Fit Control for Genesis 8 (Commercial)
11213141517
  • nabob21nabob21 Posts: 1,054
    I have also tried Fit Control for G8/8.1F on the developer version of G8.1F and it works for that character, just not for the basic versions od G8F and G8.1F.
    shingureee,
    Did you look under teh Actors section in the parameters tab? It should have a sub-section called Fit Control.
  • Zev0Zev0 Posts: 7,123
    edited February 2024
    The morphs in here have same name as Fit Control. They need to be deleted or renamed.
    /data/DAZ 3D/Genesis 8/Female/Morphs/Barry Graham/Product/
    Thanks Zev0. I will delete them and hopefully that will work.  I was looking at that and was wondering why they were created in that folder. Do you have any idea why that may have happened? And do you know why Fit Control would work with the developer version of G8.1F and not the basic version?
    No idea why. Regardless those morphs should not be there.
    Ok. Thanks for your help Zev0, I appreciate it. I'll be glad to get this working agin as the fit contril products are one of my goto utilities that I make use of all the time.
    NPyes
  • greywolfgreywolf Posts: 132
    Heya!  I like the product and concept but I have a question:  Do you plan on doing an update for 8.1 items?  I'd really like to be able to use this for some of the clothing that is (unfortunately) 8.1 specific...
  • That should work fine
    Hi. This product works with 8.1. What specific item is not working?
    Zev0, I have removed the files as instructed but I am still getting a Daz Studio crash when I close the pop-up dialogue box that says the morphs have been added. I have attached the latest log file.
    txt
    txt
    log.txt
    956K
    Post edited by nabob21 on
    Most likely the creator of that product has included the morphs in their product by mistake. Your latest log file still shows some morphs in that location.
    Hi PerttiA,
    Yes, there are still some files in that location and I did try removing all of them, but it had no impact on the Daz Studio crashing issue. I have even uninstalled and re-installed Fit Control but with no success.
    After lots of trial and error I think I have found out what is causing the crashing. There appears to be some kind of conflict between the Fit Control for G8/8.1F product and a character called "GN Nancy for Genesis 8 and 8.1 Females" (https://www.daz3d.com/gn-nancy-for-genesis-8-and-81-females). I purchased that product just over a month ago but I wasn't expecting a character morph to be causing the issue. Anyway, long story short, I removed the character and now my Fit Control appears to be working like it should.
    I am continuing to have the problem where certain character morphs seem to be conflicting with Fit Control and causing Daz Studio to crash when the final Fit Control Pop-up window appears and I click 'Okay' to close it. Removing the characters fixes the issues, but why would character morphs cause this to happen, and why now? It is costly to purchase these characters and then find out I cannot use them since not all of them are from Daz3D. Does anyone know why this may be happening?
    edited April 2024
    Hi. Clear your log file..Load one of these characters and then use fit control. Send me new log when the issue happens. I just tested gn nancy and it worked fine on my side.
    Post edited by Zev0 on
    Hello Zev0,
    Thanks for looking into this again. I did as you asked and I have attached the log file you asked for.
    txt
    txt
    log.txt
    489K
    Hi..Please send me a PM......
    I sent a message as requested.
  • xyer0xyer0 Posts: 6,356
    I LOVE Fit Control!!
    Here is the new log file.
    txt
    txt
    log.txt
    490K
    Here is the latest log file.
    txt
    txt
    log.txt
    521K
    I have removed the files that were duplicates and re-installed the Fit Control Add-On but still have the crashes when certain characters remain installed. Herre is the latest log file.
    txt
    txt
    log.txt
    522K
  • Hi! I just migrated my runtime onto another drive Strangely fit control seems to have stopped working for me,, please help!
    How was the product installed?
  • yuyu.atemyuyu.atem Posts: 470
    Hello! I created a new cloth for G8M by using blender and I imported it into DS as a obj file.I tried tu use fit control on it but it tell me that I have to select a G8 character. I selected it but fit control tells me that the G8M has already fit control morphs. So, I don't understand how to use Fit Control on my new cloth. It's the forst time that I create a cloth, so I suppose I have first to do something to the cloth, but I don't know what. Could you help me, please?
    Thank you in advance!
  • Richard HaseltineRichard Haseltine Posts: 108,657
    Have you rigged it as a figure and fitted it to the Genesis 8 figure? Fit control adds morphs to a fitted item to help with fitting (and effects), it isn't a rigging system itself
    Ah ok, I didn't understand! Thank you very much! laugh
  • FIT CONTROL FOR GENESIS 8 IS MISSING
    I purchased Fit Control for Genesis 8 and it doesn't appear anywhere!
    When I try to open it from DAZ Central it shows me an error message that says: Could not find the "50515" product!
    Please help!
  • tomekamansontomekamanson Posts: 20
    edited September 2024
    Thanks for this!
    Post edited by tomekamanson on
