[Released] Smart Collections [Commercial]
135
  • Platnumk said:
    RiverSoftArt said:
    Platnumk said:
    RiverSoftArt said:
    Platnumk said:
    I can't seem to get the it to create anything other than an Empty Product,  I also get an error that it can't find or create runtime support directory
    That is strange.  Usually, DS has already created that folder as part of downloading and installing stuff.  Do you have /Runtime/Support somewhere in your DS folders?  For me, it is at D:\Documents\My DAZ 3D Library\Runtime\Support  Please create one in your My DAZ 3D Library.
    Mine is located at Volumes/DAZ3D Library/My DAZ 3D Library/Runtime/Support
    PS. Just incase it matters I'm using macOS 12.2.1 Monterey
    Huh?  Out of curiosity, is the LOCAL_USER_78900000...[blah blah].png in that directory?  Can you post the Daz Log of the run?  It has more information that I will need to figure this out.
    No the Icon is not in there.  Here is the Daz Log File with just the Smart Collections run in it.  Just incase the video didn't upload to the forum here a link to it Video Of Full Run
    One thing I just noticed that looks strange:
    Loading product image: /Volumes/DAZ3D Library/VM Icons/Smart Collection Product.jpg
    It should be something like this: Loading product image: /Volumes/DAZ3D Library/My DAZ 3D Library/data/RiverSoft Art/Data/Smart Collection Product.jpg
    Did you move it?  Have you tried Reseting the image or changing it to something else entirely?
  • PlatnumkPlatnumk Posts: 682
    edited February 2022
    Thats where I tried adding a custom icon but got the same result
    Post edited by Platnumk on
    RiverSoftArt said:
    I am baffled then.  Any Mac users got this working?
    EDIT: Maybe it is a permissions problem?  Is that directory able to accept user files?
    Appears to accept user files
    2826 x 1554 - 1M
  • barbultbarbult Posts: 27,356
    Is Mac case sensitive? Could something like that be causing problems?
    As far as I know, No it isn't
    Mac is case insensitive by default.  The user *can* make it case sensitive from what I understand but rarely do.
  • I just thought of something.  To Macs, I believe this "/Runtime/Support/LOCAL_USER_78900000__SC_My_Smart_Collection_-_Hair.png" will be considered an absolute path.  Can you create a Runtime/Support directory at the top-level?
    Something I have noticed that when you script creates the local user file it has a double underscore after the number but all of the other local user files don't,  could that be causing a problem
  • RiverSoft ArtRiverSoft Art Posts: 6,939
    It might... get rid of the "!" in your Smart Collections name. (That is in options)
    Post edited by RiverSoft Art on
    Ok, Getting rid of the ! didn't work.  The Runtime/Support is in the top level.
    This is how macOS determans where is folder is Volumes/DAZ3D Library "This is the same as the drive letter in Windows" /My DAZ 3D Library/Runtime/Support "this is the folder location"
  • I can confgorm that it does not install a product on macOS. My log file is:
    2022-02-13 15:59:26.544 DEBUG: Installing "!SC My Smart Collection 2" product...
    2022-02-13 15:59:26.545 Installing "!SC My Smart Collection 2" product...
    2022-02-13 15:59:26.546 DEBUG:      Creating "!SC My Smart Collection 2" product...
    2022-02-13 15:59:26.546      Creating "!SC My Smart Collection 2" product...
    2022-02-13 15:59:26.553 DEBUG:      "!SC My Smart Collection 2" product created
    2022-02-13 15:59:26.554      "!SC My Smart Collection 2" product created
    2022-02-13 15:59:26.554 DEBUG: Is INSTALLED true
    2022-02-13 15:59:26.554 Is INSTALLED true
    2022-02-13 15:59:26.554 DEBUG: Is Vendor false
    2022-02-13 15:59:26.554 Is Vendor false
    2022-02-13 15:59:26.554 DEBUG: Is Local User false
    2022-02-13 15:59:26.554 Is Local User false
    2022-02-13 15:59:26.554 DEBUG: Is Local User Store true
    2022-02-13 15:59:26.555 Is Local User Store true
    2022-02-13 15:59:27.053 DEBUG: Icon Path /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    2022-02-13 15:59:27.054 Icon Path /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    2022-02-13 15:59:27.054 DEBUG: Loading product image: /Volumes/DAZ Network Library/data/RiverSoft Art/Data/Smart Collection Product.jpg
    2022-02-13 15:59:27.054 Loading product image: /Volumes/DAZ Network Library/data/RiverSoft Art/Data/Smart Collection Product.jpg
    2022-02-13 15:59:27.060 Loaded image: Smart Collection Product.jpg
    2022-02-13 15:59:27.061 DEBUG: Saving product image file: /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    2022-02-13 15:59:27.061 Saving product image file: /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    2022-02-13 15:59:27.061 DEBUG: Cannot find or create runtime support directory: /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    2022-02-13 15:59:27.062 Cannot find or create runtime support directory: /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    Seems that the script is not using the full path to write. for loading the defualt icon, it refers to /Volumes/DAZ Network Library/data/RiverSoft Art/Data/Smart Collection Product.jpg, on the writing part it refers to /Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png where the full path should be /Volumes/DAZ Network Library/Runtime/Support/LOCAL_USER_78900001__SC_My_Smart_Collection_2.png
    It is a guess, currently trying some trick to see if is the target directory path that is failing. Will report.
    Took a bit of time, as the root directory on macOS is read-only and requires some tricks to add a writeable directory to it.
    The tool tries to write to an absolute path. The product ends up in /Runtime Support on the system root.
    RiverSoftArt, you should consider recruiting a Mac guys as a beta tester. Mark_e593e0a5 sounds like a good candidate. yes
    So that was it.  The script queries a Daz function for whether the path is relative, which obviously it is NOT with the leading slash.  It looks like DS puts the wrong information in a product's Icon Path, and then that makes the script go off the rails.  I think I am going to have to see if I can hack it somehow on Mac sad  @Mark_e593e0a5, I will try and send something to you?  Or, @PlatnumK, if you could please PM me your email, I could try and send something to you.
    It is definitely a thought.  Most products I don't need it as there is nothing special about the file-handling, but stuff like Content Wizard and Smart Collections need it.
    And yet Content Wizard works perfectly (It's my goto script when installing 3rd party content)
    Feel free to send something once finished. I am more than happy to give it a try.
    CW has had LOTS of testing and updates. smiley  I just sent a test update to you.
    Got the Update, what every you did has fixed it ;) Emailed you back with log files
  • issue seems to be fixed on all versions of macOS I have tested laugh. Sent the logs as well.
    Thank you @PlatNumK and @Mark_e593e0a5 for testing it.  I will plan to submit an update this week.
    Seems like your fix has caused a slight side effect,  The Add Product Button brings up the window,  but doesn't populate the window the selected items.  Selecting the items from the Smart Content still works as normal tho.
    My guess is that is caused by OTHER files being out of sync.  I have been updating 4 different files and was unsure if some link between them might be messed up by sending you only one.  Once I package up the update for submission, I will send it to you and you can quickly try it to see if that issue is fixed.
  • DoctorJellybeanDoctorJellybean Posts: 10,044
    Is the User Manual freely available? I'd like to read it before deciding whether to buy it or not.
    Sure.  Attached
    pdf
    pdf
    Smart Collections User Manual.pdf
    1M
    Sure.  Attached
    Thank you!
  • kerrykerry Posts: 74
    This was the tool that managed to pry open my wallet after months of not spending!
    Love it, feeling super organized it's already making the creation process feel way smoother, more fun, and less of a chore of wading through irrelevant items. You can see how I'm using the product in the attached pic.
    The one thing I'm not sure about is how to delete any products created that I don't want anymore, as I got used to using this tool I started to develop a naming convention and a system for organising myself. Actually, now I have a better idea of what I want from my library if I could I would just delete the whole lot and start over. sure it's possible to override stuff but some tool created products i just plain don't want anymore.
    Now I have a bunch of stuff cluttering up my smart content that I wish I could delete but don't know how.
    Exactly the same thing is happening with content wizard too. Had a few fails as I figured it out and now I can't get rid of them in my smart content.
    737 x 892 - 493K
    617 x 427 - 172K
  • Mark_e593e0a5Mark_e593e0a5 Posts: 1,603
    You can remove the product basically like any other product in DS (you might want to clean up the directory where the shortcuts will be located afterwards, or just leave them, tehy are not taking up a lot of space)
    As for the product deletion, select the SmartCollections product in the SmartContent pane. Right-clicking should produce a menu. From that popup-menu, choose "Show Product in Content Library".
    This will take you to the "Products" section on your content library pane, with the product selected. Sometimes, this does not work on the first attempt. Either try to manually locate the product in the library pane, or retry from the SmartContent pane
    One you have the product selected in the library pane, right-click on it. A popup menus shows up. From that popup menu, select "Delete".
    You will be asked if you really want to remove that product. Select OK. Your SmartCollections product is gone.
    This only removes the metadata. For the shortcuts that SmartCollections is creating, you have to remove them from the file system.
    @RiverSoftArt: could a "Remove SmartCollection" be a potential option for the next version?
    Does the removal of the metadata also removes the database entries?
    Yes, removing the product entry should remove all related entries in the database.
