Studio 4.16 Grays Out Options For Translation, Rotation SOLVED!
Novica
[Studio 4.16 Grays Out Options For Translation, Rotation, etc] Yes, the object is selected in the scene. The studio says select something in the scene. How do I fix this? Going in and restarting doesn't fix it.
Post edited by Novica on
is this with all objects or a specific one? Please post a screen shot.
It's doing it with all objects in the scene. The item is selected in Scene tab, in Parameters it names the object, showing it is selected, I tried the Universal Tool and the node tool, it just keeps saying What Do I Do? and Select an item in the scene. Everything in Parameters is grayed out.
As one of the examples, rat is selected. All Parameter options are grayed out. Correct tool is being used.
A screen shot would still help - failing that, the first thing it occurs to me to check is that you have Show Sub Items checked at the bottom of the group list, if not it appears as in my screen shot
Already did. Was working on it when you posted.
Wow the forums are doing LOUSY at images- that is a 120dpi 900 wide image shrunk DOWN to 800 in the post. It shouldn't be blurry at ALL!
Never knew what that was, but they are all checked, so that's not the problem.
You have something written in the search bar, could that be the problem?
KISSES AND HUGS!!!!!!! That was it!
And yes, I only ever upload PNG anymore, the forum software will butcher every JPG.
Thanks for trying to help Richard! I marked it solved.
