• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • Download Studio
ADVANCED SEARCH
  • Menu
  • Daz 3D
ADVANCED SEARCH
Add image
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Partnerships
    • AI Training data
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
Notifications
Loading...
    • Categories
    • Recent Discussions
Error when importing a Daz G8F into Blender
tayloranderson2047tayloranderson2047 Posts: 116
August 2022 edited August 2022 in Blender Discussion
There is an error message when I import a Daz G8F obj model into blender... does anyone know why to fix it?
I have set the model resolution to be low. When I import the obj in Blender, I only unchecked "Split by object" box in geometry and left everything else unchecked.
I am using the 3.21 version of Blender and my error message is a little different from this post
I have attached the obj file (in zip). If by any chance it can be loaded into your Blender, please let me know.
Post edited by tayloranderson2047 on August 2022
  • PadonePadone Posts: 4,082
    I don't know why the obj importer in blender expects a utf-8 file, obj should be ansi afaik. May be this has something to do with the new python in blender 3. Anyway you may try to resave the obj as utf-8 with notepad.
    Post edited by Padone on August 2022
  • tayloranderson2047tayloranderson2047 Posts: 116
    August 2022
    Sorry for my ignorance of this, but how to resave the obj as utf-8 with notepad?
  • MattymanxMattymanx Posts: 7,000
    August 2022
    tayloranderson2047 said:
    Please try the following sequence shown in the attached images:
    440 x 415 - 31K
    447 x 417 - 37K
    198 x 303 - 21K
    1039 x 858 - 242K
    917 x 352 - 155K
    307 x 564 - 37K
    362 x 288 - 19K
    360 x 288 - 20K
  • andya_b341b7c5f5andya_b341b7c5f5 Posts: 694
    Your OBJ file loads in Blender 3.2.0 for me with no error, though the system console does report that the MTL file can't be found.  Looking at your traceback, the issue is with loading an image file and it seems the filename isn't UTF-8 compatible.  Perhaps it is an image referred to in the MTL file, in which case without that and the image referred to we can't hope to reproduce your error.
    I suggest you make sure the images referred to in the MTL file have names that only use UTF-8 valid characters, or better still only ASCII characters, and see if that helps.
    Post edited by andya_b341b7c5f5 on August 2022
    August 2022
    Sorry I am a little confused... I only exported the obj of G8F and there weren't supposed to be any images... what do you mean by images here? And by names I guess you meant the file names of images, if any?
  • felisfelis Posts: 6,147
    August 2022
    When you are exporting an obj, you are also creating an MTL file  (material file) that has simplified version of the materials for your object, with reference to the used image files.
    To save the obj as utf-8 with notepad just open it with notepad and file > save as > "utf-8" encoding. You can also try "ansi" and "utf-8 with bom". But since @andya can open it with no errors it may also be an issue with the regional settings if you're in a japanese pc for example.
    August 2022
    Thanks! But when I import I only import the obj (and I don't need the material)... How should I let Blender "forget" the information of that MTL file and only recognize the obj (the mesh and geometry)?
    August 2022
    Oh I see, thanks!
    August 2022
    I think if you just delete the MTL file you will get the behavior I get, i.e. imports the geometry OK but complains about not finding the MTL file in the system console.
    You could also uncheck the checkboxes for Write Material Library when exporting from DS: I'm not sure, but I assume that would mean not creating an MTL file.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
