Daz Studio 2025 (6.25.2025.x) - "evergreen"
rbtwhizrbtwhiz Posts: 2,380
  • This thread is "evergreen" - the posts within it are updated frequently
  • This thread is used to provide important Daz Studio 6.25.2025.x information
  • This thread is closed for comment to avoid the information being buried in conversation
Installation
  • In Install Manager, if you filter using sku::109051, you should see a package labeled Public Build Install Modules
    • When installed, this package causes an Install Modules > Public Build... action to appear in the Settings (cog - top right) menu of Install Manager
      • Clicking the action will cause a Public Builds Install Sets dialog to appear
        • Much like the Default Install Set, this dialog provides options for a specific subset of packages to download/install - in a "playlist" like manner
        • There are Install Sets for Daz Studio 2025 (6.x) Public Build, as well as Daz Studio 4.x Public Build
Application Framework
  • Qt 6.9:
    • Execute App.aboutQt(); in the Script IDE pane of any Daz Studio build to see which version of Qt is in use
Supported Operating Systems / Architectures
  • Windows: 10 (1809 or newer), 11
    • 64-bit Intel/AMD (x86_64)
  • macOS: Monterey (12), Ventura (13), Sonoma (14), Sequoia (15)
    • 64-bit Intel (x86_64)
    • Apple Silicon (arm64) is currently supported through Rosetta emulation
      • Native support is pending
Graphics Requirements
  • Windows:
    • OpenGL 4.5 (minimum)
    • OpenGL Shading Language (GLSL) 450 (minimum)
  • macOS:
    • Metal 1.2 (minimum)
Renderers
  • NVIDIA Iray 2024.1:
    • Adds support for Blackwell (50 series) NVIDIA GPUs
    • Deprecates support for pre-Turing (pre 16/20 series) GPUs
      • Support for pre-Turing (pre 16/20 series) GPUs may vanish in one of the next major Iray version releases
      • See Release Notes
    • Requires a R570 (or newer) branch driver on Windows
  • Retired:
    • 3Delight
      • Automatic "on the fly" (at render-time) conversion of certain RSL-based materials, to their respective equivalent MDL-based materials, when NVIDIA Iray is the active engine, remains functional
        • DzDefaultMaterial
        • AoA_Subsurface
        • omUberSurface
        • omHumanSurface
        • omUberAreaLight
        • omSimpleSurface
        • Custom - uses property name matching
DrawStyles
  • Retired:
    • Cartoon Shaded
      • Superseded by Filament with FilaToon shaders applied
Daz 3D Developed Plugins
  • Pending:
    • Geometry Sculptor (Premier)
  • Questionable:
    • Decimator
  • Retired:
    • 3DConnection
    • 3Delight Renderer
    • Collada Exporter
      • *.dae format is handled by the FBX Importer/Exporter (via the FBX SDK)
    • Dynamic Clothing Basic (Optitex)
    • Dynamic Clothing Control (Optitex)
    • Mimic
    • Mimic Live!
    • Photoshop 3D Bridge
    • Render Album (not to be confused with Render Library)
    • Sandio 3D Mouse
    • Scripted 3Delight Renderer
    • Shader Baker
    • Shader Builder (not to be confused with Shader Mixer)
3rd Party Developed Plugins
(... in the standard distribution footprint)
  • Pending:
    • aniMate
File Formats
  • Retired:
    • Native serialized binary
      • *.daz - Daz Studio Scene
      • *.dso - Daz Studio Object
      • *.dsd - Daz Studio Deltas
      • *.dsv - Daz Studio Vertex Map
      • Have been deprecated since the introduction of DSON
    • Daz Script 1
      • *.ds - Daz Script 1 Ascii
      • *.dsb - Daz Script 1 Binary
        • Potentially Encrypted if file version is < 3.0
      • Has been deprecated since the introduction of Daz Script 2
      • The format itself has not been removed (yet), automatic conversion has
Post edited by rbtwhiz on
  • rbtwhizrbtwhiz Posts: 2,380
    edited April 24
    Versioning
    Technical Version:
    • The version scheme consists of 4 components:
      • The Major number
      • The Minor number
      • The Revision number
      • The Build number
      • In the following order: Major.Minor.Revision.Build
    • The Major component represents the type of changes that are likely (nearly guaranteed) to break binary compatibility and potentially break source compatibility, although efforts are typically made to maintain source compatibility where possible
    • The Minor component represents the type of changes that implement a set of new features (including bug fixes during the same timeframe), but avoid breaking backward binary compatibility or source compatibility
    • The Revision component represents the type of changes that implement new features or address bugs, but are in the process of being vetted - until they reach a point that warrants incrementing the Minor component
      • Prior to Daz Studio 2025/6.x, the value of this component was incremented to indicate progression toward a feature set and reset to 0 when the Minor component value was incremented
      • Beginning with Daz Studio 2025/6.x, the value of this component represents the Gregorian year that the build occurred
    • Prior to Daz Studio 2025/6.x, the Build component represents sequential incrementation of an automated process to differentiate one build from the next - this value was reset to 0 when any of the preceding components were incremented
      • Beginning with Daz Studio 2025/6.x, the value of this component marks the day of year and hour of day that the build occurred
        • The last 2 digits represent the UTC (24) hour of the day
        • The 1-3 preceding digits represent the Gregorian day of year
    • Given the information above, the version scheme can be understood as SDK.FeatureSet.Year.DayHour
    Marketing Version:
    • The plan/intention is for Marketing to use the Year (Revision) and the FeatureSet (Minor) components to refer to and promote this and future builds of Daz Studio
      • The desktop/start menu shortcut is labeled Daz Studio Year (64-bit) [Release Channel] [Development Phase]
        • "Year" tracks the year that the build occurred - e.g. 2025, 2026, 2027, etc
        • "[Release Channel]" tracks the name of the release channel that the build is provided through, except for General Release where it will be removed entirely
        • "[Development Phase]" is currently "+ALPHA+", but will be replaced with "+BETA+" once we are "feature complete" and then removed entirely for General Release
      • The caption (text in the title bar) for the Main Window of the application displays as Daz Studio Year (Major.Minor) [Premier Status] [Release Channel]
        • "Year" displays the year that the build occurred - e.g. 2025, 2026, 2027, etc
        • "Major" displays the SDK/Qt/ABI version - e.g., 6, 7, 8, etc
        • "Minor" displays the feature set - e.g., 25, 26, 27, etc
        • "[Premier Status]" displays "Premier" for accounts with an active subscription, but is removed entirely for accounts with an inactive subscription
        • "[Release Channel]" displays the name of the release channel that the build is provided through, except for General Release where it is removed entirely
      • The header of the splash/about screens display Studio Year [| Premier Status]
        • "[| Premier Status]" displays "| Premier" for accounts with an active subscription, but is removed entirely for accounts with an inactive subscription
      • The footer of the splash/about screens display the entire (technical) version
    edited May 12
    New Features
    (... that were not made available in a 4.20, 4.21, 4.22, 4.23, or 4.24 build)
    • DrawStyles:
      • Filament
        • Now available on macOS
      • NVIDIA Iray
        • Added a Drawing > Draw Node Wireframe property that toggles drawing of the wireframe for a mesh over the top of the rendered surface
          • Provides "like-kind" parity with the Filament DrawStyle (since 4.12.2.51)
      • Texture Shaded
        • Now draws a temporary blue surface when the images for a textured surface are still loading
          • Provides "like-kind" parity with the Filament DrawStyle (since near inception)
          • Improves loading speed, as it allows objects to be drawn before all images are loaded/resampled
      • Wire Texture Shaded
    • Render Engines:
      • NVIDIA Iray 2024.1.1 - see Release Notes
        • Support for Blackwell (50 Series) GPUs
        • Adaptive subdivision/displacement
    • View Tools:
      • Strand-Based Hair Editor
        • Now a fully integrated View Tool instead of a modal dialog
        • View multiple viewports, from different angles, concurrently
        • View different DrawStyles, per viewport
        • Work directly in the viewport
        • Quickly switch between tools
        • Hide/Show nodes
        • Dock, undock, move, resize Tool Settings
      • Universal Tool (and derivatives: Rotate, Translate, Scale)
        • Now provides a Selected Style setting in the Tool Settings pane that provides options for how visual feedback for selected nodes is drawn
          • Cues - Draws bounding box corners (same as 4.x - default)
          • Wireframe & Cues - Draws the wireframe of the geometry associated with the selected node(s), using the style highlight color, and bounding box corners
          • Halo & Cues - Draws a halo around the perimeter of the geometry associated with the selected node(s), using the style highlight color, and bounding box corners
            • Similar to the way selection is drawn for the Surface Selection tool
        • Each derivative tool (Rotate, Translate, Scale) maintains its own Selected Style setting
    • Panes:
      • Content Library
        • Now provides a Duplicate Page action in the context menu for a given container in the Container View
          • Clicking the action causes a new instance of the 'current' Manage sub-pane, labeled Manage (#) where # is the i'th instance, to be created as a sibling to the primary Manage page
        • When 2 or more sub-panes exist, a tab bar near the top of the pane is revealed
        • Pages labeled Manage (#) can be detached into custom panes
        • The primary Manage page cannot be detached or deleted
        • Closing a detached Manage (#) page causes it to reattach
        • Pages labeled Manage (#) can be deleted via a Delete action in their respective context/option menu
          • Deleting a Manage (#) page causes numbering of the pages created after it to adjust
        • Preference actions in the Options Menu apply to all Manage page instances
        • API calls apply to the 'current' Manage page instance
        • Assets in Asset Views can be dragged/dropped onto containers in Container Views on different Manage pages
      • Smart Content
        • Now provides the Compatibility Base Filter selector that is present in the primary Files and Products views, when viewing the contents of a product
        • Now provides the Filter By Context option that is present in the primary Files and Products views, when viewing the contents of a product
          • Unchecked by default
          • Checked state does not persist between sessions
        • Now provides an Add-Ons page in the Information Panel
          • Elevates functionality provided by the Explore Add-Ons... action, in the context menu of an asset, to a higher level of the UI
          • Selecting an asset on the Files page, or within a product on the Products page, populates the page with categorized assets that are compatible with the selected asset
        • Now provides a Targets page in the Information Panel
          • Elevates functionality provided by the Explore Targets... action, in the context menu of an asset, to a higher level of the UI
          • Selecting an asset on the Files page, or within a product on the Products page, populates the page with categorized assets that the selected asset is compatible with
      • Script IDE
    edited April 18
    Interface Styling
    • Qt 5 introduced a number of changes to widget styling
    • Qt 6 introduced even more changes to widget styling
    • The Qt 4 based styles (i.e., Daz Studio 4.x) have been recompiled for 2025/6.x with minimal compatibility changes so far
    • Addressing styling changes/issues will be worked on in due course
    edited April 25
    Script Engine
    • ECMAScript Version(s):
      • The script engine in Daz Studio 4.x supports ECMAScript 5.1 (aka ES5.1)
      • The script engine in Daz Studio 2025/6.x supports ECMAScript 7th Edition (aka ES7, ECMAScript 2016), and a sprinkling from more recent editions
        • Adds or re-introduces several concepts, keywords, and types
        • Constructor Properties
          • ArrayBuffer
          • BigInt (from ES11)
          • DataView
          • Promise
          • Map
          • WeakMap
          • Set
          • WeakSet
          • SharedArrayBuffer (from ES8)
          • Symbol
          • TypedArray
            • Int8Array
            • Uint8Array
            • Uint8ClampedArray
            • Int16Array
            • Uint16Array
            • Int32Array
            • Uint32Array
            • Float32Array
            • Float64Array
          • Global Variables
            • Atomics (from ES8)
            • Reflect
            • Proxy
          • Declarations
            • class (re-introduced)
            • const (re-introduced)
            • let
          • Operators
            • => (Arrow Function, aka Lambda)
            • ** (Exponentiation)
            • ... (Spread)
            • ?? (Nullish Coalescing - from ES11)
            • ?. (Optional Chaining - from ES11)
          • Control Statements
            • for...of
          • Default Parameters
          • Function Rest Parameter
          • Destructuring
          • Template Literals
          • Modules
    • Strict Mode:
      • See the MDN/W3C descriptions
      • Example:
        // Declare global strict mode
        "use strict";
        function strictFunction() {
        	// Declare local strict mode
        	"use strict";
        	// Statements within this function are executed in strict mode
        function nonStrictFunction() {
        	// Statements within this function are executed in non-strict mode
      • Can be used to help find mis-typed variable names that result in global variables
    • Scoping:
      • In Daz Studio 2025/6.x, all "normally executed" scripts are automatically wrapped in an anonymous function prior to execution
        • This preserves compatibility with the concept of a script context, whereby one or more transient values are defined under specific conditions and passed to the script as global transient variables
        • Script syntax entered into value fields that support it (e.g., numeric properties) are not considered to be "normally executed"
        • ES6 Modules are not considered to be "normally executed", rather they are imported by "normally executed" scripts
    • Hoisting:
      • ECMAScript 5.1
        • Variables are declared with the var keyword, and are function-scoped (visible throughout the function they are declared in)
          • Variables that are implicitly declared (defined without using the keyword) are global-scoped (generally frowned upon and should be avoided)
        • Variables are automatically moved to the top of their respective scopes, and initialized to undefined
        • Attempting to access a variable before it is assigned a value can lead to unexpected behavior
      • ECMAScript 7
        • Variables declared with const or let are block-scoped - (visible within the set of { and } they are declared in)
        • Variables are automatically moved to the top of their respective scope, but they are not initialized
        • Attempting to access a variable before it is assigned a value will result in a ReferenceError
      • The Qt 6 script engine will warn (not throw) if a variable declared with var is hoisted "to promote better coding practices"
        • This warning does not prevent the script from executing, but can be rather "noisy"
    • Array vs Array-Like:
      • The script engine in Qt 4 conveniently/automatically converts several array-like C++ template classes (e.g., QList<T>, QVector<T>) to/from ECMAScript Array objects in the script environment
        • Calling Array.isArray( aList ) on such a list returns true, and all Array functions/properties are available for use
        • Consequently, documentation for many function parameters and/or return values in the Daz Studio 4.5+ API indicate that they are an Array, and the types of objects contained in them is provided in their respective descriptions
      • The script engine in Qt 6 does not conveniently/automatically convert array-like C++ template classes (e.g., QList<T>, QVector<T>) that cannot be coerced into ECMAScript types to/from Array objects in the script environment
        • Calling Array.isArray( aList ) on such a list returns false, and certain functions/properties described for Array are not available
      • To help ease the transition between Daz Studio 4.x and 2025/6.x
        • Added in 4.23.1.41 :
          • DzArrayHelper::isArrayLike() ...
          • Array.from() ...
            • Native in ECMAScript 7th Edition (Qt 6 - Daz Studio 2025)
        • instanceof operator (notice the output differences when the following script is executed in the Script IDE pane of both versions)
        • Example:
          (function(){
          	var aLiteral = [ Scene.getPrimarySelection() ]; //Array<DzNode*>
          	print( aLiteral, aLiteral instanceof Array, Array.isArray( aLiteral ) );
          	var lNodes = Scene.getSelectedNodeList(); //QList<DzNode*>
          	print( lNodes, lNodes instanceof Array, Array.isArray( lNodes ) );
          	var aNodes = Array.from( lNodes ); //Array<DzNode*>
          	print( aNodes, aNodes instanceof Array, Array.isArray( aNodes ) );
    • Object vs Object-Like:
      • The script engine in Qt 4 conveniently/automatically converts object-like C++ template classes (e.g., QMap<QString,QVariant>) to/from ECMAScript Object in the script environment
        • All Object functions/properties are available for use
      • The script engine in Qt 6 does not conveniently/automatically convert object-like C++ template classes (e.g., QMap<QString,QVariant>) to/from ECMAScript Object in the script environment
        • Object functions/properties are not available
        • These types of objects most closely resemble a C++ Structure (Struct) - see the W3C description
        • Example:
          (function(){
          	let oAssetMgr = App.getAssetMgr();
          	let strctCMSOptions = oAssetMgr.getCMSOptions(); // QVariantMap - not converted to Object
          	for ( let sMember in strctCMSOptions ){
          		let vValue = strctCMSOptions[sMember];
          		print( typeof vValue, sMember, vValue );
    • Signal/Slot Connections:
      • The script engine in Qt 4 supports overloaded signals
        • The way the lookup for signals is performed when establishing a connection considers the function signature
          • Two or more signals with the same name, with different parameters, can be distinguished from one another
      • The script engine in Qt 6 does not support overloaded signals
        • The way the lookup for signals is performed when establishing a connection considers the function name, not the function signature
          • Two or more signals with the same name, with different parameters, cannot be distinguished from one another
        • To help ease transition, where there are classes in the Daz Studio 4.x API with overloaded signals, the connection mechanism in Daz Studio 2025/6.x will detect attempts to use these signatures and strip the arguments portion of the signature, leaving only the function name
          • In such a scenario, a warning is logged to alert the developer of the situation and a suggestion is made for formally addressing the ambiguity
    • Script Return Value:
      • ​In Daz Studio 4.x, the return value of a script is the value of the last statement.
      • In Daz Studio 2025/6.x, the return value of a script is undefined unless the return keyword is used.
    edited April 23
    Daz Script 2
    • Automatic Conversion:
      • Automatic conversion of Daz Script 1 (based on QSA - an ECMAScript 3.0/4.0 Proposal hybrid) to Daz Script 2 (based on ECMAScript 5.1 until 2025/6.x)
        • Daz Script 1 has been deprecated since the introduction of Daz Script 2
        • Automatic conversion was dependent on a Qt 3 support library provided with Qt 4
        • The Qt 3 support library is retired (in Qt 5), therefore automatic conversion of Daz Script 1 to Daz Script 2 is likewise retired
        • Some concepts/keywords found in Daz Script 1 scripts, such as class and const, are reconstituted in Daz Script 2 as of Daz Studio 2025/6.x (ECMAScript 7th Edition)
    • Deprecated APIs:
      • Usage of deprecated Daz Studio 4.x objects, functions, and properties report themselves to the log when encountered by Daz Studio 2025/6.x
        • This helps developers identify where these objects, functions, and properties are used so that they can update their code to use non-deprecated APIs in order to provide the widest range of compatibility (backward and forward)
        • Many of the deprecated Daz Studio 4.x objects, functions, and properties are annotated in the Object Index, and individual object pages
    • Missing APIs:
      • Migration of DzProcess from 4.x is pending (i.e., currently not available)
        • The QProcess API has changed significantly since the Daz Script wrapper for it, which is based on the Qt 3 API, was implemented
    • Object Lifetime:
    • Modular Code:
      • Global::include()
        • Deprecated due to behavioral changes caused by engine differences
          • An includee (inner) script no longer has visibility of variables in the scope of the includer (outer) script
        • Superseded by ES6 Modules
    edited May 13
    New Noteworthy Script APIs
    • Application Restart:
      • Simple example
        (function(){
        	let aCommandLineArgs = [
        		"absolute/path/of/a/file/to/open.ext"
        	let nExitCode = 0;
        	App.restartOnClose( true, { "arguments": aCommandLineArgs } );
        	App.delayedExit( nExitCode );
      • If you execute the script above in the Script IDE pane, you will be asked if you want to save the script (if you did not save already), the application will close and then relaunch, and the path specified in aCommandLineArgs will be passed in as though you had double clicked it to launch the app
        • Replace absolute/path/of/a/file/to/open.ext with the path of an actual file you would like the application to open, otherwise you will see a message indicating that the file could not be found
      • The aCommandLineArgs Array can consist of any combination of the options described in Command Line Options (version specific public documentation will eventually exist in its own parallel "6" namespace), in their respective appropriate order
      • By default, the instance name of the running application will be used for the relaunched application
    • Temporary Prompt Suppression:
      • Simple example
        (function(){
        	let oHandler = new DzScriptPromptSuppressionHandler();
        	oHandler.handleFunction = function( wDialog ){
        		try
        			if( wDialog.inherits( "QMessageBox" ) ){
        				let oWidget = new DzWidget( wDialog );
        				//let wButton = oWidget.findChildOfWidget( "Button0" ); // Yes
        				let oButton = oWidget.findChildOfWidget( "Button1" ); // No
        				//let oButton = oWidget.findChildOfWidget( "Button2" ); // Cancel
        				if( oButton ){
        					oButton.click();
        			} else if( wDialog.inherits( "DzBasicDialog" ) ){
        				//wDialog.done( 0 ); // Reject
        				wDialog.done( 1 ); // Accept
        			} else if( wDialog.inherits( "QDialog" ) ){
        				//wDialog.done( 1 ); // Accept
        			} else {
        				print( wDialog );
        		catch( e )
        			print( e );
        		return true;
        	startPromptSuppression( oHandler );
        	print( "MessageBox", MessageBox.question( "Message", "Title", "Yes", "No", "Cancel" ) );
        	let wDlg = new DzBasicDialog();
        	print( "DzBasicDialog", wDlg.exec() );
        	wDlg = new DzDialog();
        	print( "DzDialog", wDlg.exec() );
        	print( "askSaveChanges", MainWindow.askSaveChanges() );
        	endPromptSuppression();
      • If you execute the script above in the Script IDE pane, you will see a series of dialogs pop up and then immediately hide without having to click on them
      • The DzScriptPromptSuppressionHandler object provides a handleFunction member that holds a function to be called by the framework when the dialog/messagebox is in the process of being shown
        • If the type of dialog can be detected, the dialog (or the buttons on it) is manipulated to provide a discrete answer and close
      • The output console at the bottom of the Script IDE pane provides feedback indicating how the dialog was handled - whether it was accepted/rejected, or which button (and therefore which answer) was chosen
    edited April 22
    Script IDE Pane
    • Syntax Highlighting:
      • Updated to reflect the ECMAScript editions supported by the script engine supplied by Qt 6 - see Script Engine
        • ECMAScript 7th Edition
        • ECMAScript 8th Edition - Partial
        • ECMAScript 11th Edition - Partial
    • Debugger:
      • The debugger provided by Qt 4 is not present in Qt 6 (or Qt 5 before it), therefore debugging functionality that exists in Daz Studio 4.x is not available in Daz Studio 2025/6.x
    • Drag-n-Drop:
      • Dragging script files from an OS file browser and dropping them on the tabbar immediately above the document area will open the scripts as though the File > Open... action were used
      • Dragging files from an OS file browser and dropping them onto the body of an unencrypted script presents a contextual menu with options for what to do
        • Open (as though the drop occured on the tabbar immediately above the document area)
          • If all dropped files are scripts
        • Insert URL String Literal ("file:///path/to/some/file.ext")
        • Insert Path String Literal ("path/to/some/file.ext")
      • Dragging folders from an OS file browser and dropping them onto the body of an unencrypted script presents a contextual menu with options for what to do
        • Insert URL String Literal ("file:///path/to/some/folder")
        • Insert Path String Literal ("path/to/some/folder")
      • Dragging script files from an OS file browser and dropping them onto the body of an encrypted script will open the scripts as though the File > Open... action were used
      • Dragging a pane from a pane group in the UI and dropping it onto the body of an unencrypted script presents a contextual menu with options for what to do
        • Undock "<pane_label>" Pane
        • Insert Classname String Literal ("DzPane")
