Using gradients
Its me again...Is there any way to change the direction of a gradient color on an object? Say it always goes to the right end of an object and I want it to go to left end but I dont want to just rotate the object in order to get in on the other end...This is in Carrara..Thanks
Hi
apart from changing the colous,. eg: black to white - white to black,
you can adjust the direction by using a Pattern Function / Gradient to control the direction of the main colour gradient or Mixer,.
You can apply the Gradient control (Pattern Function / Gradient), to the "shader" node of your Colour Gradient, or as the "blender" in a Mixer
Pic to help
Thank you so much for the info and the pic. I'm sure I'll be asking many more questions!!
