MANGA STYLE & VISUAL STYLE topic - Update Sept 23rd 2017: Fixed Dropbox links! [Commercial]
11314151618
    Wow, 12 years later (been a while), I was trying my hand at some animation, and needed a toon character model to cut-out/layer in PS, and thought..."I can probably render something in DS, if VSS is still working", and bam!  Still a solid set of shaders for 3Delight!
    ENTREPRENEUR TIP: Similar body bases are going for up to $85 each, on Etsy.  (search: "vtuber body base")  You could probably render a bunch of these, cut them up in Photoshop, and make a killing using these shaders!
  • Sphinx MagooSphinx Magoo Posts: 586
    Where's the "Like" button? I'd SMASH it right now!
    It's funny too because I'd just started using the pwToon Shader set after using the Iray Toon Shaders for a while. So to see someone else using a classic 3Delight Shader set was a pleasant surprise to see.
  • TheNathanParableTheNathanParable Posts: 1,089
    edited July 2024
    Wow, seeing people still enjoying my shaders after all these years...good lord has it really been over a decade already!?
    I really should revisit the concept sometime. There is so much I would do differently nowadays.
    Much love! <3
    Post edited by TheNathanParable on
  • Does this only work in 3Delight and iRay? I'd love for it to work in Filament as well.
    Much love! <3
    Would you do this for 3Delight or Iray? Because an Iray version would be much appreciated. The options for non-photoreal Iray shaders could use a boost!
  • Faeryl WomynFaeryl Womyn Posts: 3,741
    I'm with Sphinx Magoo, having a good iray version would be very nice.
  • memcneil70memcneil70 Posts: 5,529
    I vote also for an Iray version.
  • I'm still voting for a Filament version, though not as popular it seems.
    edited August 2024
    Dupe post due to Cloudfare.
    I concure on Filament. And would love to see it available for Mac OS systems.
    Post edited by memcneil70 on
    edited August 2024
    Much love! <3
    Unfortunately I don't think an iray version would be possible, at least not in the way I would want. There are however some excellent non-photoreal iray shaders that exist already that I highly recommend.
    Sketchy is a really cool collection of shaders to get toony results directly in iray. It even comes with a screentone style similar to Manga Style: https://www.daz3d.com/sketchy-toon-edge-and-art-style-shaders-for-iray
    And then there's Oso Toon, which is a pack of shaders that allows you to make toon images through multi-pass rendering. By making different versions of the same image with different settings, they can be combined in an image editor to create really cool effects that aren't possible with a single iray render: https://www.daz3d.com/oso-toon-shader-for-iray
    If I were to make a new toon shader pack, it would most likely be for 3Delight. It is still the best rendering engine for Daz Studio when it comes to non-photorealistic renders, even if it is unfortunately much slower than iray.
    That said, i'm also very interested in delving deeper into Blender, and seeing how easy it is to get toon characters from Daz into Blender to use either the Cycles or Eevee rendering engine. I've seen a LOT of really cool toon renders done using Blender, so that's something i'd really like to explore as an option.
  • MoreTNMoreTN Posts: 340
     So would that be a product to produce something in Daz to export to Blender, or a tutorial for how to produce toon renters in Blender, or both - or neither?
    I don't know, i'd have to do more research. I don't think it'd be the former, as there already exists the official Daz-to-Blender exporter, as well as the unofficial (tho popular) Diffeomorphic plugin, both capable of getting fully rigged characters into Blender.
    I never understood why an iray toon shader can't be made, Diva made a shader for iray that gives you character a toon look, so why can't this request be done.
    edited August 2024
    It's not that you can't make a toon shader for iray, it's that I can't make it the exact way i'd want it to be.
    Also, i'm not familiar with Diva's shader, would you mind linking it?
    This is the latest version    https://www.dropbox.com/scl/fi/crjj4rckf0sb8ebf28ahk/Divas-Toon-Skin-Helper-Ver3.zip?rlkey=2ohq8jockmxjw7esdztvk4vcj&e=1&dl=0
    This is the page she first posted the original version with images, the drop box link I posted above is ver 3
    https://www.daz3d.com/forums/discussion/277496/cartoonized-is-awesome/p3
  • scorpioscorpio Posts: 8,533
    Not shaders, this just seems to add an overlay to the mat preset of the figure.
  • Unfortunately I don't think an iray version would be possible, at least not in the way I would want. There are however some excellent non-photoreal iray shaders that exist already that I highly recommend.
    I actually like Sketchy quite a bit, and it's great for combining with Iray lighting and atmospheric effects. I just wish I could get a more solid outline output as it seems to vary a bit. I'm also still looking for a way to better control the transition from light to dark. In the Iron Man sample I uploaded, I used the Noir Presets you included with the original set to create a nice Metallic variation. Maybe I've missed something, but I haven't figured out how to sharpen that transition or how to change the dark color so it renders closer to these samples. I imagine it has to do with the Diffuse Overlay...
    Also, might I request for a new 3Delight version that it offers support for tiling. I've got a bunch of Shader Presets that I could use with VS, but there are no tiling options so I've learned to do without...
    464 x 600 - 42K
    834 x 1080 - 194K
  • Heya, just popping in to say that I literally JUST learned about FilaToon this very minute, and I am incredibly interested in exploring the possibilities of it. If possible, would anyone be interested in FilaToon presets that mimic the original Visual Style shaders?
    I'd absolutely love that, Visual Style shaders were my favorite!
    Yes please.
  • LeanaLeana Posts: 12,911
    That would be great
  • my2iumy2iu Posts: 2
    Definitely! I was actually about to ask in the forums if anyone knew if FilaToon could be made to imitate your Visual Style Shaders.
  • 3Diva3Diva Posts: 12,010
    FilaToon is now a thing, so someone must have been listening! lol
  • marblemarble Posts: 7,500
    Definitely!
  • vrba79vrba79 Posts: 1,515
    Seeing as Filament is on its way to becoming the defacto alternative for NPR rendering, more solutions that use it will be welcome.
  • UthgardUthgard Posts: 881
    Oh, God, yes, please! Looking at FilaToon, my original enthusiasm was substantially cooled when I realized how much better I liked the original visual style shaders. If you could provide some kind of option that mixed it with the manga style shaders effects (or found a way to make modern style highlights such as the ones the FilaToon-based hairs use), that would be even better.
    I just popped by, as I dropped a old render of mine into Kling AI to see if it would animate (it did, but creepy) , and noticed this Filatoon thing (apparently 3 months after y'all did).  I may play around a little with it, if I can drag myself away from POE2.
    Nice to see you back! Highly recommend checking out the FilaToon topic over here, where we've been sharing Filatoon renders and sharing tips and advice. https://www.daz3d.com/forums/discussion/704931/filatoon-cell-shaded-rendering-with-filament#latest
    Yay! I'm glad to see you getting in on this! I hope we get to see some Filatoon products from you! :D That would be awesome!
    Oh. If anyone can do amazing things with Filatoon, its definitely you, 3dO!
