Face Transfer 2
13468916
  • ArtiniArtini Posts: 10,867
    Thanks a lot for the comments and the tips, tsroemi.
    edited December 2023
    Another creation with Face Transfer 2 and with various morphs, I have available for Genesis 9
    to improve shape around mouth and chin.
    1200 x 1200 - 538K
    1200 x 1200 - 593K
    Post edited by Artini on
  • nonesuch00nonesuch00 Posts: 18,863
    Artini said:
    I am really amazed by quality of the materials generated by Face Transfer 2.
    Below is another example applied to Genesis 9.
    So it's creating normal / heught / and various shine / oil / translucency maps? That character is quite good!
    Thanks, nonesuch00.
    I like this character very much and makes me want to continue exploring more of Face Transfer 2 creations.
  • image
    I really like Face Transfer 2 but as you can see if any shadows on lips, eyebrows you can get this.  HD photos with neutral face a must (even lighting)
  • paulawp (marahzen)paulawp (marahzen) Posts: 1,796
    Face Transfer 2 shape and FT2 Base/Diffuse.
    1300 x 1300 - 610K
    Post edited by paulawp (marahzen) on
    This is one strictly for the lulz ... also does illustrate the use of morphs and a fairly extreme expression. This is Face Transfer 2 (from a source image of an older male) + varying amounts of multiple "elder" shapes and Cliff for Thimor. On top of that is a couple of JW Exaggerated Expressions. It's using the base/diffuse created by FT2.
    1300 x 1300 - 857K
    Nice creations, please keep'em coming.
    Another creation made with the Face Transfer 2.
    1200 x 1200 - 250K
    Then the look from the different angle.
    Just wonder, have you change the body morphs on the characters created with Face Transfer 2?
    1200 x 1200 - 241K
    Sure. Just that last one alone ("Angry Santa") had differing amounts of Zack 9 Elder, Julius 9 Elder, Nikolai 9 and Cliff Head and Cliff Body. Aside from one-off test renders, I don't use commercial characters in whole - I buy character bundles for the other stuff in them, and for the shapes, skins and other features (eyes, facial hair) that come with characters.
    "Angry Santa" - side view, minus Zack Elder. (As a sidenote - completely unrelated to Face Transfer 2 or 4.22, as I confirmed the behavior on Zack 9 HD in my production 4.21 Daz - there's a bug with the Zack elder shape that makes itself obvious in this side view.)
    The original FT2 character with only Base Masculine shaping added:
    1300 x 1300 - 301K
    1300 x 1300 - 687K
    Ok, thanks for the tips.
    Will need to find out, if there exist some corellation between head shape
    and shape of the rest of the body, or can I mix them freely.
    Mix away. It's just a normal G9 figure with the FT face/head shape.
    This is the dark-haired girl from above, aged down to tweens or early teens. This one uses Time Machine, and the Shaping includes only that, Base Feminine and the Face Transfer 2 shape, and a little bit of initial twiddling with her ear. FT2 seems to slightly deform some ears - haven't run into that before so I don't have a slick 'n quick process for fixing that yet.
    1300 x 1300 - 584K
    I really like when details on the face created with Face Transfer 2 just pop up.
    1200 x 1200 - 313K
    Another face with great details, here with Biker hair converted to Genesis 9.
    1200 x 1200 - 343K
  • Artini said:
    After using Face Transfer 2 a couple of times,
    I have noticed that characters usually lacks definition around mouth and chin area,
    so using a correction morphs is a must for me.
    I have converted Genesis 8 Face Transfer fixes to Genesis 9,
    but because eyes in Genesis 9 are different than from Genesis 9 ones
    applying such morphs giving a gap an eye and eye socket..
    Below is an example of Male character made with Face Transfer 2.
    after applying the corrections morphs looks much better
    care to share what morph did you use and what product(morph product) to get a more realistic lips and chin as you said?
  • videoninja719videoninja719 Posts: 344
    Also guys any guide on installing face transfer 2? I purchased face transfer 2 but I am not sure how to install it. I have daz 4.22 installed via dim. Been using daz for very long. I searched in DIM for face transfer but nothing in there. When I use face transfer in daz using a picture, it uses genesis 8. I want to use it on genesis 9. Any help appreciated
    Post edited by videoninja719 on
    It is included with the current Public Build (Beta) (4.22.0.9), not the General Release (4.22.0.1) - if you have purchased it all you need to do is enter the serial number in Help>About Installed Plugins and then restart Daz Studio to get the unlimited version.
    Another one ... had a go at trying my story series' main character. Just FT2 and Base Feminine here, and I've used both the diffuse and SSS mat files supplied by FT2.
    (Added source file, from Artbreeder)
    1300 x 1300 - 564K
    1300 x 1300 - 536K
    2048 x 2048 - 498K
    thank you, i managed to get it working, in the public build beta like you suggested. However I am getting this error "Failed to load genesis figure. Could not locate a male genesis file:data/Daz 3D/Genesis 9 Starter Essentials/Utilities/Genesis 9 Male With Basic Wear .duf , everytime using face transfer 2 on genesis 9, both female and male, it works on gensis 8 but not on 9. I already have genesis 9 starters 1 and 2 essentials installed.
     Ian McShane?
    @PerttiA: The reference image was just a random portrait generated by AI.
    I have used https://www.daz3d.com/face-transfer-shapes-for-genesis-8
    and applied them to Genesis 8 Female and Genesis 8 Male.
    Then transferred the morphs to Genesis 9 using https://www.daz3d.com/figure-converter-for-genesis-9
    The disadvantage of this method is that it produce a gap between eye and eye socket,
    so one need to use some workarounds, for example like described in:
    https://www.daz3d.com/forums/discussion/642546/released-manfriday-s-figure-converter-for-genesis-9-commercial/p5
    There are some addiitional files needed, as there is not yet an official release they are here - extract them outside your content directory and select the folder you extract to (or the folder with the zip name, depending on your extraction tool - you want the folder that contains the data folder) as a new daz Studio Format cotnent directory. When the main Genesis 9 Starter Essentials gets updated you can sdimply remove that extra content directory from the list.
    Really like, how wrinkles are coming out on the creations made with Face Transfer 2.
    Here with the converted hair to Genesis 9:
    https://www.daz3d.com/dforce-ingrid-hair-for-genesis-3-and-8-females
    1200 x 1200 - 343K
  • PhilWPhilW Posts: 5,162
    @Artini - you are doing a great job of demoing its capabilities!
  • GRFK DSGN UnlimitedGRFK DSGN Unlimited Posts: 1,126
    Mine don't seem to look that good. I've been doing mine on Genesis 9. The head seems to get squished down vertically. The ears get misshapen. And the top of the head has a slight egghead point to it. And under the chin is practically non-existent. My current fix is to flatten the top of the head and I've transferred the FTS long face morph to Genesis 9 to stretch the face out. And I've also used morphs for under the jaw line to tight it up some. I'd be curious to see what your procedure is to get yours to look so good. I did notice the interface now has a selection of Automatic, Genesis 9, and Genesis 8. I chose Genesis 9, because that was the figure I had in the scene. Should I have done Automatic instead?
    Post edited by GRFK DSGN Unlimited on
    Thanks a lot for the comments.
    Face Transfer 2 is my go to place in Daz Studio, whenever I have a free time.
    @GRFK DSGN Unlimited:
    My procedure is just testing a lot of reference images
    and choosing the ones, that gives satisfactory results in my eyes.
    What I post here, there are a small collection of the trials, I have tested.
    All my recent posts are made without any Genesis figure in the scene,
    so Face Transfer 2 creates Genesis 9 automatically.
    I only choose Female or Male.
    I have noticed, that there is some update to Daz Studio Beta in DIM.
    I am a bit afraid, if that update does not make something worse with Face Transfer 2.
    Probably curiosity will make me push to install it anyway.
