[Released] Bone Minion for Genesis 8 and 8.1 Poses [Commercial]
13
  • hjakehjake Posts: 1,341
    edited February 2025
    carrie58 said:
    hjake said:
    carrie58 said:
    hjake said:
    I have read through the bone minion threads and watched the videos but I have not seen a specific reference to my question.
    1. If I use bone minion to "on-the-fly" use a G8F pose on a G2F figure, and make fine adjustments to the pose on G2F, will I then be able to save my masterpiece of pose conversion as a pose preset for G2F?
    2. Do I need to delete the G8F bone minion prior to saving so only my adjusted pose is saved?
    3. If I create a new scene, load a G2F figure, and apply my saved preset, will it apply exactly as I saved it?
    I believe  it should work ,use the G8F Minion apply the pose to G2F  ,delete the Bone Minion ,then make your adjustments ,then save your new pose for G2F .......
    So the difference from what i asked is first delete minion donor THEN make personal adjustments then save pose preset (excluding Translate). Could someone please confrim they have saved as a pose preset. I did read in one posting saving as a scene or scene subset but that is different from a pose preset.
    I said I believe it should work , because tthis is the way I save  transferred adjusted poses on G3 from G8 or G9 from G8 if I think they are special enough to save ,
    Thank for your follow-up. I just want to be clear before I spend money and a coupon buying 6 of these products. I know there is a return policy, but I would like to avoid that for my sake and the sake of the PA.
    You used a bone minion product to do those transfers and saved them as a standard DS pose preset (if they were special enough) and later when you used them on a new figure in a new scene they maintained all the changes you  made with bone minion and your personal adjustments.
    Post edited by hjake on
  • carrie58carrie58 Posts: 4,175
    Yup I used the Bone minion to use other generations poses to the generation I am using ,then when I find a pose that I like , I delete the bone minion ,make any adjustments that I want , then sometimes I use "bake to transforms" if I've used any pose controls for my adjustments ,then save as a Pose preset . I have all of the Bone Minions and love the fact that I can use ALL of the poses I have .
    Carrie58 - Thank you very much for your reply. Don't forget to contact RiverSoft Art for your commission on the sale. smiley
    Yes, it will work.  Once a pose is on the target figure, there is nothing special about it.  You *may* have to turn off limits on the figure when you apply the pose preset later though.
    Thank you. It might seem obvious to some people, but I find explicit is better than implicit. As for the limits thank you for the reminder about turning them off. I did read that in several places of the threads and you mention it in your demo video. I think it was emphasized for V4/M4 because they have more restricted limits than the Genesis figures, but overall a good practice before any pose conversion.
    I picked up 4 Bone Minions and Hat Check for G8. So that makes 90 of your 245 products listed in the store. smiley
    You are very welcome !! and I am not sponsored by RiverSoftArt in any way laugh,I just really love the Bone Minions ,oh and he is right don't forget to use the "Turn Off Limits" that's included for all the generations ,otherwise you can get little weird funkiness ,like fingers that bend sideways .....
    You're welcome!  And thank YOU for your support! smiley
    Yes, thank you @Carrie58!  But you forgot the subliminal "his products are the best in the world" quote somewhere in your reply.  I can only give you half as much as usual laugh
    laughlaughheart
  • xyer0xyer0 Posts: 6,516
    Hi! I recently restarted using G2F (Stephanie 6) thanks to a thread in the Commons, and during two different sessions I ran into a problem using Bone Minion for Genesis 8 Female on Stephanie 6: It didn't work. I loaded Bone Minion, turned off limits on Stephanie 6, selected Bone Minion, applied the G8F pose, and Bone Minion moved, but Stephanie 6 didn't.
    In both cases, I then loaded the Generation 4 Bone Minion (V4), applied a pose to it, and Stephanie 6 assumed the pose. So, there was no glitch in principle, only specific to two different G8F poses for two different scenes. Has anyone heard of a similar issue?
  • RiverSoft ArtRiverSoft Art Posts: 6,975
    It could have been it didn't touch the hip bone. Did you then execute the Bone Minion - Apply Changes script?
    No, sir, I didn't. I will retry and implement your suggestions. Thank you for responding.
    You're welcome!
  • inquireinquire Posts: 2,464
    I'm running DAZ studio 4.24.0.3 in Rosetta 2 on a Mac studio with Sequoia 15.5 as the main OS. If I try to apply a bone minion script onto a character, Daz studio quits. Is anyone else having this issue with this version of studio, running in Rosetta 2 with the main OS being sequoia 15.5?
    More importantly, can anyone confirm that bone minion works on that type of setup?
  • memcneil70memcneil70 Posts: 6,137
    @RiversoftArt
    I opened on my MacMiniM4 Pro with Sequoia 15.5, 64GB, and I opened D|S 4.24.0.3 loaded G9 Base. Found a G8M pose, then from the Bone Menu in Favorites Selected G8Ms Minion to be added to G9 and it was successful. Selected the Bone Minion in the Scene pane, and clicked on the G8M pose, the minion moved into position and D|S crashed a second later. Here is the bit of the log file where the Bone Minion started to crash:
    2025-07-25 04:20:47.808 [DEBUG] :: Bone Minion START
    2025-07-25 04:20:47.808 [DEBUG] ::       Bone Minion is Genesis8Male Genesis 8 Male Bone Minion
    2025-07-25 04:20:47.808 [DEBUG] ::       Figure is Genesis9
    2025-07-25 04:20:47.824 [DEBUG] :: FOUND: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/data/RiverSoft Art/Common/Pose Converters/RSG8MPoseConversionConstants.dsa
    2025-07-25 04:20:47.915 [DEBUG] :: 0 Genesis 8 Male Bone Minion Genesis 9
    2025-07-25 04:20:47.916 [DEBUG] ::       Clearing Connections
    2025-07-25 04:20:47.929 [DEBUG] :: FOUND: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/data/RiverSoft Art/Common/Pose Converters/RSG8MToG9PoseConversion.dse
    2025-07-25 04:20:47.929 [DEBUG] ::       Loading pose conversion file /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/data/RiverSoft Art/Common/Pose Converters/RSG8MToG9PoseConversion.dse
    2025-07-25 04:20:48.004 [DEBUG] ::       Copying pose to parent
    2025-07-25 04:20:49.134 [DEBUG] ::       Zeroing Unlocked Bones on Bone Minion
    2025-07-25 04:20:49.883 [DEBUG] ::       Zeroing Pose Properties
    2025-07-25 04:20:49.884 [DEBUG] :: BuildBodyPartBones Genesis8Male Figure true
    2025-07-25 04:20:49.885 [DEBUG] :: InitBodyParts2021 [object Object] 8
    2025-07-25 04:20:49.885 [DEBUG] :: Body Part Information:
    2025-07-25 04:20:49.886 [DEBUG] ::   bones:
    2025-07-25 04:20:49.886 [DEBUG] ::     0: "21"
    2025-07-25 04:20:49.887 [DEBUG] ::   breakBones:
    2025-07-25 04:20:49.887 [DEBUG] ::     0: "0"
    2025-07-25 04:20:49.887 [DEBUG] ::   recursive: "true"
    2025-07-25 04:20:49.888 [DEBUG] ::   startWithChildren: "false"
    2025-07-25 04:20:49.888 [DEBUG] ::   breakWithChildren: "true"
    2025-07-25 04:20:49.890 [DEBUG] :: Break Bones: upperTeeth,lowerJaw,upperFaceRig,lEye,rEye,lEar,rEar
    2025-07-25 04:20:49.907 [DEBUG] :: END BuildBodyPartBones 93 [object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
    2025-07-25 04:20:49.907 [DEBUG] :: Zero Bone Properties Genesis8Male 93
    2025-07-25 04:20:49.909 [DEBUG] :: Bone Minion END
    2025-07-25 04:20:49.910 [DEBUG] :: FOUND: /Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/data/RiverSoft Art/Common/Bone Minion.dse
    2025-07-25 04:20:49.911 [DEBUG] :: Genesis 8 Male Bone Minion Creating callback "/Volumes/Spawns Work/Users/Mary/My DAZ 3D Content/data/RiverSoft Art/Common/Bone Minion.dse - On Bones Change"
    2025-07-25 04:20:49.940 [INFO] :: Loaded morph deltas: 0m 0.20s - /data/Daz 3D/Genesis 9/Base/Morphs/PedroFurtadoArts/The Age/PFA THE Age Baby Right Forearm Bending Up Corrective.dsf
    2025-07-25 04:20:49.948 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/Daz 3D/Genesis 9/Base/Morphs/PedroFurtadoArts/The Age/PFA THE Age Baby Right Forearm Bending Up Corrective 2.dsf
    2025-07-25 04:20:49.953 [INFO] :: Loaded morph deltas: 0m 0.4s - /data/Daz 3D/Genesis 9/Base/Morphs/PedroFurtadoArts/The Age/PFA THE Age Baby Left Forearm Bending Up Corrective.dsf
    2025-07-25 04:20:49.962 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/Daz 3D/Genesis 9/Base/Morphs/PedroFurtadoArts/The Age/PFA THE Age Baby Left Forearm Bending Up Corrective 2.dsf
    2025-07-25 04:20:49.970 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/Daz 3D/Genesis 9/Base/Morphs/vyktohria/Boragia/VYKBoragia_body_cbs_upperarm_y110n_l.dsf
    2025-07-25 04:20:49.976 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/Daz 3D/Genesis 9/Base/Morphs/vyktohria/Boragia/VYKBoragia_body_cbs_thigh_z90p_l.dsf
    2025-07-25 04:20:49.981 [INFO] :: Loaded morph deltas: 0m 0.5s - /data/Daz 3D/Genesis 9/Base/Morphs/vyktohria/Boragia/VYKBoragia_body_cbs_upperarm_y110n_r.dsf
    2025-07-25 04:20:49.993 [INFO] :: Loaded morph deltas: 0m 0.10s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index2_z105p_r.dsf
    2025-07-25 04:20:49.995 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky2_z105n_l.dsf
    2025-07-25 04:20:50.004 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_z40n_l.dsf
    2025-07-25 04:20:50.008 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_foot_x65p_l.dsf
    2025-07-25 04:20:50.009 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_hand_z70p_r.dsf
    2025-07-25 04:20:50.010 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid1_z95n_l.dsf
    2025-07-25 04:20:50.011 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid2_z105n_l.dsf
    2025-07-25 04:20:50.012 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index3_z90n_l.dsf
    2025-07-25 04:20:50.013 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_y110p_z40p_r.dsf
    2025-07-25 04:20:50.014 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thigh_x35p_r.dsf
    2025-07-25 04:20:50.015 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid3_z90p_r.dsf
    2025-07-25 04:20:50.016 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky3_z90p_r.dsf
    2025-07-25 04:20:50.017 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_x95n_r.dsf
    2025-07-25 04:20:50.018 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring2_z105n_l.dsf
    2025-07-25 04:20:50.018 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thumb3_y90p_l.dsf
    2025-07-25 04:20:50.019 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky1_z95n_l.dsf
    2025-07-25 04:20:50.021 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_shoulder_x30n_r.dsf
    2025-07-25 04:20:50.022 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_head_x30n.dsf
    2025-07-25 04:20:50.023 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring3_z90n_l.dsf
    2025-07-25 04:20:50.024 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_y110p_r.dsf
    2025-07-25 04:20:50.025 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thumb1_y40n_r.dsf
    2025-07-25 04:20:50.025 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index1_z90n_l.dsf
    2025-07-25 04:20:50.026 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring1_z95p_r.dsf
    2025-07-25 04:20:50.027 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thumb1_z20n_r.dsf
    2025-07-25 04:20:50.029 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_spine2_x40p.dsf
    2025-07-25 04:20:50.030 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_toes_x40p_r.dsf
    2025-07-25 04:20:50.034 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_forearm_y75n_l.dsf
    2025-07-25 04:20:50.034 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid1_z95p_r.dsf
    2025-07-25 04:20:50.035 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_hand_z70n_l.dsf
    2025-07-25 04:20:50.037 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_x95n_l.dsf
    2025-07-25 04:20:50.038 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid3_z90n_l.dsf
    2025-07-25 04:20:50.038 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index3_z90p_r.dsf
    2025-07-25 04:20:50.039 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_y110n_z40n_l.dsf
    2025-07-25 04:20:50.040 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_mid2_z105p_r.dsf
    2025-07-25 04:20:50.041 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_shin_x90p_l.dsf
    2025-07-25 04:20:50.042 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_foot_z45n_l.dsf
    2025-07-25 04:20:50.043 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_spine3_x35p.dsf
    2025-07-25 04:20:50.045 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_spine3_z20p_r.dsf
    2025-07-25 04:20:50.046 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_hand_y28n_l.dsf
    2025-07-25 04:20:50.047 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_shoulder_z55n_r.dsf
    2025-07-25 04:20:50.048 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_toes_x60n_l.dsf
    2025-07-25 04:20:50.049 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_z40p_r.dsf
    2025-07-25 04:20:50.050 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky2_z105p_r.dsf
    2025-07-25 04:20:50.051 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_neck1_y22p_l.dsf
    2025-07-25 04:20:50.051 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thumb2_y65p_l.dsf
    2025-07-25 04:20:50.061 [INFO] :: Loaded morph deltas: 0m 0.10s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index2_z105n_l.dsf
    2025-07-25 04:20:50.063 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_spine2_z24n_l.dsf
    2025-07-25 04:20:50.064 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thumb1_y40p_l.dsf
    2025-07-25 04:20:50.065 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_upperarm_y110n_l.dsf
    2025-07-25 04:20:50.066 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring3_z90p_r.dsf
    2025-07-25 04:20:50.067 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_forearm_y75p_r.dsf
    2025-07-25 04:20:50.068 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring1_z95n_l.dsf
    2025-07-25 04:20:50.068 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_index1_z90p_r.dsf
    2025-07-25 04:20:50.069 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_foot_x65p_r.dsf
    2025-07-25 04:20:50.071 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_spine1_z15n_l.dsf
    2025-07-25 04:20:50.071 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky3_z90n_l.dsf
    2025-07-25 04:20:50.073 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_shoulder_x30p_l.dsf
    2025-07-25 04:20:50.073 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_pinky1_z95p_r.dsf
    2025-07-25 04:20:50.075 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thigh_z90p_l.dsf
    2025-07-25 04:20:50.076 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_neck1_z40n_l.dsf
    2025-07-25 04:20:50.077 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_neck1_x40p.dsf
    2025-07-25 04:20:50.078 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_thigh_x35p_l.dsf
    2025-07-25 04:20:50.079 [INFO] :: Loaded morph deltas: 0m 0.0s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/Base Correctives/body_cbs_ring2_z105p_r.dsf
    2025-07-25 04:20:50.285 [INFO] :: Loaded morph deltas: 0m 0.22s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/FACS/facs_bs_EyeLookUpLeft.dsf
    2025-07-25 04:20:50.293 [INFO] :: Loaded morph deltas: 0m 0.3s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/FACS/facs_bs_EyeLookInLeft.dsf
    2025-07-25 04:20:50.298 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 9/Base/Morphs/Daz 3D/FACS/facs_bs_EyeLookUpRight.dsf
    2025-07-25 04:26:56.647 +++++++++++++++ Daz Studio 4.24.0.3 starting +++++++++++++++++
    edited July 2025
    I haven't closed the crash report that was generated by Apple. If I copy it and send it to you, will it help?
    Went ahead and attached it.
    txt
    txt
    Apple Crash Report 2025_07_25 Bone Minion.txt
    180K
    Post edited by memcneil70 on
    Unfortunately, the crash report doesn't help me. So you too have issues on the Mac. I wonder does it not work on any Mac or this configuration?
    edited July 2025
    Okay, back at my computers. On my MacBook Pro M2, 16GB, on D|S 4.24.0.3 I had to reinstall my scripts that had been stripped off of Favorites (again). I opened the manual also. I also made sure my preferences in D|S are to set to 'Always turn limits off'. I loaded G9 Base but I used the script in Bone Minion to double-check limit were off too. Applied the Minion for G8M and the selected the minion in Scene tab, and clicked on my pose for G8M. Minion moved. I then watched and G9B moved into that pose. No crash.
    I opened the MacMiniM4 and had to reinstall the scripts onto favorites again. Loaded G9 Base, used the Bone Minion script to turn off limits, then selected the G8M Bone Minion and applied it to G9B. Selected the Minion and applied a G8M pose and watched as the minion moved into a pose, and then G9B moved into the pose.
    I have highlighted the key thing I did not do in the first test. @inquire, look at the steps I did and see if you are doing the same. Also, did you install the Bone Minion scripts into your Favorites? My biggest error is always using my left button on the mouse. You need to use the right button on the mouse for the .dsa action. Doesn't matter what script by any PA I will crash. I always forget this. Smack my head and then try again. With Macs we get to reinstall our scripts a lot unfortunately. Not the PAs' fault, it is DAZ and they are working on it in the Alpha.
    Mary
    P.S. Your stocking stuffer to load characters is such a life saver for me. I send you thanks every day for them.
    I actually put the script into the scripts menu. I just pulled down to the bone minion that I want and click to apply that to the character. Should I delete the scripts from the script menu and just have them in the favorites menu?
    Also, I want to apply the bone minion to one or more of my characters, not to the G9 base. That wouldn't help me much.
    @memcneil70: you've really helped me a great deal with your comments. I loaded just the base Genesis 9 figure, turned off limits, And DAZ did not crash. I applied the poses I wanted to the bone minion, and saved each pose. Then I loaded in, in another file, the characters I wished to work with, and applied the saved poses to them. That works! Of course, it's not the same thing as just readily applying A Pose. Now there's a folder of new poses.
    Other than this issue with the Scripts, DS4 does seem to be working pretty well.
    Do the scripts work at all in the alpha version of DS?
    That I would hesitate to answer. The PAs are dealing with moving from QT4 to QT6 and right now Alpha is not yet settled into place. If you read the Alpha thread you will see some of the discussions. V3Ditigtimes' Commercial threads are also addressing this too. As is Code66/Totte. I have installed simple Code66 scripts to favorites, but they do not work. But I am testing to see if they will stay in favorites from one version to another. What you can do in the Alpha now is work in Filament/Filatoon. But plugins and scripts use, you need DS 4.24.0.3. So plan to use both versions by saving your scene file and open and close in the version that has the tools you need. If you had a Windows computer with an RTX 5xxx card, the Alpha would be your only choice. (I really recommend reading the Alpha thread, I am not a programmer and do not have a technical understanding of all the issues, but I do understand that upgrading programs/computers does give fits to everyone involved. I can be patient.)
    But we should take further discussion back to the Mac thread so we don't hijack the Bone Minion thread.
    Mary
    Mary
    Thank you Mary! That is fantastic you were able to work through that.
    Daz Studio 2025 is a nightmare for me. Some basic things changed that I always used and I am spending a lot of time trying to figure out what to do.
    What you just quoted is what Mary did with DS4.24.0.3. I don't think the scripts will work at all in DS 2025.
    I https://www.daz3d.com/forums/discussion/728111/daz-studio-2025-alpha-version-6-25-2025-19807-updated-july-17-2025/p4
    in the alpha version of DS, page 4, One of the posters says that neither bone minion nor prop minion work in DS 2025. But I don't think it's just these two products. I think this is pretty much the case for scripts at present in the alpha DS 2025.
    So I'm pretty much sure that what Mary Posted about getting bone minion to work was in DS4.24.0.3. I got bone minion to work there by following her procedures, loading just a base G9, making sure that limits were turned off, and then applying the bone minion. After that, I applied a series of poses I wanted, saved each pose, and then close that file.
    At that point, I had a folder of G9 poses. I applied a pose to a G9 Character in a new file, and touched it up, and then resaved it so that it was what I really wanted.
    She also talked about DS2025 in the next post. I was replying to both. The bone minions do not work in DS 2025. Most of my scripts don't. I am working to port them but it is taking months.
    I'm sorry. I thought you had figured that Mary's procedure was done in the alpha version. I do apologize.
    No problem at all.
    I uninstalled and then reinstalled DS4.24.0.3 to see if I could get the bone minion products to apply without as studio crashing. I can now get them to apply, but when I try to apply a pose to the bone minion, I get a dialogue box saying that the "conversion constants" cannot be found. Please see the first file.
    When I search for these, I do find them on the hard drive within Daz studio in the data folder. Please see the second file. The third file shows the conversion files and again their location.
    But I don't understand what to do now. Do I have to uninstall all of the bone minion products and then reinstall them?
    824 x 332 - 127K
    2342 x 1640 - 621K
    2326 x 1744 - 783K
    I could not see from the second or third image that RSG9PoseConversionConstants.dsa was in the data/RiverSoft Art/Common/Pose Converters but since a lot of them were, I am going to assume it is in there. The real question, is that directory listed in the Daz Studio Formats section of the Content Directory Manager? DS concatenates that data/RiverSoft Art/Common/Pose Converters with the root directories specified in the Content Directory Manager. Here is my Content Directory Manager:
    So Daz expects to find the files in D:/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/Pose Converters or D:/Documents/My DAZ 3D Library/data/RiverSoft Art/Common/Pose Converters. Does it contain your root directory?
