The "Animators Assemble!" thread for Daz animation WIPs, clips, and tips
1…2829313334…39
  • CoXComicsCoXComics Posts: 102
    It would be time consuming.
    I'd remove any object intended to move and render the static background with the spherical camera. That would be the base layer for the animation and the dome. After that render each moving object as a layer with the dome invisible and stack them into a video editor for the final render and spatial injection. The hardest part for me would be timing the vehicle wheels to turn at a rate that matches the vehicle movement. Some of the layers could be looped to make the main loop start and finish less obvious.
    Turning wheels to match movement is always difficult for me.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,633
    I used to do 360 videos
    https://www.youtube.com/watch?v=TUi6tBcmD7A&list=PL403UZF5-5dIRzfe0i4NVT-GyicTfVvpE
    but without a VR viewer they get boring fast and more importantly take way too much drive space
  • FirstBastionFirstBastion Posts: 8,076
    The technology for full 360 degree ability on every frame of the video is mindblowing.  I don't doubt these are really big data files.
  • GordigGordig Posts: 10,809
    Dartanbeck said:
    The tough part, I think, would be having all of the people and non-parked vehicles perpetually in a looping motion
    Houdini could spawn an infinite number of agents at a regular or even random interval so that you don't even need to worry about looping.
    Perhaps. The looping part is because it needs to become rendered out into a final viewable file
    Enter the Four-Wheeler Animation Template System!!!
    All of these would be rendered using the same camera:
    • Outer Layer 360 background image - Very distant background
    • Inner set of buildings - no backdrop (Alpha) with Iray Floor On (for shadows of buildings
    • Set of vehicles placed around the scene - all pointing the same direction, but at different distances from the camera - no backdrop (Alpha) with Iray Floor On (for shadows of buildings
    • Repeat but different vehicles pointing the opposite direction - no backdrop (Alpha) with Iray Floor On (for shadows of buildings
    • Loitering people who don't actually travel the scene, but are set to a short loop for less frames of render - keep them distant for faster rendering - no backdrop (Alpha) with Iray Floor On (for shadows of buildings
    • A fog layer that can be set at various places within the stack in the final edit and various strengths - to mimic depth
    The only layer mentioned above that really needs more than one frame would be the people. In post add a radial blur to the vehicle wheels and let a fog leyer help simulate the idea of movement. Make the entire final output enough frame to rotate the vehicle passes far enough around behind the inner buildings to look convincing. Loop the people into all of it - placed in areas where they can simply blend into the background.
    Just food for thought on how I'd initiate my own appoach to this idea
    Possibly also another set of buildings - a mid layer that goes behind the inner and in front of the distant background.
    Although I would render my fog layer at full opacity, I'd mix it into many layers very weak each time, rotating them differently to help sell the idea of a living world
    How do you figure? It doesn't need to loop to be renderable.
    edited January 2025
    The files can eat some space depending on resolution. Rendering the entire scene frame by frame ends up giving ~50meg or so individual images at the resolution I start with, 7680x4320. I noticed that the first few videos in your list were done in 2008 and drive space was certainly at a higher premium. It's a little easier now. Once production is done, I dump the whole thing onto an 8TB external drive.
    Edit: I see the later videos were just last year. The Troll Cave video looked great in VR.
    Post edited by CoXComics on
    Pretty much the same approach I outlined. Anything that moves has to have its own layer and the same lighting. The default loadout of Xi's Steampunk City street is only wide enough for vehicles to pass in one direction. As the scene stands, there are 5 figures meant to be idling and three to move. Of course all the idea spawning is making me less interested in my current project and want to go play with this. Wheel template kit put in the wish list.
    CoXC
    I didn't even have a PC in 2008 cheeky
    edited January 2025
    WendyLuvsCatz said:
    CoXC
    It shows this: "Streets of Asia Stonemason DAZ 3D set 360 VR madcatlady 35.5K subscribers Subscribe Like Share Download 2.6K views 8 years ago". My dyslexia transposed the 8 yeares ago to 2008. Doh!
    AI - Assited Keyframe Animation Enters Daz Studio!
    Enter a world where we can sculpt our own animations for Daz Studio as easily as deciding on the next outfit our characters should wear, or which new hair they should have.
    The amazing developers at Cascadeur are constantly improving software that was really, Really great for this for quite some time already - but it just keeps getting better!
    I'm starting off 2025 with a subscription to the Pro tier plan of Cascadeur to really dig into this amazing endeavor.
    edited January 2025
    I really do render a lot of [sily stuff] wink so don't share here often
    (it would be awfully spammy if I did given the utter volume cheeky)
    But, I bought that Xi Steampunk scene too yesterday and had to plonk it into Twinmotion and see how it looked
    edit, forgot to add a person or people to the car before I saved it to the User Library in order to add to a motion path so that's why it's empty, was too lazy to do it again for the umpteenth time after editing (adding rotators, tweeking materials etc)
    That's awesome Wendy!!!  I Love It!!!   heart
    edited January 2025
    oh BTW not only does Twinmotion render 360 videos (but not on my PC without a huge struggle the earlier versions without Lumen etc worked OK but meh shading)
    but
    You can use it in VR mode apparently working and export VR presentations, just something CoXComics might be intersted in
    not sure if still free though, might be, look on Epic Games
    edit, if you are poorer like me and most people not millionaires yes
    Twinmotion is free for students, educators, hobbyists, and companies earning under $1 million USD in annual gross revenue. Above that threshold? Find out about pricing or get a free 30-day trial today.
    oh and thanks Dartanbeckheart
  • TugpsxTugpsx Posts: 921
    edited January 2025
    Good job @Wendy, lots of activities happending in the environment. I'd use some movie magic and change to a blue light to represent night scenes so that more information is presented. Some of the scenes were a bit dark.
    Great job anyway thanks for sharing.
    Post edited by Tugpsx on
    Awesome work Dan, these workflows make animating in Daz much easier when you can get realistic ani-motions via a combined mocap and hand posed. keep up the great work and looking forward to more Cascadeur tips and tricks.
    Hey man! Thanks!!! I really appreciate that!
    More coming soon... I hope! :D
  • I heard about Twinmotion a couple of years ago, but my previous rig didn't stand a chance of running it so I forgot all about it.
    It's still available for free under Epic so long as you are below their income caps. It's installed, but it looks like I might be facing a steep learning curve based on poking around at it.
    Thanks for bringing the program up.
    but
  • I've been ill recently so projects didnt get much attention. I did render a quick version meeting 360 requirements for the Oculus and was able to stand within it. I'm not sure it does anything for me other than "Gee whiz, neat-o"...
    Gee Whiz! Neato!!!
  • MouserMouser Posts: 775
    I hope this is the right place for this question, apologies if it is not.
    I have a number of animations & aniblocks that are what I need but I need to mirror them (character only I hope this all makes sence).
    The only method I know of is editing a pose via symmetry but can this be done for animations & aniblocks?
    I do have the item:
    Daz Studio 4 Scene Tools Set 3 - Pose Symmetry
    But it never worked.
    Q: is this possible and what are the options if yes?
    Thanks
    I do have the item:
    Thanks
    You would need to bake the AniBlock to keyframes first, which requires the full Animate 2 (rather than AniMate Lite) as far as I know.
    edited February 2025
    Better idea:
    With the aniBlocks active in aniMate 2 (before Baking to Timeline):
    • Click on the aniBlock to Select it
    • Click the Mirror aniBlock Button
    Many more tips and tricks for using aniMate 2 Here
    1408 x 1001 - 116K
    1408 x 1005 - 117K
    Post edited by Dartanbeck on
    I do have the item:
    Thanks
    Yes I have Animate 2 and how to change from aniblocks to keyframes.
    What I am wondering is it possible to mirror a set of keyframes? (I am assuming that aniblocks cannot)
  • AuroratrekAuroratrek Posts: 260
    A quick note that Chapter 4 of my ongoing fantasy series Quest of the Key is now available online. This isn't animated in Daz, but it uses a lot of great Daz assets, in this chapter in particular it uses the Blacksmith Forge and Medieval Cellar by 3dLab. Let me know what you think!
     Every episodes adds depth and context to story. More than the sum of the parts indeed!  This series continues to impress. I absolutely want to know what happens next.  And what more can we ask for from entertainment;  to peak our interest.
    Thanks, FB! I'm glad you have enjoyed this series and want to see more--that's all I can ask as a storyteller!  ;-) The next chapter is in the works, and I hope to not keep you waiting too long for it!
