Genesis 3 and 8 to 9 Pose Converter (Commercial)
1…34689…12
  • parshkov said:
    I don't understand how to make shortcut or how to add it to menu
    The video in the first post explains it
    https://www.daz3d.com/forums/discussion/591191/genesis-3-and-8-to-9-pose-converter-commercial/p1
  • Zev0Zev0 Posts: 7,123
    edited November 2022
    Please look at promo 1 or watch promo video on the prodcut page, or link in first post of the thread.
    Post edited by Zev0 on
  • Zev0 said:
    Update is now live. Script version should read v1.1. Please refer to first post in thread for change list. Thank you all for your support.
    Nice update.  Now we need breast control for G/V9 so I can make them bouncy wink
    Ye busy on Breast Control among other stuff lol...
    laugh
  • HavosHavos Posts: 5,704
    mossberg_7e7b58e40f said:
    Hi
    When i use this script, the Genesis 9's Hip's X, Y, and Z Translate Sliders become too sensitive
    Even if I move a little, the figure goes out of the screen.
    only Hip, other axis is looks ok
    DAZ version: 4.21
    I have seen this behaviour before. It happens when limits are switched ON for the x, y, z translation, rotation etc. Normally limits are OFF for the hip and top level, but ON for all other bones. Maybe the script sets the limits on in some cases?
  • This program works perfectly for me, allready have a lot of poses changed from gen3 and 8 to gen 9. Minor tweaking but easy to do, thanks for making this product.
  • edited December 2022
    Hi
    DAZ version: 4.21
    It's the same result whether you turn Limits on or off.
    when i save it as a Scene  with problemed figure and check it with Dson editor, the duf file  clude value 'clamped boolean true' in hip node
    i think it can't find in hip node normally
  • I noticed when I was using G9 with out added morphs that the script was working fine but now after I added all my morphs from G3F and G8F daz just freezes after it converts the pose to G9.  I transferered the morphs via transfer utility is there a work around for that?
  • Redownloaded product working fine now keep up the great work zev0.  only thing I wish I had was more skins for G9
  • RyderRyder Posts: 28
    Well the script don't work for me at all right now, it was working when i first time use it but now it's just don't do anything.. anyone have the same problem? or what is the fixes? thanks.
  • victorvictor Posts: 49
    Using the script from the menu no longer brings up the window with pose options.
    Double clicking it within Utilities does.
    I removed and re-added it to the script menu.
    I double checked to make sure there was not more than one pose selected.
  • SevrinSevrin Posts: 6,314
    Thinking ahead, a lot of G9 content has been pose sets.  Some days, the only G9 content are poses.  Is there a possibility of converting G9 to G3/8 in the future?
    Yep..we have it blue printed already.
    Hey, how can you even get it to work? Many times i unnistall and reinstall the product still no any fix. Also how to remove it from scripts menu? this problem really ruins everything for me. I was about to make a scene, and now i can't...
    Batch Converter has been released due to high demandyesThank you all for your continued support.
  • Works like a charm - I love it!
  • vwranglervwrangler Posts: 5,049
    Thank you so much for making this! From the early comments, I'd thought there was no interest, so I'm very glad to see this.
  • edited January 2023
    Hmph .... When installed product script is selected, installed product shows error that installed product is not installed.  I installed both via Install manager and then manually via zip.
    Any thoughts?
    Post edited by lancelmartin_cf51987037 on
  • MartialMartial Posts: 431
    Too bad The script don't work for me also
    I have DAZStudio 4.21.0.5
    i have installed and reinstalled manually,and tried with DAZ Instal Manager, Failed  -see capture screens __oups uploading still don't work
    Here my files and folders structure
    D\DAZStudio4 64 bits\Scripts
    Most of my files for scripts and files in runtime fold are there i my main DAZStudio soft exe:
    D\DAZStudio4 64 bits\My Library\Scripts
    D\DAZStudio4 64 bits\My Library\Runtime
    There where i have installed
    Few files are here:
    i also hasve another library in
    E:\DAZStudio Library\ My Library sur E
    where some scripts are in Scripts folder
    Some suggestions please  Thanks
    OK forget my comment this script works
    i make confusion with
    88686-01_Genesis3and8to9BatchPoseConverter
    this new script don't work for me
    Few files are here:
    Send me a log please.
  • Hi, I experience the same problem. Sent you some info via Message.
    edited January 2023
    Update from our side, we think we found a solution to the rapid figure rotation issue regarding limits. If it works as intended we will be doing a product update.
    Guys, a lot of people are sending us issues and this is because the base product is not installed. It is a requirement for the batch converter addon to work. Please make sure it is installed. Thanks
    edited January 2023
    Few files are here:
    "i also hasve another library in
    E:\DAZStudio Library\ My Library sur E"
    Looks like you have nested libraries. EG a library within a library. But a log file would help. Thanks
    edited January 2023
    Yhanks for reply
    Ok i will try it again this week end and send you the log
    I failed to see the requirements, thanks.
    edited January 2023
    But i use this folders structure for around 3 years now and all my others contents work ok All these are indicated in the content directory manager in Preferences
    Few files are here:
    Few files are here:
    Nested content directories (one inside another) cause problems because Daz Studio doesn't knoww hich to take as the starting point for relative paths - should a texture  in the inner folder be listed as /Runtime/Textures/Someflders/someimage.jpg or /My Library sur E/Runtime/Textures/Someflders/someimage.jpg - though that may not be apparent until the file is opened on another system.
