• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
How do I make sabertooth teeth for HiveWire Tiger for Daz3D?
SasaSasa Posts: 15
February 2023 in Blender Discussion
Hello everyone, I am here to request add on how to properly sculp sabertooth teeth I can scale a bit size wise for the product HiveWire Tiger located here: https://www.renderosity.com/rr/mod/bcs/hivewire-tiger/144304/ I am hoping it will look something like this: © National Geographic Thank you for reading!
  • felisfelis Posts: 6,645
    February 2023 edited February 2023
    I would model it instead of sculpting it.
    Added: I have no idea of actual dimensions of a saber tooth, but a quick version could look like this.
    599 x 703 - 100K
    Post edited by felis on February 2023
  • 3WC3WC Posts: 1,171
    February 2023
    https://community.hivewire3d.com/threads/saber-tooth-morph-for-hw-big-cat.4607/post-228776
    622 x 774 - 663K
  • SasaSasa Posts: 15
    Hiya! I replied to you on the other thread but I agreed with the other persons reply. Its a bit too thin for it to fit a sabertooths teefers. Thank you tho!
    That looks great! I am not exactly sure how to model it though... :/
    Post edited by Sasa on February 2023
    February 2023
    I don't know how familiar with blender you are.
    I did the following.
    I added a cylinder with 16 verteces and no end caps, and scaled it down to the base size, which I choose was 2 cm.
    Then I extruded it upwards till around 8 cm.
    Then I filled the upper end cap with quads, and with proportional editing and small radius i pulled it upward a bit.
    Then I scaled the top in so I had the general shape, and then added loopcuts.
    Then I smoothed it the loop tools > Relax
    That gave me the straight tooth to the left.
    Then I duplicated it, placed the 3d cursor at the bottom, and with the top vertex selected, and proportional editing enabled, I rotated in the Y direction and got the final result.
    All in all, less than 5 minutes.
    872 x 665 - 173K
    February 2023
    Ive never made anything in blender tbh... Is it possible you could share that file? (⁠;⁠ŏ⁠﹏⁠ŏ⁠)
    February 2023
    I have attached the obj file.
    You must be aware of that blender and Daz Studio differs in world orientation and scale.
    Daz Studio has X-Y as a flat picture and Z is depth, while blender has X-Y as the ground-plane and Z as height.
    Daz Studio has 1 cm as unit size, while blender has 1 m.
    For my obj I use Daz Studio orientation and blender scale, so in order to import in Daz Studio I use the attached settings for import into Daz Studio.
    The object will load at world origin. To place it I recommend Universal Tool, and in Tool Settings set it to use object coordinates. It will make it easier to position (I don't have the Hivewire Tiger). You might want to scale it too.
    When you have placed one tooth, duplicate it. And to mirror along the X-axis use the values from the first tooth as
    Translate: -X, Y, Z. Rotate: X, Y, -Z
    And when placed parent them both to the head. I would assume that that should work.
    365 x 370 - 14K
    zip
    zip
    Sabertooth.zip
    7K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
