NVidia 5090
17891012
  • windli3356windli3356 Posts: 293
    edited May 2025
    Richard Haseltine said:
    windli3356 said:
    Darknote said:
    So I finally got the 5090 (+Ryzen 7800X3D + 64GB RAM) rig, and installed Daz Studio Public Build 2025 (6.25), and renders take from 11 minutes to 4 minutes now, to complete! Yay!
    But, I have a big issue, iRay/Texture/Filament preview is unbelievably slow. I've disabled CPU fallback in render settings (first thing I did :D ), but it still doesn't help? I've also switched in Texture Resources to Performance mode, in Preferences -> Interface. Does anyone have any idea why this is? Moving around in iRay preview mode (Or Texture/Filament mode even) is incredibly slow, but once I stop moving, it instantly renders the scene, so something is working at least...
    (I'm also on the Nvidia Studio Driver 576.02).
    Thanks for any advice!
    how did you get your RTX5090 to work? me and my friend both have RTX5090, and the render stopped for both of us as soon as we hit the render button. Are you sure your rendering task didn't fall on CPUs?
    You are trying the Daz Studio 2025 Alpha, and you do have sufficiently new drivers? https://www.daz3d.com/forums/discussion/727631/daz-studio-2025-6-25-2025-x-evergreen
     I tried searching sku # 109051  in both store and install manager, nothing pops up, is this version for Daz + users only?
    It's two colons (::) not a hash (#).
    All worked out! everything feel so much faster, thank you!
    I especially like the fact that it's a stand lone app outside of the one I'm using, So this 6.25 is what Daz 5 will look like?
    Post edited by windli3356 on
  • MarieMarie Posts: 57
    edited May 2025
    Rauko said:
    I found my 4090 was 60% faster in Iray than my 3090 which equates to saving some 36 minutes on a render that would take 1 hour on the 3090. I'd certainly take that speed up again on a 5090 - but time will tell ..
    I just had new pc 32gb of a 5090 but when I try & render with just the grphics card I am getting blck screen? any clue? I spent a fair packet for this pc & doesn't seem to be cutting it with most programmes I also have 192gb of ram? I can not understand what is happening?
  • ElorElor Posts: 3,487
    edited May 2025
    You need to use Daz Studio 2025 to render with an RTX 5000 GPU: the Iray version included in previous version of Daz Studio, including Daz Studio 4.24 are not able to use them.
    https://www.daz3d.com/blog/daz-studio-2025-alpha-release
    https://www.daz3d.com/forums/discussion/728111/daz-studio-2025-alpha-version-6-25-2025-12207-updated-may-2-2025
    Note that DS 2025 is an alpha version, and plugins made for Daz Studio 4 won't work with it and scripts are likely to not work either (scripts without UI should work).
    Post edited by Elor on
    edited May 2025
    god no I haven't a clue I thought get the best & it would work go figure with someone who like me does'nt have a clue :C
    (Edited by mod to fix the quote)
    Post edited by frank0314 on
    You have to follow these steps to access the alpha (taken from the blog post):
    How to Get the Alpha
    Try the new Alpha today via our Public Build Channel in DIM.
    Follow these steps:
    • If you haven’t already, download and install Daz Install Manager (DIM). It’s free and easy to do.
    • Open Install Manager and log in with your Daz account.
    • Click the “Download Filters” button on the “Ready to Download” tab.
    • Scroll down to the “Release Channel Tags” section and make sure the “Public Build” box is checked. If it isn’t, click it to enable the option. Then hit “Accept”.
    • Type “Daz Studio 2025” into the filter field.
    • Download and install.
  • MIH_BADMIH_BAD Posts: 68
    How are you guys doing? smiley At the moment I work with both DAZ: the old version for developing and with the new one for rendering. I have both open at the same time and of course, I need to close and open the DAZ 2025 to load new scenes.
    I was in your shoes 2 weeks ago, go download Daz alpha 6.25(only avilable on DIM) like other posters suggested, get the latest nvidia driver, and things will work on RTX5090 beautifully.  (still alot of bugs like scripts and animations don't work but it loads things much faster)
    Hey, just pushing the 5090 to the limit and I guess I need to get the other RAMs from the drawer... RAM hungry with 2 DAZ (old and new) open
    Just before opening DAZ 2025 and rendering I have 20 GB busy, so the rest 70 GB are being used by the rendering scene; I do have 12 FIGS (G8 and G9) and a big house with garden (a lot of props)
    Will update after I installed the other 96 GB RAM ...
    965 x 853 - 53K
  • Richard HaseltineRichard Haseltine Posts: 109,174
    The general advice is that to take full advantage of the memory in the GPU you want two or three tiems as much system RAM, so yees a 32 GB might well need 96GB of system RAM on its own.
  • kyoto kidkyoto kid Posts: 42,081
    ....96 GB is what my system upgrade calls for.  Can never have too much "overhead" particularly for future upgrades (like a slightly more modest  RTX Pro 4000 with 24 GB VRAM).
  • Jesus, are you guys doing stuff on the side for Pixar, heres me with my 4070 Super quite happy with render times :D
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,494
    I could use it if I had the money (both for the rig and card) those Dforce Strandbased hairs alone are resource killers
    all the newer stuff is
    ...yeah dForce hair is worse than cloth and I have two toughest ones to simulate (particularly for my 13 year old system): Primavera and  Classic Long Curly Hair
    Staying away from the dForce strand based hairs for now.
    He he - Classic Long Curly Hair is the one I bought when I first started long time ago, so I can do a test: took 1 min and 30 sec for the "Better"simulation in DAZ 4xx ... some years ago on 1080 Ti's (had 4 of them) it was super hard to do this smiley
    For the Classic Long Sleek Hair (with View SubD Level on 2) I need around 7 min on "Better" sim settings (can make and drink a coffee) -- sometimes, after the 8th min, it crashes my system: the screens turns black and mouse stops moving (no clue why). In case the sim is close to the end and I can wait, the systems restores...
    Just realized and switched the View Sub D on 1 and I get 2m 30s angel (thanks)
    952 x 675 - 637K
    ...when i got the first successful sim of Primavera Hair it took about 18 min and the pose was not as complex as the one yout attachment. I have a Maxwell Titan X (12 GB) however only 24 GB of system memory and a 2.9 GHz 6 core Xeon.
    I also use dForce Companion 2..
  • ExpozuresExpozures Posts: 261
    ArtRoulade said:
    q1472060 said:
    The test version of DAZ studio 2025 has been released. This is undoubtedly an exciting piece of news!
    I've been thinking about changing my graphics card recently, but I've been struggling to decide whether to choose the 5090 or the 5080.
    Could everyone on the forum tell me how much better the 5090 is than the 5080 in the use of Daz? Thank you very much!
    We have two results from the benchmark thread:
    NVidia GeForce RTX 5090:    1800.0 iterations, 48.027 s
    NVidia GeForce RTX 5080:    1800.0 iterations, after 01:17.385 = 77.385 s
    5090 is around 37.9% faster than a 5080
    Late to my own discussion here (lots going on IRL), but if I'm seeing that correctly, the 5080 is about on par with the 4090, just with 8GB less RAM...maybe even a touch faster.
    RAM wise...I know things are getting bigger, but when I had my 4090, I gave myself a "Vicky Challenge".  Kept loading Victoria 8 into the scene till the render became GPU fallback.  I forget how many I had, but I eventually got bored and gave up.
  • HavosHavos Posts: 5,614
    Adding new V8s (or any other figure being added again and again), will not load new textures into the GPU, only extra geometry, which takes a fraction of the space of the textures. If you had ensured all the new V8s were sub-d 5, or more, then it could well have made you run out of GPU quicker. V8s on sub-d 1 or 2 don't use a huge amount of VRAM for the geometry, so you could indeed load quite a lot of them (though I would expect Daz Studio to crash at some point if it ran out of normal memory).
    edited May 2025
    ..what about HD textures?
    Post edited by kyoto kid on
    Textures or morphs? In DS HD is almost certainly about morphs.
    ..yeah, thinkimg more of 8k textures along with HD morphs. .
    OK - big question: does anyone tested with 2x 5090 smiley  any problems?
    I need a second one, else it's too boring here ... not that I would make any money, but at least with the TOP machine of the world (for freelancers) I would be motivated to work devil
    The 5090 is working great, found no problem at all. I need to use both versions of Daz as I prepare the scene with my 3D Mouse and then render in DAZ 2025
    Loading a scene is not that bad, very fast loading and unloading times.
    Sadly I think the preformance is very close to 2x 4090 so, it might have been OK to keep those, but they would devaluate in time, so the 5090 can be sold more easily.
    Scene with 4 chracters takes up 13.5 GB, and I keep it only 2 minutes, else the difference is very very very small. Normal RAM is 3x GPU at 39 GB
    Power at 410 W (70%) and with 34% of fans spinning the temp is amazing 72 for GPU and 76 for VRAM
    I think a big plus is the smoothness of the camera incl. Perspective View ... I like this much more.
    Also, I update almost weekly the new DAZ 2025 - we get a lot of updates heart
    ...do you still have the 4090s?
    No, I sold them when the 5090 came out, so I still make some money on them ... (worst decision ever :), I'll never upgrade like that, only after 6 - 12 months after new GPU release
  • I’m trying to decide between getting an RTX 4090 at the current high price, or going for the RTX 5090 and working on DAZ Studio alpha/beta builds.
    I usually create complex scenes and rely heavily on dForce, so my question is:
    • Can I build my scenes in DAZ Studio 4.24, then export/open them in the DAZ Studio alpha/beta if I go with the 5090?
    • Will the scene stay exactly the same, or could some parts break/change when moving it to the alpha/beta version?
    Probably - ypu may need to bake any plug-in data that isn't supported in DS (e.g. Mesh Grabber modifiers baked to morphs) and there is not currently a batch render option for DS 2025 other than the Premier-only render Queue.
    It should be unchanged, though note the change log does note some work on render (which is intended to be neutral, but it is rlatively new so there may be issues)
    edited August 2025
    My opinion angel
    Yes, that's how I work for some months now and all is grreat. For very heavy scenes with a lot of items (had a huge yacht with rooms and furniture) it takes a lot of time to open, and you can only render, not even preview...  changing views (texture / universal / render) takes a lot of time (minutes)
    If you have any GPU, experience with them now, it takes a bit longer - but I am happy.
    What I use in DAZ 2025 is changing textures, turning on / off, simulations ... but if I need to turn camera and lights I prefer to do that in Daz 4 and then re-open. I also keep both DAZ open all the time.
    The only scenario that would be unusable is if you need to change libraries often, because you need to change them in both DAZs, or when you need PlugIns that are not available in DAZ 5.
    EDIT: Forgot to mention, you can work on DAZ 4 while DAZ 5 renders heart
    I strongly recommend to get a 5090 and get a thin one, maybe you'll want to add another one soon.
    Post edited by MIH_BAD on
  • Diaspora said:
    So, if we can expect a comparable iray performance boost as with what we see from his blender and maya arnold results, it would be around 40%. Maybe iray will be better because it's an Nvidia developed render engine.
    edited November 2025
    Hey Guys,
    when the DAZ 25 goes in background mode, the GPU drop to 50% power rendering. Might be even windows? Like when I open Facebook while rendering.
    Very easy to spot as the fans turn down a lot.
    1844 x 961 - 39K
    Multi GPU working as well ... 2x RTX 5090 for a total 43.520 cuda cores (can run it only 1 min due to overheating, no space in small ATX)
    1228 x 968 - 293K
