Carrara crashes with Huion tablet ( Workaround )
Stezza
After a few years trying to solve the problem of Carrara crashing on startup if you have a HUION graphics tablet installed Carrara users have found a solution and a workaround that fixes the problem.
See post here in Carrara forum for more info
Option 1. Fixes the problem ~ get yourself this official file from WACOM - wintab32.dll from WacomTablet_6.3.40-2. Using this means you get no errors. You need to place this file in the Carrara folder where the Carrara.exe file is. Carrara then should open without crashing.
Option 2. Open notepad and then Save As wintab32.dll
put this empty file in the Carrara folder. Carrara should open with an error message saying that wintab32.dll is not designed to run on windows.. dismiss the error message and Carrara should start normally.
thanks to all who have persevered over the years with this annoying bug and trying to find a fix for it.
Richard Haseltine or @Frank0314 or any other mod that may be around can we have this pinned thanks
yippee, thanks for doing this Stezza :)
Nice fix thank you
Fantastic, thanks!
unforuntely inspite of repeated requests, the DAZ moderators won't pin this thread
Thanks Wendy, Thanks Stezza !!!
Bringing this up again, new wrinkle maybe for Windows 11
Setting up my new wiz-banging new system and I install Carrara (ok it's only 7.2 pro but anyway).
I set it up as above with the fake .dll and Cararra will load and works fine, but it's unable to remember the serial number and I have to reenter it every time I load it.
So I'm looking for the DLL (don't really want to install the Wacom driver) and find the Huion solution page. It contains a direct d/l of a wintab32.dll that actually works with everything. Download a copy of it and overwrite the one in the \windows\system32 folder and the windows\syswow64 folder and reboot. Then things work correctly without anything in the Carrara folder.
Note I installed the program to another folder, not Program Files(x86), so that might have helped as well although it wasn't sufficient on my previous Win10 machine.
in top LH corner of Carrara click on the logo and register from there and allow when prompted
