[Released] Content Wizard [Commercial]
14546485051
  • followme.kevfollowme.kev Posts: 5
    edited October 2024
    RiverSoft Art said:
    followme.kev said:
    Hello !
    I have trouble to find how to generate smart content without using a zip file.
    Let me explain.
    A few months ago, I bought more than a hundred products on Renderosity and I installed these products manually on a dedicated hard drive each time and then deleted the zip archives.
    Recently, I wanted to generate the smart content of all the products on this dedicated hard drive with CW but I don't see how to do that without using the zip archives.
    So I had the idea to create a zip archive including absolutely the entire folder of my special Renderosity library like it was a really BIG product and the archive looks like this:
    G:\AllRendoLib.zip\Content\(All the files like Data, Runtime, People, etc).
    Maybe the archive is too heavy for CW (~450GB), but when I run the analysis, it tells me "No User Facing...".
    I should point out that I took care to check that the SCI working directory is empty and that I have more than enough space to work (10TB).
    My question is: Am I stupid? Or is there a way to generate smart content directly from my already installed rendo library without going through any zip archive?
    Thanks in advance.
    Edit : Ok, i have found my answer in the comments section of your YT video tutorial.
    The question was : "Sorry for this stupid question but is it possible to generate Smart Content Metadata right inside DAZ for installed content? I have a lot of products from sites like Renderosity and I don't want to redownload and reinstall every single product. That would be great, thank you!"
    And your answer was : "You need the zip files as CW would have no idea what files are part of the product. You don't need to reinstall them necessarily as long as the paths don't change from the zip, but the zips are definitely needed."
    I'm really sad... Look like i will have to redownload every single products :(
    It would be great, in the future, to be able to tell CW to simply scan a specific pointed library or a specific pointed folder to generate SC.
    If these are older products (V4 era), they might not have user facing files like later stuff.  However, even if you got it to work, I would not recommend it as even if it worked, it would take forever.  And more than likely, you would make a mistake somewhere and CW would generate metadata for an asset already in another Daz product, causing DS to get confused.
    The zips are really needed to help CW figure out what refers to what.  It was and is incredibly hard to figure out what files are since places like Rendo do not enforce the Daz rules.  The zips made it easier.
    Hello and thank you for your answer.
    I have another question...
    When BatchCW installs products that contain the "Manifest.dsx" file, does it rely primarily on this file to install the smart content?
    Or maybe the "Manifest.dsx" files have nothing to do with the smart content?
    If so, if BatchCW relies primarily on the "Manifest.dsx" files if they are present alongside the "content" folders, is it still a problem if the creator has not respected the daz conventions?
    For example, I bought a lot of products directly from the DAZ store and some clothes are in a folder named "Genesis 8 Females" instead of "Genesis 8 Female".
    Another creator sells his product on the daz store except that the path is "Enviroments" instead of "Environments".
    So, I end up with a library like:
    Content\Data
    Content\People\Genesis 8 Female
    Content\People\Genesis 8 Females
    Content\People\Genesis 8 Female\Character
    Content\People\Genesis 8 Female\Characters
    Content\Enviroments
    Content\Environments
    Content\Etc...
    Everything is sold on the daz store and with the "Manifest.dsx" file.
    I would like to know if there is no problem getting the smart content as long as the product has the "Manifest.dsx" file?
    Or do I need to manually fix all the wrong path event if the "Manifest" file is included ?
    Thank you in advance for your insights.
    Post edited by followme.kev on
  • followme.kev said:
    RiverSoft Art said:
    followme.kev said:
    Hello !
    Let me explain.
    Thanks in advance.
    Content\Data
    Content\Enviroments
    Content\Etc...
    CW does not look for or at the Manifest.dsx.  If a zip has it and is coming from Daz, there is already metadata and you should be using DIM.
  • RiverSoft Art said:
    followme.kev said:
    RiverSoft Art said:
    followme.kev said:
    Hello !
    Let me explain.
    Thanks in advance.
    Content\Data
    Content\Enviroments
    Content\Etc...
    Ok.
    I don't like DIM. It confuse me in some way...
    I will need to do some cleaning manually ! ^^
    Thank you for your support and have a nice day :)
    RiverSoft Art said:
    followme.kev said:
    RiverSoft Art said:
    followme.kev said:
    Hello !
    Let me explain.
    Thanks in advance.
    Content\Data
    Content\Enviroments
    Content\Etc...
    Ok.
    I find DIM vastly superior to the other ways Daz allows you to install content. smiley  But the point is that for Daz content, use Daz methods for installation as they already got the metadata right (or at least better than CW can do)
    Have a nice day too!
  • DieterDieter Posts: 18
    RiverSoft Art said:
    RiverSoft Art said:
    Dieter said:
    Sorry,
    Hello Riversoft;
    after the last update of DAZ Studio to version 4.22.0.19
    after installing the metadata in the smart content CW is not closed properly.
    Either items of clothing or figures from different stores remain in the scene!
    Is there an update or another solution for this?
    It's pretty annoying to have to close and restart DAZ every time!
    Thanks
    Dieter
    I'll investigate.
    For me, CW finishes.  However, it IS slower.  Looking at the Daz log for when CW is installing Smart Content, I see a lot of this:
    2024-10-09 07:07:55.928 [INFO] :: Clearing the scene...
    2024-10-09 07:10:39.938 [INFO] :: Loaded image: Fabric 1_Color.jpg
    2024-10-09 07:10:39.975 [WARNING] :: QWidget::repaint: Recursive repaint detected
    2024-10-09 07:10:40.092 [INFO] :: *** Scene Cleared ***
    Notice the BIG time gap between when the script calls Scene.clear() and the scene ACTUALLY being cleared.  I don't think I can do anything about that.  The call is an atomic operation (i.e., one line of code) that the script has no control over.  I will keep investigating though.
    Dieter said:
    RiverSoft Art said:
    RiverSoft Art said:
    Dieter said:
    Sorry,
    Hello Riversoft;
    Thanks
    Dieter
    I'll investigate.
    Hello Riversoft,
    I tried to install some files with CW again today and again encountered the problem I mentioned!
    After installing in Smart Content, the last piece of clothing or figure remains in the viewport and cannot be deleted without canceling CW and DAZ Studio.
    Even after waiting for over 10 minutes, nothing happened!
    The metadata is saved correctly!
    Attached is the log file and a screen shot
    Dieter
    txt
    txt
    log.txt
    4M
    2119 x 1471 - 899K
    601 x 901 - 81K
  • Dieter said:
    Dieter said:
    RiverSoft Art said:
    RiverSoft Art said:
    Dieter said:
    Sorry,
    Hello Riversoft;
    Thanks
    Dieter
    I'll investigate.
    Hello Riversoft,
    Dieter
    What version of DS are you using?  I am not seeing this at all.  In fact, with 4.23.0.1 I am not seeing the slowdown either.
  • YacomoYacomo Posts: 45
    edited December 2024
    I just purchased Content Wizard, hoping to save time setting up smart content info for external purchases.
    Unfortunately, I cannot even start it, Studio crashes hard when attempting to start the Content Wizard script.
    Maybe, my environment is not supported?
    • Studio 4.23
    • MacOS 15.2
    • Apple Silicon (M3 Max)
    Installed via DIM.
    Any ideas?
    This is all I could find in the log file:
    2024-12-18 10:03:33.529 [INFO] :: Loading script: /Users/Shared/My DAZ 3D Library/Scripts/RiverSoft Art/Content Wizard/Content Wizard.dse
    2024-12-18 10:03:33.571 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSConstants.dsa
    2024-12-18 10:03:33.594 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSSmartContentConstants.dsa
    2024-12-18 10:03:33.655 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSBuildPanels.dsa
    2024-12-18 10:03:33.675 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/seedrandom.dsa
    2024-12-18 10:03:33.694 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSAssemblyLineFunctions.dse
    2024-12-18 10:03:33.710 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSHelperFunctions.dse
    2024-12-18 10:03:33.724 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSAdvHelperFunctions.dse
    2024-12-18 10:03:33.736 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RS2020HelperFunctions.dse
    2024-12-18 10:03:33.755 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSSmartContentCategoryEditor.dse
    Edit: This is the stack trace after the crash:
    Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
    0   <translation info unavailable>           0x105bc01e8 ???
    1   QtCore                                   0x108a37c65 QMetaType::construct(int, void const*) + 1953
    2   QtCore                                   0x108a4d242 construct(QVariant::Private*, void const*) + 1762
    3   QtGui                                    0x109c95678 construct(QVariant::Private*, void const*) + 2088
    4   QtCore                                   0x108a50591 QVariant::QVariant(int, void const*) + 49
    5   QtScript                                 0x111e38e75 QScript::callQtMethod(QTJSC::ExecState*, QMetaMethod::MethodType, QObject*, QTJSC::ArgList const&, QMetaObject const*, int, bool) + 4165
    6   QtScript                                 0x111e3c848 QScript::QtFunction::execute(QTJSC::ExecState*, QTJSC::JSValue, QTJSC::ArgList const&) + 408
    7   QtScript                                 0x111e30526 QScript::QtFunction::call(QTJSC::ExecState*, QTJSC::JSObject*, QTJSC::JSValue, QTJSC::ArgList const&) + 186
    8   QtScript                                 0x111d8fde1 QTJSC::NativeFuncWrapper::operator()(QTJSC::ExecState*, QTJSC::JSObject*, QTJSC::JSValue, QTJSC::ArgList const&) const + 113
    9   QtScript                                 0x111d7832d cti_op_call_NotJSFunction + 221
    10  ???                                   0x2bcf9ea3bb46 ???
    11  QtScript                                 0x111d395f9 QTJSC::Interpreter::execute(QTJSC::EvalExecutable*, QTJSC::ExecState*, QTJSC::JSObject*, int, QTJSC::ScopeChainNode*, QTJSC::JSValue*) + 975
    12  QtScript                                 0x111d3977c QTJSC::Interpreter::execute(QTJSC::EvalExecutable*, QTJSC::ExecState*, QTJSC::JSObject*, QTJSC::ScopeChainNode*, QTJSC::JSValue*) + 114
    13  QtScript                                 0x111e13a80 QScriptEnginePrivate::evaluateHelper(QTJSC::ExecState*, long, QTJSC::EvalExecutable*, bool&) + 754
    14  QtScript                                 0x111e13c36 QScriptEngine::evaluate(QScriptProgram const&) + 140
    15  libdzcore.dylib                          0x10c244a94 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 4203732
    16  libdzcore.dylib                          0x10c245396 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 4206038
    17  libdzcore.dylib                          0x10c245443 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 4206211
    18  libdzcore.dylib                          0x10c031ea2 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2029794
    19  libdzcore.dylib                          0x10c0417d5 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2093589
    20  libdzcore.dylib                          0x10c0432d1 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2100497
    21  libdzcore.dylib                          0x10c043805 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2101829
    22  libdzcore.dylib                          0x10c0438ee DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2102062
    23  libdzcontentlibrarypane.dylib            0x12b1a7a83 0x12b197000 + 68227
    24  libdzcontentlibrarypane.dylib            0x12b19f6fd 0x12b197000 + 34557
    25  QtCore                                   0x108a43131 QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 2001
    26  QtGui                                    0x10a11048c QAbstractItemView::mouseDoubleClickEvent(QMouseEvent*) + 336
    27  QtGui                                    0x109caa404 QWidget::event(QEvent*) + 354
    28  QtGui                                    0x10a008a52 QFrame::event(QEvent*) + 40
    29  QtGui                                    0x10a087f44 QAbstractScrollArea::viewportEvent(QEvent*) + 126
    30  QtGui                                    0x10a1111f7 QAbstractItemView::viewportEvent(QEvent*) + 663
    31  QtGui                                    0x10a08a32d QAbstractScrollAreaFilter::eventFilter(QObject*, QEvent*) + 33
    32  QtCore                                   0x108a2b231 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 149
    33  QtGui                                    0x109c598a8 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 288
    34  QtGui                                    0x109c5a348 QApplication::notify(QObject*, QEvent*) + 2666
    35  libdzcore.dylib                          0x10c592a1e DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7668830
    36  QtCore                                   0x108a2d7e2 QCoreApplication::notifyInternal(QObject*, QEvent*) + 104
    37  QtGui                                    0x109c61ffe QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 432
    38  QtGui                                    0x109c10db3 qt_mac_handleMouseEvent(NSEvent*, QEvent::Type, Qt::MouseButton, QWidget*, bool) + 995
    39  AppKit                                0x7ff80e56c00a -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4471
    40  AppKit                                0x7ff80e4e533d -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 409
    41  AppKit                                0x7ff80e4e4f89 -[NSWindow(NSEventRouting) sendEvent:] + 339
    42  QtGui                                    0x109c085a2 -[QCocoaWindow sendEvent:] + 114
    43  AppKit                                0x7ff80edde38e -[NSApplication(NSEventRouting) sendEvent:] + 1546
    44  QtGui                                    0x109c0c07e -[QNSApplication sendEvent:] + 94
    45  AppKit                                0x7ff80e94b2c3 -[NSApplication _handleEvent:] + 65
    46  AppKit                                0x7ff80e37e575 -[NSApplication run] + 654
    47  QtGui                                    0x109c14b77 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 879
    48  QtCore                                   0x108a2ab68 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 394
    49  QtCore                                   0x108a2df33 QCoreApplication::exec() + 175
    50  libdzcore.dylib                          0x10c5beb80 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7849408
    51  libdzcore.dylib                          0x10c5c922e DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7892078
    52  DAZStudio                                0x1000025dd main + 461
    53  DAZStudio                                0x100002304 start + 52
    Post edited by Yacomo on
    • Studio 4.23
    • MacOS 15.2
    Installed via DIM.
    Any ideas?
    I have this dim memory that my scripts may struggle on a shared drive?  Try installing to a local drive.
    • Studio 4.23
    • MacOS 15.2
    Installed via DIM.
    Any ideas?
    Thanks for the quick response. Unfortunately this made no difference:
    2024-12-18 13:33:59.654 [INFO] :: Loading script: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/Scripts/RiverSoft Art/Content Wizard/Content Wizard.dse
    2024-12-18 13:33:59.701 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSConstants.dsa
    2024-12-18 13:33:59.729 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSSmartContentConstants.dsa
    2024-12-18 13:33:59.793 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSBuildPanels.dsa
    2024-12-18 13:33:59.812 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/seedrandom.dsa
    2024-12-18 13:33:59.828 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSAssemblyLineFunctions.dse
    2024-12-18 13:33:59.844 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSHelperFunctions.dse
    2024-12-18 13:33:59.857 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSAdvHelperFunctions.dse
    2024-12-18 13:33:59.870 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RS2020HelperFunctions.dse
    2024-12-18 13:33:59.889 [DEBUG] :: Found: /Users/Yacomo/Documents/DAZ 3D/Studio/My Library/data/RiverSoft Art/Common/RSSmartContentCategoryEditor.dse
    This is not really a surprise, since, despite the name, '/Users/Shared' on a Mac is not some network link. It is a bare basic folder on the local hard disk next to the user's home folder.
    • Studio 4.23
    • MacOS 15.2
    Installed via DIM.
    Any ideas?
    Hmmm, this definitely works on a Mac.  If you run it TWICE, what does the log say between crashes?  Often, the Daz log won't show the last couple messages until something else flushes the log buffer.
    Unfortunately there is nothing more in the log, I get a hard crash - Studio exits immediately.
    Next messages in the log file then are the Studio startup messages:
    2024-12-18 14:30:59.572 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Common/RSSmartContentCategoryEditor.dse
    2024-12-18 14:30:59.584 [DEBUG] :: Found: /Users/Shared/My DAZ 3D Library/data/RiverSoft Art/Data/RightArrowTriangle.png
    2024-12-18 14:31:11.101 +++++++++++++++ DAZ Studio 4.23.0.1 starting +++++++++++++++++
    2024-12-18 14:31:11.102 [INFO] :: Performing cleanup...
    2024-12-18 14:31:11.107 [INFO] :: Release Cycle: General Release
    2024-12-18 14:31:11.107 [INFO] :: Platform bits: 64
    2024-12-18 14:31:11.107 [INFO] :: Qt Version: 4.8.7
    2024-12-18 14:31:11.108 [INFO] :: OpenSubdiv Version: 3.0.0
    2024-12-18 14:31:11.154 [INFO] :: Running on macOS Sequoia 15.2
    2024-12-18 14:31:11.168 [INFO] :: CPU Information:
    2024-12-18 14:31:11.168 [INFO] ::     CPU Brand String = Apple M3 Max
    2024-12-18 14:31:11.168 [INFO] ::     Family = 6
    2024-12-18 14:31:11.168 [INFO] :: Current DateTime:
    2024-12-18 14:31:11.169 [INFO] ::     Loc: Wed Dec 18 14:31:11 2024
    2024-12-18 14:31:11.170 [INFO] ::     UTC: Wed Dec 18 13:31:11 2024
    2024-12-18 14:31:11.170 [INFO] :: Home Path:
    2024-12-18 14:31:11.170 [INFO] ::     Location = /Applications/DAZ 3D/DAZ 3D/DAZStudio4 64-bit
    2024-12-18 14:31:11.170 [INFO] ::     Disk Total: 3.6 TB (3996329328640)
    2024-12-18 14:31:11.170 [INFO] ::     Disk Avail: 442.3 GB (474980151296)
    2024-12-18 14:31:11.170 [INFO] :: Temp Data:
    2024-12-18 14:31:11.170 [INFO] ::     Location = /Users/Yacomo/Library/Application Support/DAZ 3D/Studio4/temp
    Good to hear this should be working on a Mac. The problem may be that I am using a machine with an Apple Silicon chip? Do you also have such a machine at your disposal for testing or are you still using an Intel machine? Next best option may be the OS version, I am on MacOS 15.2 (most recent release) which unfortunately is not the greatest release ever - it has known issues with a couple of well known tools (Little Snitch and SuperDuper in my case).
    Edit: Are there by any chance some additional debug setting I could turn on to get more info in the log?
    Hmmm, I will have to think about it.  Unfortunately, I have only have a 10? year old Mac Mini collecting dust somewhere.  I will see if I could create a debug version for you.  Do you have other scripts from me?  Do they work?
    Hmm, I just tried Bone Minion (G4 for G8) und it crashes as well, with pretty much the same trace:
    0   <translation info unavailable>           0x1040eaf90 ???
    10  ???                                   0x58297ec3209a ???
    18  libdzcore.dylib                          0x10c2455bd DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 4206589
    19  libdzcore.dylib                          0x10beedea8 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 702696
    20  libdzcore.dylib                          0x10bef399f DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 725983
    21  libdzcore.dylib                          0x10be64bf9 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 140857
    22  libdzcore.dylib                          0x10beb45f7 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 466999
    23  libdzcore.dylib                          0x10beb730a DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 478538
    24  libdzcore.dylib                          0x10bf0b265 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 822437
    25  libdzcore.dylib                          0x10c0415ee DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2093102
    26  libdzcore.dylib                          0x10c0432d1 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2100497
    27  libdzcore.dylib                          0x10c043805 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2101829
    28  libdzcore.dylib                          0x10c0438ee DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 2102062
    29  libdzcontentlibrarypane.dylib            0x12c05da83 0x12c04d000 + 68227
    30  libdzcontentlibrarypane.dylib            0x12c0556fd 0x12c04d000 + 34557
    31  QtCore                                   0x108a43131 QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 2001
    32  QtGui                                    0x10a11048c QAbstractItemView::mouseDoubleClickEvent(QMouseEvent*) + 336
    33  QtGui                                    0x109caa404 QWidget::event(QEvent*) + 354
    34  QtGui                                    0x10a008a52 QFrame::event(QEvent*) + 40
    35  QtGui                                    0x10a087f44 QAbstractScrollArea::viewportEvent(QEvent*) + 126
    36  QtGui                                    0x10a1111f7 QAbstractItemView::viewportEvent(QEvent*) + 663
    37  QtGui                                    0x10a08a32d QAbstractScrollAreaFilter::eventFilter(QObject*, QEvent*) + 33
    38  QtCore                                   0x108a2b231 QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) + 149
    39  QtGui                                    0x109c598a8 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 288
    40  QtGui                                    0x109c5a348 QApplication::notify(QObject*, QEvent*) + 2666
    41  libdzcore.dylib                          0x10c592a1e DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7668830
    42  QtCore                                   0x108a2d7e2 QCoreApplication::notifyInternal(QObject*, QEvent*) + 104
    43  QtGui                                    0x109c61ffe QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 432
    44  QtGui                                    0x109c10db3 qt_mac_handleMouseEvent(NSEvent*, QEvent::Type, Qt::MouseButton, QWidget*, bool) + 995
    45  AppKit                                0x7ff80e56c00a -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4471
    46  AppKit                                0x7ff80e4e533d -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 409
    47  AppKit                                0x7ff80e4e4f89 -[NSWindow(NSEventRouting) sendEvent:] + 339
    48  QtGui                                    0x109c085a2 -[QCocoaWindow sendEvent:] + 114
    49  AppKit                                0x7ff80edde38e -[NSApplication(NSEventRouting) sendEvent:] + 1546
    50  QtGui                                    0x109c0c07e -[QNSApplication sendEvent:] + 94
    51  AppKit                                0x7ff80e94b2c3 -[NSApplication _handleEvent:] + 65
    52  AppKit                                0x7ff80e37e575 -[NSApplication run] + 654
    53  QtGui                                    0x109c14b77 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 879
    54  QtCore                                   0x108a2ab68 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 394
    55  QtCore                                   0x108a2df33 QCoreApplication::exec() + 175
    56  libdzcore.dylib                          0x10c5beb80 DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7849408
    57  libdzcore.dylib                          0x10c5c922e DzFacetVertexSubPath DzFacetVertexSubPath::remapPath<signed char>(signed char, signed char const*) const + 7892078
    58  DAZStudio                                0x1000025dd main + 461
    59  DAZStudio                                0x100002304 start + 52
    This does not bode well...
    I've been away from Studio for quite some time and have a completely empty Runtime at the moment (besides Studio default content). Thought about starting cleanly from scratch.
    Let me see if I have scripts from other vendors I could try...
    Okay, could not find many scripts to install. But I do own UltraScenery 2 (which is a plugin) and Alienator Pro II (which is a script) - installed both. UltraScenery works. And the window for the Alienator Pro script as well as the Alienator Builder do open, cannot test much more her atm.
  • ElorElor Posts: 3,521
    I have a MacBook Pro with a M1 Pro chip. I'll see if I can test it, but as far as I remember, it did launch the couple of times I launched with the intent to learn how to use it.
    Edit: it launched without any problem (which in itself may not meant that much, some scripts have a tendency to crash Daz on my Mac and may require a couple of relaunch of Daz before finally being able to launch the script without Daz crashing).
    Post edited by Elor on
    That's great, thanks for testing. Now to figure out what's wrong on my end... Given that I have a clean new Studio install all I can think of is the OS. Which version are you currently on?
    Edit: Since you mentioned that you do get random crashes with scripts I tried again to open the script multiple times in a row. And indeed out of about twenty tries it did open once! Unfortunately every orther try afterwards failed again :-(
    Edit 2: And trying again with Alienator, the Set Builder also crashes randomly (with a very similar trace). Oh my...
  • LeanaLeana Posts: 12,942
    Which version of DS 4.23 are you using, general release or latest beta? AFAIK the general release had some issues with several plugins on a Mac so if that's what you are using I would try the beta in case it is linked.
    Thanks for the tip Leana. I was using 4.23.0.1, the current Beta is 4.23.0.4 - unfortunately I am experiencing the same crashes with that version. :-(
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    I am using Content Wizard for literally years now on a Mac, both Intel and Apple Silicon. I had no issues with any DS release prior to 4.23.x. It does crash (a lot) when running on 4.23, both the current build and the public beta one. DS 4.23.x is as stable as a wet paper house in a hailstorm. CW even would work with a network shared drive, as this is my standard setup since 2020.
    Post edited by Mark_e593e0a5 on
  • I hadn't realized that 4.23 had caused so many problems on the Mac.
  • anaximanes_2000anaximanes_2000 Posts: 374
    edited January 2025
    Riversoft, sorry to bother you with this, but I cannto figure it out.  Every time I install anything, it also reinstalls these:
    Nevermind!  If anyone notices that Content Wizard is reinstalling the same files every time (but also installing the new files correctly) go to:
    C:\Users\Owner\AppData\Roaming\DAZ 3D\Studio4\temp\ContentWizard
    And delete everything in that folder.
    Post edited by anaximanes_2000 on
  • memcneil70memcneil70 Posts: 5,605
    @Riversoft
    I am working on my new MacMini Pro M4 and this is the second time I have attempted to install a file from Renderosity that I have successfully installed on not only my Win 10, Win 11, and my MacBookPro M1 D|S systems in the past. My MacOS is Sequoia 15.3.1 and I am working on Daz Studio Public Build BETA v.4.23.1.36, and Content Wizard is 1.2.1.. After I pasted the snip of the log, I clicked save log and it crashed Daz Studio. BTW, it does take about one to four crashes before I get a stable Studio to work on. I have given DAZ3DIM, DzInstallHelper, and DAZStudio full disk access and check it each time I have an OS update. This is similar to what happened when I attempted to install an outfit by Lully a week ago.
    After a successful installation of Content it is at Install Smart Content I have had issues. I have attached a snip of part of the Content Library's files, so they do appear. Just without metadata.
    This is a snip of the end of the log that appears:
    15:07:06 GMT-0700 (MST): ...Success
    15:07:06 GMT-0700 (MST): Copying "Runtime/textures/FK-Creations/ColoretteScreen/FKTHL-Screen33.jpg" to "/Volumes/Spawns Work/Users/Public/My DAZ 3D Library/Runtime/textures/FK-Creations/ColoretteScreen/FKTHL-Screen33.jpg"
    15:07:06 GMT-0700 (MST): Installation Completed Successfully
    15:07:16 GMT-0700 (MST): Installing Product to Daz Studio...
    15:07:16 GMT-0700 (MST): Version Number 1.2.1
    15:07:16 GMT-0700 (MST): Verifying existence of Renderosity store: true
    15:07:16 GMT-0700 (MST): Verifying "Theory of Light - Energy Flow Iray Lights, HDRIs and Props" product does not exist already
    15:07:16 GMT-0700 (MST): Creating "Theory of Light - Energy Flow Iray Lights, HDRIs and Props" product (Store="Renderosity", ID="Renderosity_124021") in Daz Studio...
    15:07:16 GMT-0700 (MST): Building product metadata...
    15:07:16 GMT-0700 (MST): Unable to open file for writing: /Volumes/Spawns Work/Users/Public/My DAZ 3D Library/Runtime/Support/Renderosity_Renderosity_124021_Theory_of_Light_-_Energy_Flow_Iray_Lights,_HDRIs_and_Props.dsx
    15:07:16 GMT-0700 (MST): Error creating metadata for Daz Studio import: /Volumes/Spawns Work/Users/Public/My DAZ 3D Library/Runtime/Support/Renderosity_Renderosity_124021_Theory_of_Light_-_Energy_Flow_Iray_Lights,_HDRIs_and_Props.dsx
    15:07:16 GMT-0700 (MST): There were errors during installation.
    Do you have any idea what I might be doing wrong or if my file structure is incorrect?
    Thank you,
    Mary
    2364 x 1712 - 3M
  • memcneil70 said:
    @Riversoft
    Thank you,
    Mary
    Does this directory exist? /Volumes/Spawns Work/Users/Public/My DAZ 3D Library/Runtime/Support/
    edited February 2025
    No, should I create a shell one?
    The program had no problem creating the other files necessary to install the program though. See attached file structure. Only one other product partially installed. Same issue.
    Mary
    3210 x 462 - 246K
    Post edited by memcneil70 on
    Mary
    Please create that directory and try again.  Thanks.
    Thank you sir! I added 'Support' and deleted the messed-up files and re-installed both, and the other files bought at the same time and all five products from Lully and fabiana installed perfectly. I can now get moving on with my other stores' and freebie products.
    And this is why I love your products. Service when I am confused and lost.
    Have a wonderful day.
    You're welcome!  I am glad it worked.
    edited April 2025
    Hello,
    I'm using Content Wizard on my Mac, with Daz Studio 4.23.1.40. I have installed everything through DIM.
    Daz Directory is set to '/Users/[username]/Documents/DAZ 3D/Studio/Metadonnees/'
    Daz Studio is allowed to access that directory and Content Wizard was able to unzip the product inside the 'Metadonnees' directory. But when I'm asking CW to install the metadata, I'm greeted with these errors:
    11:29:38 GMT+0100 (CET): Verifying "DMs Abiding Sanctum" product does not exist already
    11:29:38 GMT+0100 (CET): Creating "DMs Abiding Sanctum" product (Store="Renderosity", ID="115026") in Daz Studio...
    11:29:38 GMT+0100 (CET): Building product metadata...
    11:29:38 GMT+0100 (CET): Unable to open file for writing: /Users/[username]/Documents/DAZ 3D/Studio/Metadonnees/Runtime/Support/Renderosity_115026_DMs_Abiding_Sanctum.dsx
    11:29:38 GMT+0100 (CET): Error creating metadata for Daz Studio import: /Users/[username]/Documents/DAZ 3D/Studio/Metadonnees/Runtime/Support/Renderosity_115026_DMs_Abiding_Sanctum.dsx
    The problem is apparently the absence of a Support folder and after creating it myself, it did work.
    Is it possible for Content Wizard to create a Support folder automatically if it's missing ?
    Another question: I may have missed it, but what can I do to start from a clean slate ?
    Once I have use the Save button, CW will always show the last saved state and I don't know how to remove it. On your video, there is a Clear button near the '-' button but it's not visible on my version.
    And a last question: I'm trying to add metadata to a product with one-hand and two-hands hammers for G8 & G9.
    From what I can see, the one-handed wearable presets are all using the same model (with different transformations to place in into the hand of each figure) and it's the same with the two-handed wearable presets, but Content Wizard wants to create a Compatibility Base for each wearable preset.
    Is there a way to point one compatibility base to the dsf file directly ?
  • RiverSoft ArtRiverSoft Art Posts: 6,832
    Elor said:
    Hello,
    It's certainly possible. It is on my list of fixes.
    Click the New Product button, just below the Intended Audience field.
    No, that is not how the smart content works so CW can do nothing about that.
