CARRARA CHALLENGE #63: There be Dragons..... WIP
1…1011121416
  • ed3Ded3D Posts: 2,653
    edited August 2022
    Bunyip02 said:
    ed3D said:
    UnifiedBrain said:
    Yes, those DIM prompts are confusing to me as well.
    Probably better to install the product manually.  It has two main folders - Presets and Scenes - which can be merged into the Carrara program folders with the same names..
    When that is done, you still need to go to your Carrara browser window and add the PhilW folder to your scenes menu.
    ~.~   And Thanx very much  _  manuall  install  >  instatlled right in  _   just need to see this   " the individual buildings bit "   and how  its'  done +
    + and the First Renders  -
    Glad you got it sorted !!! Nightime Dragon flame attack by chance ?
    ~  Thanx ,   and  would   suppose the 3 Entrys will  "mostly"  be all   _  did start an scene  => do'nt know how to set the lights to be On or Off
    ( if they even can ) on singl buildings
    1920 x 1028 - 686K
    Post edited by ed3D on
  • KhoeKhoe Posts: 347
    edited August 2022
    ther first render. next sep fine tuning. Better gras the dead bunches better texture. The rigt wing from the Dragon look for a better postion.
    864 x 1080 - 160K
    Post edited by Khoe on
  • Bunyip02Bunyip02 Posts: 9,345
    3 Entries is excellent !!!
    Looking great !!! Maybe angle the wing a bit ?
  • There's a lot of really good stuff!
    So I needed a room to display the dragon shield in so I started with the drapery set from DAZ store.  Retextured the room with the procedural shaders and noise functions.  Then found a lace pattern on FilterForge and created a curtain pattern and alpha map so light would shine thru the hole thingies in the lace and used a noise function for texture - plus some transparecy and translucency.
    So then I thougt it would be cool to have a couple of braziers for some light from the flames.  Things really went bad .  The curtain caught fire and you can see the result.  ALWAYS use fire retardant materials for drapes and curtains.  Now to clean up the mess.
    The fire on the curtains does look pretty cool though ...
    1600 x 1600 - 771K
    2000 x 2000 - 454K
    .well ,  thanx  -   ususally 1 or 2  -
    Nice work, lace curtains look groovy !!!
    Was trying to twist your arm and make it 4 !!! wink
    edited August 2022
    Inspired by Khoe - Just for Fun - Not an Entry
    Thunder Drake at Maple Meadows
    The Thunder Drake - https://www.daz3d.com/the-thunder-drake
    Maple Meadows - https://www.daz3d.com/maple-meadows
    1200 x 1560 - 4M
    Post edited by Bunyip02 on
    edited August 2022
    well  ,  Thanx   - -  but actualy   "Could"   be 4 if can  finish  "the Smokers"    -  but  idk  -
    I'll keep my fingers crossed !!!
  • DiomedeDiomede Posts: 15,464
    edited August 2022
    Update to the dragon helm of dor lomin.
    1600 x 1200 - 3M
    1200 x 1600 - 3M
    Post edited by Diomede on
    Awesome !!! Shader on the helmet gives a nice effect !
    edited August 2022
    Thanks for the nice comment.
    On workflow, I created the tombstone using the terrain modeler.  Created the letters in an image editor, then insterted as a heightmap in terrain modeler.  Added a smooth filter.  Converted to vertex model for some minor editing.
    1737 x 862 - 144K
    1749 x 998 - 185K
    1804 x 1010 - 380K
  • UnifiedBrainUnifiedBrain Posts: 3,588
    Very clever!  It seems obvious when you describe it, but I would not have thought of it.
    Thanks for the workflow !!!
    I'm always amazed at the number of ways you can do things in Carrara !
    UB any more WIPs from you or are you ready to enter your creations ?
    edited August 2022
    _  pretty good
    _  made an Cemerty Monument  _  for Bryce Challeng # 30 Secret Garden _  but , used Blenders  +  and made the Inscription with Blenders also
    + And the Final Image ++ thanx
    1536 x 1152 - 131K
    _Yes, was supposeing an Inscription_On one of the others_And made one with Blender , Also+1.jpg
    1024 x 768 - 45K
    1650 x 1237 - 197K
    Thanks for the comments, Bunyip, UB, and ed3D.  Great tombstone modeling in B, ed3D.
    _  pretty good
    Nice work !!!
    You're welcome Diomede !!!
    Will you have enough time to finish the animation, or will you do a still render of your scene ?
    Reminder :- Entry Thread Closes/Voting Begins: Saturday,  3 September 2022 23:59:59 CST (GMT-6)
    Get those entries in people !!!
    edited August 2022
    Bunyip02 said:
    Nice work !!!
    ~.~   and Thanx so much  +
    + 1  ~
    UnifiedBrain said:
    Part 3 - Haute Couture in Lizardland
    What did you expect, alligator purses and snakeskin boots? smiley  These are civilized lizards, not cannibals.
    The character is a kitbash of V4, Dragon Folk, and a second skin product (retextured) from Rendo.  The tail ornament is a modifier applied to a Carrara primitive.
    The runway bulbs are a Carrara basic object, rezoned with different shaders, and topped  with a bulb using a light sphere effect (thanks to Wendy for the suggestion).
    Carrara text is such a blessing!  There is probably not a single Carrara tool that I value more.
    No postwork.
    Oh that is just so good, beaut pose and skin texture - elegant dragon
    Classic scene taking place here Khoe - looking forward to the magick you make.
    that colour is scintillating against the meadow - I always lose patience
     rendering Howie's scenes.
    that's a brilliant idea Ted!!! Good subject for a ted Talk ;)
    That's a scene worth playing with!
    Thanks !!! The only scene of Howie's that I struggle with is Valle Alpina due to it's massive size !
