Using gradients
Its me again...Is there any way to change the direction of a gradient color on an object? Say it always goes to the right end of an object and I want it to go to left end but I dont want to just rotate the object in order to get in on the other end...This is in Carrara..Thanks
  • 3DAGE3DAGE Posts: 3,321
    edited August 2015
    Hi
    apart from changing the colous,. eg: black to white - white to black,
    you can adjust the direction by using a Pattern Function / Gradient to control the direction of the main colour gradient or Mixer,.
    You can apply the Gradient control (Pattern Function / Gradient), to the "shader" node of your Colour Gradient, or as the "blender" in a Mixer
    Pic to help
    1049 x 473 - 126K
    Post edited by 3DAGE on
  • Thank you so much for the info and the pic.  I'm sure I'll be asking many more questions!!
    We're here to help!
