• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Emissives not working in fbx files imported from Daz (not using dtb bridge)
milliethegreatmilliethegreat Posts: 456
June 2024 in Blender Discussion
Emissive materials are not imported when importing fbx files straight from Daz. I'm not using Daz to blender bridge at the moment. Haven't set it up or tried it
  • milliethegreatmilliethegreat Posts: 456
    June 2024
    Guess I'm spending big money on a p600 quadro and p40 Tesla for Daz Studio. I was hoping I could cheap out and use blender on an m40 instead. Guess not ;(
  • PadonePadone Posts: 4,152
    June 2024 edited June 2024
    Fbx only imports basic textures, not materials. If you want to import materials then try diffeomorphic which gets a fair good conversion from iray to cycles, including emission.
    Post edited by Padone on June 2024
    June 2024
    I used to diffeomorphic to import an environment and I got this error:
    Some assets were not found. Check that all DAZ root paths have been set up correctly.
    June 2024
    You have to do what the error message tells you, there's an extensive documentation available at the addon site.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Install/Save the DAZ root paths
    June 2024
    i didn't know there's something specific i need to do. It's been years since I used it. I used diffeomorphic back in something like 2017-2018 last so I'm just now relearning stuff about it
    UGH I CANT FIGURE OUT HOW TO GET THE [wretched] THING TO [bloomin'] WORK!!!!!!!!!!!
    A which root path do I put it in?
    my primary library folder where my assets are (which is on my E drive not my C drive
    the Daz library on my c drive
    my Daz program (where the exe is) folder
    the the root of my E drive where my primary library is
    my plugin folder in my Daz program folder
    the root of my Daz studio 4 folder
    somewhere else altogether??????
    im so confused
    Post edited by Richard Haseltine on June 2024
    June 2024
    If you follow my link above it explains there's a script to run which does the work for you. No need to guess anything.
    June 2024
    I used the script and it didn't help
    June 2024
    This is freaking FRUSTRATING!!!!!!!!!!!!! I used the script and still got that god awful error message!!!!!!!!!!!!!!!!!
    June 2024
    I really want this to work because I really don't want to shell out $200 something for a new gpu!
    June 2024
    Am I using the script wrong? Do I save the import to Daz file that the script generates somewhere specific????
    June 2024
    Is it my operating environment????
    June 2024
    Ugh I'm so lost and frustrated!
    June 2024
    Please upload a picture of your daz and blender folders so we can compare. If they're the same then everything should work fine. Below mine that's the deafult, I don't use daz connect, if you do be sure that the cloud directories are listed too.
    499 x 481 - 64K
    June 2024
    Where did you find the global settings window? I never saw that on my blender. Note: I'm using the latest edition of blender (4.x not 3.x)
    June 2024
    I've tried it on 3.6 but the same issue happens
    June 2024
    Where by chance would i find the global settings folder in blender 4.x?
    June 2024
    I can't find global settings anywhere, does blender 4.1 even have it?????
    June 2024
    I give up I'm just gonna eat the $200 price tag and buy the $200 gpu. But thanks for trying to help smiley
    June 2024
    It's the addon global settings where the daz paths are, as explained in the docs I linked for you above, which you are supposed to read.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Global Settings
    June 2024
    I actually did read it. Still couldn't find it
    June 2024
    Maybe I'm misunderstanding the instructions?
    June 2024
    You did not find the global settings button in the main tab ? If so try a clean install, though I'm not aware of anything which could remove the settings button, so you really messed it up bad some way.
    https://bitbucket.org/Diffeomorphic/import_daz/wiki/Install/Installing the Blender add-ons
    268 x 317 - 24K
    June 2024
    Clean install of what? Blender or Daz? What part of the screen is that dropdown menu on? I only see the menu itself
    June 2024
    What software is the global setting found in?
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
