Celebrity Look-a-Likes for 3D figures part 3
15253555758100
  • alamo4alamo4 Posts: 48
    The new Celebrity 108 from Adam Thwaites looks a bit like Maggie Q to me.
    900 x 1170 - 786K
    467 x 664 - 45K
  • LearstangLearstang Posts: 46
    Haruchai said:
    Learstang said:
    Could CS107 be Milana Vayntraub (AKA 'Lilly' from the AT&T commercials)?
    Best Regards,
    Learstang
    Good spot, I'll update the front page list now :)
    Thank you! Glad to be of help!
    Best Regards,
    Learstang
    Agreed. The eyebrows look very close.
  • alamo4 said:
    @HID3D is now selling figures on Daz.
    Does anyone recognize if the new character, Karen, is based up on anyone in particular?
    https://www.daz3d.com/hid-karen-for-genesis-81-female
    The 164 cm is perhaps a clue, but not sure who that could be.
    https://fmsppl.com/list-of-people/female/height-164/
    She perhaps looks a bit like LIly Collins, but with less thick eyebrows?
    Regardless, a good looking character.
    Looks like the "Cash me outside" girl to me.
  • HaruchaiHaruchai Posts: 2,040
    edited March 2022
    Guhzcoituz has released SC Natasha for Genesis 8 Female at Renderhub. Scarlett Johansson.
    (Not to be confused with the SC Natasha by secondcircle at Renderosity, not sure why Guhzcoituz added the SC the beginning as they are different).
    Post edited by Haruchai on
    Looks like her to me too :)
    edited March 2022
    OK, as I know my way around a duf and dsf I've managed to detangle the morphs. Here is a side by side to compare the characters, on the left guhzcoituz and on the right secondcircle. Both with WPGuru's Stream Safe textures for a fair morph comparison.
    Update - After a quick message to the creator the morphs no longer clash.
    1920 x 1080 - 2M
  • RayDAntRayDAnt Posts: 1,166
    edited March 2022
    If head and body are separate morphs, zero-ing out the body (height, really) on both and then putting them at the same X,Y should make it very obviously just how similar the face shapes are based on poke-through alone.
    Post edited by RayDAnt on
  • xyer0xyer0 Posts: 6,490
    The new SC Natasha looks like ScarJo, and the old one looks like not quite a bronze medal.
    So, who's HID Mei?
  • Haruchai said:
    Krashwerks (original courtesy of deepred6502)
    Annalie - Liv Tyler
    Bayley - Jodie Foster?
    Cali - Reese Witherspoon?
    Camryn - Margot Robbie
    Chloe - Chloe Grace Moretz
    Elsie - Elle Fanning or Kristen Bell or Jodie Foster
    Erika - Yvonne Strzechowski
    Frankie - Cameron Diaz
    Gwen - Ginger Lynn (NSFW search caution)
    Ingrid - Inger Stevens
    Izabel - Anna Silk
    Jessie - Stana Katic?
    Kylah - Keira Knightley
    Lucy - Lily James
    Meribel - Michelle Dockery
    Miranda - Zoe Bell?
    Nathaly - Nata Lee
    Nella - Julia Stiles?
    Nikki - Jennifer Garner
    Olena - Alexa Flexy (NSFW search caution)
    Olivia - Angelina Jolie
    Rachel - Halle Berry
    Rhonda - Robin Wright
    Roslynn - Bryce Dallas Howard?
    Shylah - Shylah Jennings (NSFW search caution)
    Sybil - Sigourney Weaver
    Tiffany - Shannen Doherty
    Vanessa - Resembles Whitney Houston, probably named for Vanessa Williams?
    Yvonne - likely based on a Golden Age Hollywood actress, possibly Audrey Hepburn?
    Is there an up date for Krashwerks model list, cause I seen some new ones out online, but not on the list here.
  • commando991_70eecfd4fc said:
    Annalie - Liv Tyler
    Izabel - Anna Silk
    Lucy - Lily James
    Miranda - Zoe Bell?
    Nathaly - Nata Lee
    Would also appreciate as there are also a lot of older characters which are not covered by the list as well.
    Annalie - Liv Tyler
    Izabel - Anna Silk
    Lucy - Lily James
    Miranda - Zoe Bell?
    Nathaly - Nata Lee
    Hoping to be able to update this list in the near future.
  • LossowLossow Posts: 110
    Looks like Krashwerks is doing a Cobie Smulders too   https://www.renderosity.com/rr/mod/bcs/krashwerks-cody-for-genesis-8-female/153942/
  • Reggie68Reggie68 Posts: 17
    Lossow said:
    Looks like Krashwerks is doing a Cobie Smulders too   https://www.renderosity.com/rr/mod/bcs/krashwerks-codEy-for-genesis-8-female/153942/
    Exactly what I thought
    Nicolle possibly based on Bar Paly (Anna Kolcheck from NCIS LA)
  • nabob21nabob21 Posts: 1,058
    Haruchai, you mentioned that one of the SC Natasha characters had their morphs updated so they don' t clash. Can you clarify which character had their morphs updated?
    The SC Natasha by Guhzcoituz. I contacted Guhzcoituz and they sent me a link to an updated file that had the morphs renamed.. However, I have just downloaded the file available in my downloads and it is still the old one. If this is going to be an issue you might want to contact Guhzcoituz prior to purchase, maybe it has been updated for new customers but I can't test that obviously.
    Thanks Haruchai. I have actually already purchsed the two products and did indeed have a conflict, so I will have to contact Guhzvcoituz if he hasn't released an update yet.
    Hope you get this sorted. If you do get the updated files remember to uninstall the existing ones to prevent the clash. As I mentioned earler there is a way to rename the morphs and files yourself, if needed I could talk you through that (if you don't know already).
  • i53570ki53570k Posts: 235
    I don't see it on the sticky so I thought I add this: https://www.sharecg.com/v/97676/ ; probaby the best Maggie Q out there IMO and he made it for G1,G2,G3 and G8.
    I could use a teaching on your method. I tried to rename some files in order to keep installed both Naomi and Vicey3D's Naomi - G8F, but I failed and had to delete the latter. Vicey3D was nice enough to give me a refund, and he started adding his prefix to files to avoid this problem.
  • Rod Wise DriggoRod Wise Driggo Posts: 2,340
    edited March 2022
    Interested in that lesson as well ;-)
    Post edited by Rod Wise Driggo on
    edited March 2022
    My way to stop clashes with morphs. I'll use SC Natasha by Guhzcoituz as that was what I did last and is on topic for this thread, but obviously it applies to any situation
    1) Navigate to the relevant data folder
    2) You will probably need to unpack the dsf file with an archiving software (I use WinRAR). Most dsf files are compressed but you can try editing it direct first to check
    3) Unpack the bare file to the same data folder - See pic Stage 01
    4) Now you will need to edit the morph references in those files. I use Notepad++ as it can batch replace in more than one document at a time (Notepad++ is free)
    5) Open both bare files at once in Notepad++
    6) Under the Search menu at the top open the Replace dialogue (or ctrl+H on PC). Change the naming of the morph reference to something new. In this case I changed the beginning of the file from SC Natasha to GZ Natasha. Hit 'Replace All in All Opened Documents' - See pic Stage 02
    7) Move the original morph files out of the data folder and then add '.dsf' to the end of the bare file names to turn them into dsf morph files
    8) You should now have two amended morph files in the data folder
    8) Now we need to tell the character files that we have changed the name. Navigate to the relevant People-Characters folder and find any full character, character apply or character remove duf files. Unpack them to bare files (if necessary) as before. In this case there are six apply/remove files - See Pic Stage 03
    9) Open these files all at once in Notepad++ and bring up the Replace dialogue again. Notepad++ should have remembered what was last in there so just hit Replace All in All Opened Documents again
    10) Move the original duf files out of the folder and add '.duf' to the bare files
    11) Start (or restart) DAZ Studio and test
    Something to look out for, if there is a full character duf file (there wasn't in this case) and the creator has used the same naming method for the textures as well as the morphs this will rename those as well. I tend to open full character dufs separately and edit the full morph names to avoid this. It means more steps as you need to rename head and body morphs separately but avoids breaking the texture references
    Stage 01
    Stage 02
    Stage 03
    1493 x 233 - 49K
    1372 x 825 - 93K
    561 x 386 - 22K
    franky85 said:
    Chloe Grace Moretz
    https://www.daz3d.com/hid-alina-for-genesis-81-female
    Nice one :) Front page list updated.
    Droid said:
    V3D Sofia - Selena Gomez?
    https://www.renderosity.com/rr/mod/bcs/v3d-sofia---g8f-g8-1f/153917/
    I can see that :)
    magnus1781 since last update
    Christopher Reeve
    Gregory Peck
    Emma Stone (Version 2)
    Very close likeness, except for the usual Vicey3D problem (for me!) of a head that's too wide and eyes that are close to each other... with the right morphs one can probably adjust that to make the likeness even closer to the original.
  • tj_1ca9500btj_1ca9500b Posts: 2,057
    We don't usually deal with hair in this thread, but this hairstyle invokes Lindsay Wagner IMHO.  The model in the promo art sort of invokes Lindsay, but Lindsay's nose is different and the character model asset isn't called out on the product page to in any case.
    https://www.daz3d.com/biomorph-beauty-hair-for-genesis-8-and-81-females
    Stage 01
    Stage 02
    Stage 03
    Thanks so much, @Haruchai! That's very helpful.
