Adding to Cart…
HI, have you find a solution ? The same things happened now to me both on regular and public Carrara.
This thread is now named "Update - 8.5.1.19" but I was unable to find any information about the update...are there release notes of the current version ? I have 8.5 Pro build 243 and I am not sure if it is worth to install the latest version...can't find any relevant information. Isn't the latest release worth at least a separate sticky thread ?
(to make it clear : I am not looking for any new features, stopped expecting anything new from Carrara a while ago, just would like to get the most stable version available). Thanks.
First post has a short list of new features:
http://www.daz3d.com/forums/discussion/48629/
G3 doesn't work - so save your money .:lol:
When will Daz start communicating more clearly about its version numbers?
- in the shop, to indicate which version is latest
- in "My Account", to indicate which version I'm downloading
- in DIM, for the same reason
All it takes is one line of text, and save countless discussion threads.
still glad I have not updated
Is Carrara broken again?!?
Trying to work on a couple projects, have the newest 8.5.1.19 public buil... can't seem to load G2M natively and apply clothes to it. Starts crashing aain once i conform the hair and 2 clothing items, crashes at the Projecting Morphs 97% , with a Carrara Crashed / topped Working window ...
Having trouble loading the character as a daz studio scene sub-set as well now... grrr..... Sent in a bug reprt ticket... with screenshot...
No it's not broken again, it was never fixed in the first place :p
I've skipped back several pages and can't seem to find what I'm looking for.
Getting back into Carrara and Genesis now since upgrading to this latest version, the "Parameters" tab is missing from the main "Genesis 2 (Male and/or Female)" line, and the Parameters tab for "Actor" is empty, no matter which figure I load in from the library. Those that I've already saved as CAR files work fine.
Does anyone remember a fix for this? I thought I saw this issue a while back.
EDIT: Some screenshots of what I mean:
I don't seem to be seeing this issue. However, my loaded Genesis 2 Male appears with an additional level in its hierarchy.
Mine starts with "Genesis 2 Base Male", then I have "Genesis 2 Male".
I see parameters for the "Genesis 2 Male", "Actor", and "Head" levels of the hierarchy.
I'm running the Mac version of Carrara, if that's of any consequence.
Jeeze man, that's really wierd!
I get the same as de3an , even though I'm on Windows 8.1 Pro, and using the Postgre SQL ... In addition, I load my Genesis 2 figures from the Smart Content tab...
Having 3 levels of heirarchy + per bone, and the lower 2 being the ones where the Parameters tab shows up can be good, but also frustrating sometimes too... Especialy when your looking for something specific.
By the same token, Nomatter which of the 3 top levels I have selected and drop the clothes onto, I still have to manually select the clothing and "Conform to Genesis 2 Male" , which after conforming 3 items (ie: hair, shirt, pants) , proceeding to manually conform the 4th clothing item Carrara crashes at the 97% of "Projecting Morphs" phase.
I think that the only reason the one in my screenshot doesn't show the extra line in the hierarchy is because I just double-clicked on the file without having a scene open first. I'm pretty sure that I also have the extra hierarchy line. But the issue is the same, even when I load into an already opened scene. Somebody else was having my issue earlier in this thread, I think...
I'm sure I'll find a way to correct it. I didn't have this before the latest update. Perhaps I just need to uninstall > re-install? We'll see. I'm not scared just yet! ;)
I believe you are correct, sir.
If I do NOT open a scene first (just double-click) the extra line does NOT appear. If I have a scene opened first, then the extra line appears.
I am NOT having any issues with the parameters tabs or with Carrara crashing after I manually conform items, regardless of the number of them - I stopped at eight.
Stupid question - probably one more out of curiosity... When you've got Carrara open, Genesis2 male or female loaded into a scene natively from the Smart Content Browser, start loading clothing (before conforming to) ... How many instances of Postgre32 do you see loaded in Task manager? (Yeah i've tried the Postgre 64bit conversion from Valentine in the DIM but it never did anything) ... This is for Carrara 64bit of course...
In my own case i've seen a bunch, easily 5 or 6 Postgre32's running in Windows Task Manager when I have Carrara loaded, Genesis2, several clothing pieces, and begin to conform them one by one when Carrara ultimately crashes...
Yes, that's correct, there should be about half a dozen instances of postgres.
When I am looking for something specific I usually do this:
1. Is it a shape change? - Look under the Actor level Parameters
2. Is it a movement or expression? - Look under the top level Parameters (top level being the level just above Actor, not the group/character name level)
3. Then in whichever one I expect to find it based on the two questions above I just type part of what I think the dial is called in the filter to quickly find it
I can almost always find something right away doing this.
The dials that appear under the head are duplicated in the top level parameters, so I never use those and just use the ones in the top level.
Incidentally, if you have that group above the top level - that is, going up, you have actor, then the top level, then another level named for the character, that final level with no parameters is just a normal group (like if you selected something and hit control-g) and can be deleted without issue if it bothers you. I tend to keep it and put anything parented to the figure in there, plus it reminds me which UV set the figure was loaded with. :)
Yes, I work the same way. Works without flaw for me. Well... when I have a Parameters tab, that is ;)
One of the things I really love about Genesis 2 figures is how this is all set up. It's really quite a nice design, especially after getting to know it. But also after adding a bunch of new shapes and expressions to work with. Thorne makes those excellent head-tweak shape morphs and several artists make really great expressions that are super handy to have in the list. I really like the list filter. It makes animating really fluid for me.
:red:
Yes - I forgot that part. Very important!
Go to your DAZ 3D account
Look under your Available Serial Numbers section
That is the behavior from the build before the most recent one. It should be fixed.
--------------------------------+Sorry formatting got messed up. +-----------------------
Technically the first line is the "scene line," which is why it shows when you merge into an existing scene. The next line, you called it top line, is the "animation" line and is the rig. The third "actor" line is the "mesh" line and represents the actual polys, edges and verts. You are essentially correct though.
I find the scene line very useful as it allows me to quickly collapse a figure and all of the things that go with it on more crowded scenes.
I also the to drag and drop clothing onto the figure directly in the viewport for quick conforming of clothing.
Thanks! I didn't know the different levels/lines had actual names so I made up my own; I always prefer to know the real names of things though.
No, unfortunately, I haven't found a solution to this. Just using the old version. (8.5.0)
I don't use the FBX format, so I'm not sure if this is a real fix or not.
I tried the FBX export option with a simple cube and got the same error message. I examined the Carrara application package contents and found a file named fbx.dll in the Extensions folder with a size of zero KB. In comparison, my copy of Carrara 8.5.0.243 had a file named FBX.dll (in upper case) with a size of 4.9 MB.
I copied the FBX.dll file from Carrara 8.5.0.243 to Carrara 8.5.1.19 (renaming the zero KB one first, just in case I needed to revert back to the original), restarted Carrara and tried to export a cube in FBX format again. This time it appeared to work.
This may or may not be a fix. Just passing along my findings.
Has anyone else been able to test the FBX export work-around described in the previous post?
Just to be clear, this is a Macintosh version work-around.
Is it also an issue in the Windows version? If so I imagine that the same procedure would work for it as well.
If i know where to find an older version, i try to do this, but you cant download an older version on Daz3D. I ask on the helpdesk they say " We are aware of this issue and are working on a fix to the problem. I will let you know when I have heard any more information."
Hi! Sorry for not replying earlier. I can confirm that putting the fbx.dll file from the old version into the relevant folder of the new version of Carrara works as you said.
Thanks for the suggestion & cheers! :)
I recently had to wipe a drive and reinstall everything. On that computer I had downloaded and was running a beta version update to Carrara 8.5 Pro. I can't seem to find anything on that update. Even the Icon showed that it was a beta version. It ran a whole lot faster after that upgrade. Is it still around?
I emailed customer support about this fbx and they have not answered me back for 5 days so far.
