• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…25262728293031…49»
  • X3DX3D Posts: 30
    February 2015 edited December 1969
    Hi Casual.. I noticed what might be causing the problem.. On Auxiliary Options / Process Materials.. the save option is set for .blend and not .mtl?
    When Blender opens the figure, the path for the specular textures are correct apart from a pink sheen across them .. when checked in the Node Editor the Diffuse path is unavailable resulting in the pink colour.
    Very odd.. maybe the path saves from previous version are conflicting? no idea really :)
  • mCasualmCasual Posts: 4,607
    February 2015 edited February 2015
    DecadentUK said:
    Thanks for the quick reply Casual.. I shall experiment further, I did notice that after deleting version 2 and replacing with version 3 in both Daz Studio & Blender that the save paths for Blender.exe + blend/obj/image files were still present, from previous version, are these paths saved somewhere? If so I may need to delete them?
    Maps were collected so its slightly confusing..
    Version 2 does everything perfectly though. Thankyou again for this great script.
    the settings are stored and retrieved by the Windows registry [ or the mac's equivalent ] in a section named mcjteleblender
    but you would not really gain anything by deleting tke key values
    mcjteleblender has a ''restore defaults'' button which puts it in the default state
    unrelated image
    800 x 800 - 80K
    Post edited by mCasual on February 2015
  • X3DX3D Posts: 30
    Hi Casual.. I did use the "restore defaults" but get the same results.. when I resort back to Version 2 all is fine.. Going to try using mcjBlendBot2 with mcjteleblender3.
    That has solved the problem! by using the blendbot from version 2. BTW what is mcjShareTheTextures.py and should this be included in Modules folder?
    Post edited by X3D on February 2015
  • ajd_at_072df9a27dajd_at_072df9a27d Posts: 60
    I had the same confusion with mcjBlendBot .
    The latest version of mcjBlendBot is for Teleblender2 and Teleblender3.
    Hi Casual, and noticed that from DAZ version 4.5, you can export only the selected objects as objs.
    // Do not limit export to selection - only available in 4.5.x +
     oSettings.setBoolValue( "SelectedOnly", false );
     // Do not limit export to the selected roots - only available in 4.5.x +
     oSettings.setBoolValue( "SelectedRootsOnly", false );
     // Do not limit export to the primary selected root
     // This setting overrides SelectedRootsOnly - only available in 4.5.x +
     oSettings.setBoolValue( "PrimaryRootOnly", false );
     // Do not export items that are parented to the selection - only available in 4.5.x +
     oSettings.setBoolValue( "IncludeParented", false );
    Quite useful when working with mdd.
    mcjShareTheTextures was made following a request
    it's standalone
    to run standalone python scripts in Blender
    you open a Text Editor panel
    then you load the script
    then you click the Run button
    i dont know if it still works but
    it's supposed to merge together materials that use the same texture images
  • RoygeeRoygee Posts: 2,247
    March 2015 edited December 1969
    Hi Casual:)
    I'm using teleblender successfully in Blender 2.73a - working very well, thank you.
    Qusetion on animation - I can export an animation and it makes an .obj per frame, but does not open Blender automatically. I can open Blender manually and import any of the singles frames, but can't figure out how to open the .obj sequence.
    Any help, please?
    March 2015 edited March 2015
    Roygee said:
    Hi Casual:)
    Any help, please?
    when you use teleblender's 'export animation" button
    teleblender exports each scene-frame as an .obj
    and it creates a .bat file
    if you double-left-click on that batch file
    an invisible Blender will render each .obj/scene/frame
    one after the other
    which can take hours -
    note that in teleblender before using the 'export animation" button
    you must specify which frames are exported
    and which frames will be rendered
    when you use the teleblender's "export current frame" button
    teleblender launches a ( visible) blender
    it also produces a .bat file which could be used at a later date to
    re-open the same scene in blender, independently from Daz Studio
    i didn't write teleblender thinking i'd want to open individual animation frames in blender
    but you could open the .bat is a plain-text editor like notepad
    and you will see a series of text lines which look like
    "I:/blender/blender-2.72b-windows64/blender.exe" -b -P "I:/tmptmp/scene.py" -f 0
    "I:/blender/blender-2.72b-windows64/blender.exe" -b -P "I:/tmptmp/scene.py" -f 1
    "I:/blender/blender-2.72b-windows64/blender.exe" -b -P "I:/tmptmp/scene.py" -f 2
    "I:/blender/blender-2.72b-windows64/blender.exe" -b -P "I:/tmptmp/scene.py" -f 3
    "I:/blender/blender-2.72b-windows64/blender.exe" -b -P "I:/tmptmp/scene.py" -f 4
    the number at the end is the frame number to render
    the "-b" part is what causes blender to run in invisible mode and immediately render the frame
    if you want to open frame 4 in Blender in Visible mode, and not immediately launch the render
    then you could write ( with notepad ) a .bat file which looks like
    "I:/blender/blender-2.72b-windows64/blender.exe"-P "I:/tmptmp/scene.py" -f 4
    when i render animations, what i usually do is
    use teleblender to render the first frame ( not in animation mode )
    adjust the materials and the lighting in Blender
    save this blender scene as myMaterialLibrary.blend
    delete all the objects except the lights
    save this blender scene as myEnvironment.blend
    close Blender
    then in teleblender
    set "Render Engine" to "Scene file", and specify myEnvironment.blend as the scene-file which will be re-used
    and
    set "Process Materials" to "Use mat-lib", and specify myMaterialLibrary.blend as the materials which will be re-used
    and turn Off the Export lights option since we'll be using the ones in myEnvironment.blend
    export the animation
    use the animation-rendering .bat file to render all the frames
    Post edited by mCasual on March 2015
    Thanks for that detailed info :)
    Being as curious as I am, I hit the .bat file and got this - only about 20 min.
    Next time I'll do the whole process as you describe :)
    http://youtu.be/7TeeYm3q0RY
  • IsamuDysonIsamuDyson Posts: 27
    I finally got around to taking the same model I rendered before and rendering it again using an HDRI. Only problem was with Youtube's compression. It really messed up the video with the background in it. So, I put a link to the original AVI videos for others to look at uncompressed. There's a big difference in the quality of the original AVI and the Youtube version. I wish Youtube had quality streaming like Netflix.
    https://www.youtube.com/watch?v=U9mbWBj2TrM
    https://www.youtube.com/watch?v=LJsjDvVyLDc
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    1920 x 1080 - 2M
    Post edited by IsamuDyson on March 2015
    looks good to me !
    recently i tried adding a simple bump map like this one here
    and it's very subtle but it does change the way the surface diffuses the light
    it also seems to soften the shadow lines
    in Blender if you reduce the "size" parameter of the lights, from 1 to .1 or from 0.1 to 0.02 it makes the shadows crisper
    and probably improves the 'rim lights'
    second bmp map is the same, but i ran a photoshop high-pass filter to remove the apparent tiling
    but it's hard to handle, like on the bent shoulders that stretch the bump map
    772 x 999 - 394K
    1500 x 2000 - 2M
    1500 x 2000 - 2M
    1544 x 1000 - 701K
    Casual said:
    looks good to me !
    Yeah, that bump map does help.
    When I get a little more time, I'm wanting to try out this skin tutorial on Blender Cookie. http://cgcookie.com/blender/cgc-courses/skin-shading-cycles/ If I can apply those techniques to this model it should really add some realism. This one is free but it isn't as in depth of a tutorial. http://cgcookie.com/blender/cgc-courses/creating-a-realistic-head-in-blender/
  • greg017greg017 Posts: 11
    April 2015 edited April 2015
    Am I doing something wrong or does teleblender not import bump maps
    I can't seem to get it to work.
    I thought I had it going once before.
    It seems to work for objects and clothing but not for skin.
    Even if I have a material library blend with the bump maps setup, they get removed in the import.
    Thanks Greg
    Post edited by greg017 on April 2015
    Thanks Greg
    testing it ...
    first make sure the bump map works in Daz Studio software render
    bump strength 100%, Max = 2cm
    for my first test i used mcjTeleBlender's "collect maps" option
    which relies on Daz Studio's built-in exporter
    it correctly exported a copy of all the texture files into a Maps folder
    located where Daz Studio creates .bat, .py, .mtl and .obj files
    in my case I:\tmptmp\Maps
    in blender things didn't go well, textures were gone
    then i inspected the materials and saw that Blender was looking for them in C:/maps
    which is not the correct location
    i opened the scene.mtl file and saw that the image locations are specified like
    newmtl Cloth_1
    d 1
    Ns 0.85
    Ni 0
    Ka 1 1 1
    Kd 1 1 1
    Ks 0 0 0
    Km 0.00048
    map_Kd /Maps/mcjsball2x.jpg
    map_Bump /Maps/TankTop_Bum.jpg
    in the past i'm pretty sure Blender interpreted this as meaning "the file is right here in this folder, in the Maps sub-folder"
    which in this case would be "I:\tmptmp\Maps"
    but recent versions of Blender seem to have changed ( probably with good intentions ) the way the obj/mtl files are imported
    and now Blender thinks \Maps means C:\Maps
    my quick fix for this render was to copy the content of "I:\tmptmp\Maps" to "C:\Maps"
    another way could be to not use the "Collect Maps" option
    because we then get MTL files which look like
    newmtl Cloth_2
    d 1
    Ns 0.85
    Ni 0
    Ka 1 1 1
    Kd 1 1 1
    Ks 0 0 0
    Km 0.00048
    map_Kd I:/aoa/mcjHoney/New folder/mcjsball2x.jpg
    map_Bump C:/Program Files (x86)/DAZ/Studio/content/Runtime/textures/Idler168/V4A4Clothing/TankTop_Bum.jpg
    so the location of the image files are specified so precisely that Blender cant miss them
    another patchy way of solving this would be to copy an old version of Blender's built-in obj importer
    and paste it over the one of your new version,
    ( the file C:\Program Files (x86)\Blender Foundation\Blender\2.71\scripts\addons\io_scene_obj\import_obj )
    but that's not an ideal solution
    --- Other things to look for ---
    maybe none of the above applied to your problem
    if your bump image is not a jpg file, but instead a tga for example
    try converting it to jpg , because Daz's exporter sometimes exports images as jpg and tells blender to use the .tga
    also, if the bump file filename contains characters other than letters and numbers
    ( blank spaces, hyphens ) this may prevent Blender from finding it
    and if the file is located in a folder with a 12 ft long path with spaces and things
    then you could try placin the file in a simpler location like C:\Users\YourNameHere\Documents\Maps
    BUT WAIT
    the bump map is still not there !
    800 x 600 - 144K
    Post edited by mCasual on April 2015
    Thanks Greg
    maybe Blender doesnt understand the word "map_Bump" anymore"?
    looking into this ...
    ok i found out Blender's mtl/obj importer only understands the word "Bump" not the word "Map_Bump"
    and i think mcjTeleblender's "Fix .mtl for Blender" option is in charge of this
    and is not doing its job anymore !
    the case continues
    https://www.youtube.com/watch?v=f2gNV5l_seY
    turns out that a few weeks or months ago i added the
    / in front of the /Maps/ paths because Blender 2.71 seemed to require it
    but it was probably not the right thing to do
    and in teleblender3 i dont see the code which made Blender happy
    by replacing the word "Map_Bump" with the word "Bump" in the material file
    just to make sure i'll do just that "by hand" right now ....
    * i close Blender, open scene.mtl in wordpad,search and replace Map_Bump with Bump
    * save
    * re-open the scene by double-left-licking on scene.bat
    it didn't work !!!
    maybe them suspiciously missing quotation marks?
    Thanks Greg
    Ok i located the problem
    in a recent mcjTeleblender3 update it seems that i removed or sidelined
    the function ( FixMtl ) which takes the mtl file produced by Daz Studio's exporter
    and prepares it for Blender
    if notably changes the word "Map_Bump" with the word "Bump" ... ( not sure 'bout that anymore )
    it adds quotation marks around the paths to the images
    one odd thing is that Blender doesn't seem to care about missing quotation marks for non Bump textures
    the short version is that i'll have an mcjTeleBlender3 update this afternoon
    960 x 540 - 163K
    960 x 540 - 129K
    1024 x 768 - 135K
    by default, mcjTeleBlender3 will now, leave quotation marks in the .mtl files
    even when the "Fix Mtl for Blender" option is used
    but in case this is required for other situations ( some software do like their filenames unquotemarked )
    there will be a checkbox to re-enable quotation marks removal
    stay tuned, the update is coming up next
    812 x 455 - 100K
    UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE UPDATE
    - V 3.08 - V 3.08 - V 3.08 - V 3.08 - V 3.08 - V 3.08 - V 3.08 -
    Only the script was updated, no need to touch blendbot
    Apr 8, 2015, 12:54 PM
    removal of the quotation marks from the .mtl file during the "FixMtl" call is now optional.
    There is a checkbox in the "misc" section of the Third tab to re-enable it
    https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    This should fix the cases where the bump maps didnt make it to the blender scene
    ( though i didn't ascertain why it didnt affect other maps )
    tip : to make the shoes brighter i set their diffuse color value ( HSV ) to 1.33 instead of the usual 1.0
    1280 x 720 - 408K
    April 2015 edited December 1969
    Thanks heaps for that.
    Downloading update now
    oops i just realised i made all my tests in DS3 !
    i'll make sure it works in DS4.7, DS4.8
    looks like it does !
    photo of a slice of breas applied to a Daz Studio primitive-sphere
    DS4.7 - 64bit - Blender 2.71 - 64bit
    1920 x 1080 - 405K
    Ok I think it's DAZ after all
    I try and do a straight export of a gen 2 female and the only parts that get bump maps are the mouth parts.
    All other parts get exported without the bump map.
    Tried this with several different characters and that's as far as I got.
    Any ideas anyone??
    Ok I have worked out a way around it.
    I have a blend file that originally had two characters in it.
    I worked on the figures adding bump maps to improve the textures.
    This was working fine. I then deleted one character from the blend file and tried to use it.
    The problem was all the materials had names like Toenails_Vicky etc I then tried to import a single character scene which only had names like Toenails. Thus the Toenails_Vicky didn't match and my materials weren't being used.
    Rename the Parts in the material blend file and it all works as expected.
    I should have realised.
    May help someone in the future though.
    The direct DAZ export problems still remain though.
    THanks Greg
    you could try some other random gray image as the bump map
    and see if it's because the file is too big or the file-path is too long or contains 'illegal' chracters or is not in jpg format
    note that teleblender is better at handling default daz materials
    maybe maybe teleblender cant find the bump map in the skin shader
    because the shader doesn't use the word "Bump" and Bump Strength
    if you know how to do this, try replacing the shader with the default Daz Shader , or shaders that look like it
    in the image below you can see how mcjBlendBot creates materials that include bump maps
    it creates a multiplier node and plugs it to the displacement input of the output node
    then it creates an image node and plugs it in the multiplier node
    the UV map setup is possibly superfluous
    1920 x 892 - 449K
    i did a test just now and indeed the genesis 2 shader doesnt get its bump map transfered
    i will have a solution for this
    i just have to teach teleblender how to find the bump map in that type of shader
    if you look at the mtl file that gets exported from daz studio
    you can see that the daz studio obj/exporter supplies very little information about materials using this shader (omUberSurface)
    mcjBlendBot was counting on the mtl file to contain the bump map but it's not there
    mcjTeleBlender does look for bump map settings, but it too was counting on the exporter for the transfer of the bump image
    the easiest option ( for me ) would be to change the surface shader to DS Default
    but but, since this is 2015, i'll update mcjTeleBlender to work well with Genesis2 !
    newmtl Legs
    d 1
    Kd 1 1 1
    map_Kd C:/Program Files (x86)/DAZ/Studio/content/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsM.jpg
    tech note : the
    omUberSurface bump channel names are
    "Bump Active", "Bump Strength", "Bump Minimum", "Bump Maximum"
    Ds Default bump channel names are
    "Bump Strength", "Negative Bump", "Positive Bump"
    In the upcoming version of mcjTeleBlender/mcjBlendBot
    when we detect the presence of a bump map
    we will transfer the bump map path and bump parameters using a statement in the scene.py file
    ( nope not by modifying the mtl file )
    mcjBlendBot.setBumpMapStrength2(
    'C:/Program Files (x86)/DAZ/Studio/content/Runtime/ ...V5BreeLimbsB.jpg',
    'Genesis2Female',
    'Toenails',
    0.05 )
  • Dean_2026310Dean_2026310 Posts: 22
    Hey , Im using blender 2.74 and daz Studio 4.7 , Everything is coming across purple , even when the maps are collected , I think blender does that when the textures don't get applied correctly , I could manually apply all the texture , but I guess that defeats the point of the scripts you wrote ? I am at a loss.... Has any one else got 2.74 working ?
    This is the same with both Mk 4 & both Genesis types.
    Post edited by Dean_2026310 on April 2015
    O.k , so basic primitives with your daz shader presets applied and lights and cameras come across perfect , which is amazing in itself !! but I can't seem to get textures transferring across on figures. Just all this crazy purpleness........mmmmh
    it shpuld be ready this evening
    here's a render
    the bump map once in Blender had a strength of 0.05 which looked too harsh on close-ups
    so i reduced it to 0,02
    but at a greater distance and with the jpeg reduction of crispness we don't perceive it much
    now that the onUberSurface bump maps makes it safe and sound to Blender
    i'll see if i can fix other issues
    ( the issue wherein, by default, Gen2 get zombie white eyes )
    Fig 2 - ambient strength support added for shaders
    1902 x 610 - 542K
    960 x 1920 - 303K
    you could try yesterday's update of the mcjTeleblender script
    just the daz script
    ( though later today the update will involve the mcjBlendBot kit of Blender scripts too )
    Hey , I'll wait till later.... I'm in England so It's 1 o clock in the morning at the moment.... !! I was up to date on the scripts.. But still a whole lotta purple. I'll give it a go tomorrow and see how its working , Cheers buddy.
    the omUberSurface shader uses "Active" on/off switches on many surface properties
    and it so happens that the eye materials for genesis have 100% strength specular settings
    .... but the "Specular active" switch says 'Off'
    so to avoid white zombie eyes in Blender, mcjTeleBlender will now
    be on the lookout for shaders with "specular active" switches
    and act accordingly
    that's a Blender Cycles render immediately after applying the Genesis2 Bree materials
    the only tweak i did was to add 15% light-cyan Ambient light to the Irisses
    You'll notice that the Bump map strength is too high,
    on close-ups the skin looks like sandpaper
    but i'll leave it to you to adjust it either in DS or in Blender
    presently a Bump Strength in DS of 25%, Min/Max = -0.1, 0.1
    in Blender becomes Bump Strength = 0.05
    the formula i used BlenderStrength = DSMax - DSMin * DSStrength
    note: sometimes the bump map effect is not very visible
    BUT it can help hide the polygon edges !
    Cycles is physically based and the angle between adjacent facets
    of a figure can become apparent, notably on very long renders
    where the render "noise" is not there to hide this
    i wonder if a 0.25-pixel wide gaussian filter would be appropriate on that image to soften but not erase the bump effect
    1024 x 768 - 2M
    It's funny but I am pretty sure the normal map works if you have one for your character but not the bump.
    It's tricky working with one API but you have two to deal with.
    Yep I found that about .007 was good for skin but .02 works good for lips.
    A bit of a side effect is you can get more noise with the bump map added with strong lighting but the results are way better.
    I'll post some results soon.
    I would love to sort out the eye reflection stuff. DAZ doesn't do the best eyes but they should be able to be better with cycles.
    I am still trying to get my head around your eye reflection material.
    BTW when you do the bump nodes in cycles I think you are supposed to set them as non-color data. Not sure what it does but I've heard it works better (according to Andrew Price and he supposedly got it from one of the devs)
    UPDATE - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE - UPDATE -
    April 9th 2015 11pm
    mcjTeleBlender3.09 -
    - now detects and sends Bump maps from omUberSurface shaders ( ex Genesis2 ) , also gets the the ambient channel strength.
    - now takes the omUberSurface shaders "Specular Active" switch into consideration thereby solving the white zombie eyes issue ;)
    mcjBlendBot V 11 -
    now ready to receive and apply Bump maps which were not in the .mtl file
    note that the April 8th version of mcjTeleBlender also contained a tweak
    which may help cases where Blender can't find texture images
    and they show up as plain magenta'ish color
    if this problem still occurs, you can try
    - turning On mcjTeleBlender's "no quotes in .mtl files" which is in the misc. section of the third tab.
    - make sure the mcjTeleBlender's "fix .mtl for Blender" option is On
    - make sure your figure doesn't use non-existant texture images
    - you can look in the .mtl file ( mcjTeleBlender exports .obj .mtl .py and .bat files ) using a text editor you can see which image files mcjBlendBot did/will attempt to use. Sometimes the .mtl file says something like Maps/skinmap.tga when in fact the file in maps is Maps/skinmap.jpg and you'll have to fix that somehow.
    - if the image filename or the path to its location contains non-alpha-numeric characters ( hyphens maybe ) this may be the problem. Sometimes the 'space' character is the problem ... well it's worth a try to rename the texture image.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
