Fit Control for Genesis 8 (Commercial)
1121314151618»
  • SVBSVB Posts: 7
    I have aquestion about Fit Control for Genesis 8 Male(s). I added the morphs to an item (Swim Shorts) but the morphs are not showing.
    1793 x 683 - 179K
  • nabob21 said:
    I have removed the files that were duplicates and re-installed the Fit Control Add-On but still have the crashes when certain characters remain installed. Herre is the latest log file.
       Hi Nabo21, I had a problem that seems identical to yours, though in my case, it also coincided with an upgrade (I upgraded again, but it did not eliminate it).
        Tried to remove a character you suggested, but before even trying if it was only that character, I found a workaround (hoping Zev0 is not going to kill me and somehow change the product so the workaround stops working :-P :-)), thanks to an old post in which Zev0 indicated how Fit Control (for G2, I think, but it is the same principle) worked.
        If the morphs are correctly installed, they are in reality loaded with the character, just not visible. In the parameters, there is a "hidden" folder - in reality, the morphs you can see there, are not really hidden, but if you use the menu in the "preferences" tab (top left corner) and select "show hidden", you will see the fit control morphs are there.
         Once that is the case, you can just select them as "favorites" (the little heart), then use the transfer utility to transfer them from the character to the clothes you want to apply fit control to.  If you want to do it for a bunch, or all of them,  better pass into "edit mode" and select multiple, that way you can "favorite" them at once.
        In basic terms, you would be doing manually the work the the script does.
        Of course if you transfer all them and then want to "clean up" becomes a tedious long work, because the scripts from Zev0 normally do all the work for you, and it seems even you untick the "hidden", they still stay hidden (but I did not yet try saving the scene and reloading it), so, it is far from being as good as Zev0 scripts, and I would suggest you really transfer only the morphs you need for the specific clothes.
       But at least it works and is better than the alternative I had got from DAZ. Their idea, after a "peer review" of my ticket (worked in helpdesk in the past, loved that one :-)), was to blame it to my database not being in the default location, and tell me I had to remove every daz related, full library included, and reinstall everything, which means thousands of assets, many of which cataloged by myself, and without giving me any way to save and restore that information.
      Luckily I work in IT, so, I could see what their indication relly meant :-)
       Hope this helps, even if it is only a workaround and not a real solution.
  • Zev0Zev0 Posts: 7,123
    edited November 2024
    Hi can you show me the steps you took eg the script interface where you select the shorts to add Fit Control?
    Post edited by Zev0 on
    dobbyelf said:
    FIT CONTROL FOR GENESIS 8 IS MISSING
    I purchased Fit Control for Genesis 8 and it doesn't appear anywhere!
    When I try to open it from DAZ Central it shows me an error message that says: Could not find the "50515" product!
    Please help!
    Can you try and install it via DIM?
  • nabob21nabob21 Posts: 1,057
    Thanks alofaro, I'll give this a try.
    Hi, I know you had already gone in that (the right) direction, effectively, you pointed me towards it, but I got a final and definitive confirmation.
    I installed Daz on another computer, even left the DB in the default location as told by the Daz support, even if I was sure it had nothing to do with it.
      Installed few basics, Fit control worked.
      Then I put back all the stuff I had, Fit control would crash Daz, as we have already seen.
      Then, came to mind, since I have Turbo loader utilities (huge library), I switched off everything for G8F, and loaded a subscene with a character that is a combination of morph, and that had plenty of clothes, plus other wearables, but that I had created when Fit Control was still working using the turbo loader tools load file (which automatically loads the morphs, but only the ones needed for the scene).
      I then tried to use fit control the normal way. It worked perfectly. This confirms definitively, if there was any need, that the problem is some morph that for whatever reason makes Daz go crazy, when Fit Control tries to complete the morph transfer.
       Unfortunately, the problem for me started months ago, and I did not get any suggestion from the DAZ helpdesk it could be morphs, so in the meantime I have nonetheless installed plenty of stuff, understanding what could be exactly can take a looooong time, I will just have to go by making a basic list of safe morphs, and if by chance over time I found out what other products could be.
  • I have tried unsuccessfully to figure out which morph(s) is causing Fit Control to crash. Hoping you can help.
    txt
    txt
    log.txt
    1M
  • y11971alexy11971alex Posts: 19
    Hi Zev0,
    What I currently want use this product for is to adjust the inseam of a set of trousers. When I use the "Height Adjust" slider in the underwear menu, the trousers no longer follow the shape of the charactr model, leaving plenty of pokes-through. I wonder if there's a way to let the trousers fit the character model while your product is applied? Thank you very much.
  • xyer0xyer0 Posts: 6,389
    Did I mention that I love Fit Control? Well, I do!
  • RobertDyRobertDy Posts: 274
    I think this product may need to be updated. Whenever I added morphs to a piece of clothing, and then click on Delete Unused Morphs, it would work. But now I keep getting "Please select a piece of clothing with Fit Control morphs added to it." Has happened on multiple instances of daz clothing I'm using.
