Adding to Cart…
I'd be really curious to see how emitter-lit scenes compare to uberarealight-lit scenes, since the two features do fairly similar things. (Though in vastly different ways)
Maybe I'll experiment with that...
When you see these two there seems to be little to choose between them. When I saw renders done with Lux the difference was night and day.
CHEERS!
Greetings,
While the first is probably more powerful, the second is exactly the card I went with. It should arrive this afternoon sometime, and hopefully I can install it tonight and try it out.Good thing I keep a Windows box around as a render slave... ;)
-- Morgan
Greetings,
CHEERS!I'm fairly confident that the two renders are using the same render engine, just different SSS shaders on the skin. That is 'Iray is a bit faster' means 'The Iray skin shader applied to the skin makes the render a bit faster.' If I'm wrong, I'm sure the author will let me know.
Note the 'I stopped both renders at 83% (CPU only)', which strongly implies both were done in the Iray renderer, as stopping a 3Delight render after 83% would look very different. :)
-- Morgan
Yes fox, both were rendered in Iray, only the skin shader is different.
Looks very good, also makes me want to buy the set now
Yes; it light the Scene but the Sky (Clouds, Stars, Sun and so on) did not show up in the final Render; it only chance Color from black to Brown or yellow and White - depending on the value of the Luminance.
Try setting it way up in strength. Like 50 K
Kat
this is what happens with a Maximum Luminance of 10000000000; no Sun, no Clouds...
Can you screenshot your environment and Emitter settings? :)
Kat
Oh, my bad, well, what does the same scene rendered with 3Delight look like then? I want to see what differences there are.
CHEERS!
Oh I like those!! Now I need to see if I have that set or if I am going to be shelling out more money. LOL
Nice job. :) I really like it.
Kat
I posted this elswhere also, but this is a quick test render just to get a feel for the Iray renderer. Laptop, i5, 8gigs ram, The laptop has no nvidia card so it took longer to render, but the results still show promise. I did have the extra cooler fans running though.
I wanted to render a scene made and saved in 4.7. I removed all the old lights but want to move the sun position/angle. Is there an easy way to do this ? I can't see the sun listed in the Scene tab, although the light is there when I render.
This one took just under 54 seconds to render (2GB card). Simple, but I like animals.... lol It took longer to find the branch in my content.... *sigh*
Kat
Sweet ride. :)
Kat
CHEERS!
Keep in mind:
Just using the iray uber shader converts it from a 3delight-compatible shader over to a similar base with the iray dials to work on. It is nowhere near the final product and really doesn't take advantage of any iray features. the shader is a generic shader for everything, not just skin. So no it's not a fair representation.
Also we're just clearing the 1 full day of people playing with the renderer, so there won't be any midblowing results.. especially when it comes to skin. People said the same thing about luxrender, and there was more work on that before actually playing with 3delight settings. There really wasn't a real push to learn materials settings for skin using 3delight until Genesis released and the switch from gen4 characters that had basic DS settings were more common.
Are you actually using this build as others in this thread?
Ok, now we're getting somewhere. It's clear Iray has potential and this is the only render I've seen that has truly shown that.
Nice going
CHEERS!
Is it not possible in Iray to change the strength of lights and the ToneMapper whislt it is rendering, for real time update of lighting changes in a scene.??
S.K.
There is no question that there will be a good deal of raving about Iray for the next while. There was a good deal of raving when Reality, Luxus and octane became viable render paths. But there will always be people who need a render engine like 3delight. Some people don't render for realism like manga and toon users. Some people are just here to play around a few hours in the evening and want quick gratification. Some people do a base render and then do magic in post. DAZ is not going to stop selling them content and isn't going to try and run them away just because they ADDED a new render engine. Some people will try Iray and love it and never go back. Some will try it and like it but not well enough to change over. I think the really big up side for all the customers will be that in order to look good in Iray content creators will need to be held to a higher standard. Castles will need to look realistic in Iray so they will look more realistic in 3delight as well. I think in the long run it will be a win for everyone no matter which engine they pick that day.
Well said. I like realism like the next person. Truth is everybody knows it's a 3d render in the end especially for human subjects unless you're totally blind. With that, I've enjoyed the progress 3delight continues to make especially in this release. things are much snappier and faster than what they were just one year ago. For animation, which is what i'm getting into these days, physical renders have a long ways to go at the same time I've seen render times dropping dramatically for 3delight even with SSS skin and hair in the scene. The IPR rendering appears much improved from last version too for 3delight. 3delight is here to stay and has its place.
Are there any charts available showing the appropriate Emission Temperatures and Luminance values for duplicating real-world lighting? For example, what values to set for candle light, light bulbs, a flashlight, ceiling lights, etc. Thanks.
The Iray sun doesn't appear on the Scene tab. You can either use the settings in the Environment section of the Render settings pane, or use the Sun Dial Set in the Iray Uber Defaults content.
http://en.wikipedia.org/wiki/Color_temperature
OK thanks, so it seems it really is only global.
I've got a lot of practice fitting scenes into my Vram so I'm not worried there.
CHEERS!
You can try it if you place two uberlights one behind the figure emitting cold bluish light and the other in front of her emitting warm light.
I have now closed the scene and I´m rendering the figure in another enviroment.
You can also use uberenviroment to make the overall result look better but I didn´t use dome in iRay so the only light source in the scene were really the two mesh lights.
No, I'm not, I do have 4.7 but am busy with other projects and haven't had much chance to use it yet. Kat's render is impressive and if more follow in a similar vein then my reticence may well fade. It doesn't seem that long since 4.7 came out and we're already hurtling towards another build before the dust has settled on 4.7. I need time to adjust and I just hope that, by the time I'm ready to get back into this full time there will be a version of DS that I can fully get used to before another arrives.
CHEERS!
Not during the final render, but it is possible in the Viewport. Therefore you have to set the Viewport preview mode to "Iray Preview". Then you will see the image as it will look like rendered and you can do all the tonemapping and light adjustments.
But be warned: If you do not have the right grapics card and have to run Iray in CPU mode, things are getting veeeeeryyyy sloooooow here. So it is not nearly as comfortable as it is in Luxrender.
I'm attempting a simple scene, one done with arealights, the other done with iray emitters, trying to be as similar as possible (with appropriate material/shader changes).
Never mind,
I don't use the DIM and will maybe get this when it hits full release. What I'm doing now is assessing what advantage that build will be.
CHEERS!
Kat
Kat
with Emitter Settings you mean the Emission Tab?
It isn't really realtime though, you pick something and it starts to render. So its still an improvement for some people but it's not the same "Realtime" that some are used to.
Like if I am changing the position of the sun, the viewport changes back to the flat shaded view while I am sliding the dial.
Huummmm,,
Thanks for the Info guys, so not as versatile as Luxrender or Octane Render in that department, I will no doubt give it a spin once DAZ 4.8 goes general release status, but I cannot invisage this replacing either Luxrender or Octane render for me yet...!!!!!
Maybe if it is developed further, or if the Iray interactive renderer can be incorporated at some point in the future, then possibly...but it is a promising start, and of course Free.!!!
S.K/
