Ethin's Art and ... stuff.
1235789
  • Fae3DFae3D Posts: 2,908
    Ethin said:
    Sven Dullah said:
    Hahaha cool:)) Want more^^
    You asked for it!devil
    These look really amazing, and are such a creative use of morphs!  Do you happen to remember how you made any of them?  Especially the green aquatic one and the last one, those are super impressive.  I have a bunch of morphs for the Dragon 3, but I've never had much luck with them myself.
  • EthinEthin Posts: 1,331
    edited November 2023
    Thanks. I guess doing stuff like this is just normal for me at this point.
    Let see I have-
    -DAZ Dragon 3 & Morphs
    -Spectral Dragon
    -Legendary Wings & Fins
    -Crystal Dragon
    -Zilladreki
    -Wyverdreki
    Mostly I just used the Dragon 3 Morphs and the wingless geo-graft from Zilladreki. I used the arm-less morph from Wyverdreki to shrink the arms on a few and a D-former here and there as well as the spike/plate/fin add-ons.
    So mainly just lots of messing with morphs (with their limits turned off), scaling body parts and creative posing.
    "... and that is how you make a baby dinosaur"
    1203 x 882 - 446K
    Post edited by Ethin on
    Let see I have-
    -Spectral Dragon
    -Crystal Dragon
    -Zilladreki
    -Wyverdreki
    Ah, I see.  Very clever to use some of the different morphs from the separate characters!  I just sort of assumed that they just had one "breed" type morph, instead of separate morphs for arms and such.  I have mainly just tried using the basic morphs packs.  Will wishlist those products, thank you!
    I decided I should make sure I wasn't leading you astray, and I was. Sorry.
    you are correct, those characters are just full body "breed" morphs.
    The Wyverdreki does have one utility morph to "hide" the arms by shrinking them down to nothing, an effect that can be ruffly duplicated by manually selecting the arms from the collars down and scaling them, using the morph was just a quick short cut.
    I also found the geo-graft that hides the wings comes with the base figure. Face meet palm.
    edited August 2024
    ...And since I was poking around under the hood, I decided to see what else I could break. Found that with some very creative use of scaling you could change the number of toes and fingers.
    1203 x 882 - 289K
    806 x 872 - 194K
    No problem!  I go through phases where I just really want to work on dragons, so the next time I do that I'll just go back and look at some of your pictures for inspiration.  Playing around with the morphs is part of the fun, after all ^_^
    edited December 2023
    "Conversion" of @Thorne's Ksenia from Victoria 4 to Aiko 3.
    2590 x 2800 - 796K
    Fiddling with her outfit some more.
    2590 x 2800 - 835K
    2590 x 2800 - 817K
  • DollyGirlDollyGirl Posts: 2,709
    She is lovely Ethin
    DollyGirl said:
    She is lovely Ethin
    Thanks!
    Elspeth converted to Aiko 3. This one took three year and a couple tries but I finally got something I was happy with.
    ...and then things got a little crazy.
    2590 x 2800 - 824K
    2590 x 2800 - 1M
    Nelli.
    An OC I started back in 2018. Finally found the right skin texture and hair, also touched up the morphs a bit.
    2590 x 2800 - 674K
    A slightly matured version of Sarsa's and Thorne's Sylfie for A3.
    So many options to choose from.
    2590 x 2800 - 747K
    2590 x 2800 - 1M
    2590 x 2800 - 770K
  • That's a pretty amazing character you've developed there. Looks amazing. Regards, Richard.
    Thanks @richardandtracy!!
    Are you talking about tha most resent post?
  • Yep. 'Mazing. Regards, Richard
    I can't take all the credit, Sylfie's a real cutie to start with, Sarsa and Thorne did a wonderful job with her.
    I did give her a well deserved and over due update.
    Yeah, I'm probably being way too modest about all the work I put in, but I also what to show my respect for those who made the content I use.
    First snow.
    2800 x 2100 - 3M
    I wanted to do something more christmasy, everything fell through though, but here's some test shots at least.
    2590 x 2800 - 1M
    2590 x 2800 - 1M
    2590 x 2800 - 1M
    So darn cute Ethin
  • They are nice, very nice. I presume (due to a 'family' likeness) that they are all A3 based still. I remain with my flabber completely ghasted. I really don't know how you do it.
    Regards,
    Richard.
    edited January 2024
    DollyGirl said:
    So darn cute Ethin
    Thanks, both of you!
    Nah, the first two are V4, she's wear'n my free Dody character preset I converted from A3 to V4.
    A3
    V4
    That makes two of us, I look back at my own work and am astounded, "how can that be mine?", even though I clearly remember making it.
    I have two time-laps videos on youtube of me doing characters if you want to see the process (v link in my sig v).
    edited January 2024
    Trying to change the Wild Gas Station over to 3DL, had to strip all the mats down to just diffuse and opacity, and turn half the props off so it would render in a timely enough manner so I could rough in the lighting. So this is basically just a lighting test.
    It took 4 hours to render, anything I do from here on in will just increase the render time. If I use IRay it only takes 7 minutes. So I spent around 12 hours just to make the render take 34 times longer.
    I'm starting to wonder If it is worth the time and hassle for me to continue to use 3DL, and a 96 core cpu is a bit out of my budget.
    {rant mode: Actually any cpu better than the one I've got is out of my price range. My drives are so full to install something new or paint a new texture I have to remove something else. I had to pull the front off my computer and duct-tape a fan to it because the case is too old to support the cooling system my components need.}
    Sorry, I think the low light is starting to get to me.
    1820 x 1024 - 845K
    edited January 2024
    Also converted SV7's Anna over to A3.
    2590 x 2800 - 840K
    Hahaha, I know I know! It's normal procedure for me to spend days on a scene to reduce rendertimes by some minutes:))) But it's educational lol...
    It sure looks nice, though! What's the culprit? Lots of opacitymaps? UE2? Insane rendersettings?
    smiley
    smiley
    Thanks! Still a lot of work to do, and if I ever get around to doing the image I wanted to do I'll probably end up changing the lighting anyway.
    Yeah, it's all those tranz-mapped clumps of plants. The ones visible in the render are part of the foreground landscape, and then there are about a 1000 more I hide that are stand alone props (I'm so glad they were parented to a group so I only had to hide one thing).
    I had another image in mind I tried to do just before NewYears but ended up scraping the idea after blocking in the main scene because I realized 3DL wouldn't like it (a tranz-mapped pine forest and a bunch of point lights as the main light sources).
    smiley
    Hm, sounds like a nightmare. You may have noticed I avoid transmaps like the plague;) Did you turn off occlusion for the offending plants?
    Yes. But I've only seen occlusion in UberSurface and UberEnviroment2, so unless your using UE2 and one of the occlusion options does that actually do anything?
    edited January 2024
    No, unless you use GI like AoA ambient or IBLM , both of which use Ambient Occlusion. And the AoA lights can be flagged to use alternative shadow/SS samples, which probably makes a difference in cases like this!?
    Edit: So I looked at the promos and see what you're talking about:) Don't believe you can cut rendertimes to 7min whatever you do lol.
    One thing you could try on the transmapped foliage is to use the opacitymaps also for diffuse strength and specular strength. Might or might not shave off some time...
    Post edited by Sven Dullah on
    edited January 2024
    I tried your suggestions and it did speed things up but it also made the plants a lot darker.indecision
    I also decided to try replacing the transmapped plants with full poly ones, I tested it with the render I "scraped" because 10 trees sounded easier to replace than hundreds of bushes. I found a pine tree with "real" needles then spent 6 hours untriangulating it to cut the poly count down, so much for easier.
    Another lighting test, took 3 hours, with the transmapped trees 3 hours only got me half way to the upper most star and one of those hours was spent on just a single row of buckets. Navigating the scene sucks because of the poly count but at least now it'll render in my lifetime.
    2590 x 2800 - 2M
