any awy to get a proper response from this forum or the creator of said product I bought this two weeks ago and still can not get it to work.I have uninstalled then reinstaaled .alsochecked the folsders to see they were actually in the proper folder realised that i did not see itin the scripts foder so manual install and the same problemn persist
    1743 x 1024 - 651K
  • jmucchiellojmucchiello Posts: 2,594
    Are you using 4.24? Most PAs are not on the forums. If you are considering returning it, the window closes soon.
  • LeanaLeana Posts: 13,641
    Which product did you buy exactly, and how did you install it?
    I was able to get your account checked - what you need is https://www.daz3d.com/genesis-3-and-8-to-9-pose-converter but what you have is https://www.daz3d.com/genesis-3-and-8-to-9-batch-pose-converter - that is an extra script that can be used to convert a whole set of poses in one go, using the conversion script from the base product. If you open a Sales ssupport ticket you should be able to return the batch script and buy the base converter, if you don't need the batch feature.
  • emilynoelleemilynoelle Posts: 2
    Hi! Very interested in the product, but can only use Daz Studio 6 due to my card; will the products in the bundle work?
    Thank you!
    Thank you!
    You could convert the poses in DS 4, then use them in DS 6. It's only GPU acceleration for Iray that is blocked in DS 4 if you have a 50x0 card.
  • crosswindcrosswind Posts: 10,354
    Thank you!
    The product works well in DS 6 ~
