Help with Pixel problem
A few times I have finished a render only to find I have dots all over my lady, How do I get rid of these please?
  • That's noise - the render needed to run for longer/with a higher convergence threshold/with the denoiser on (if the render is fitting into the GPU memory - it isn't available when rendering with CPU), or you need to add lights to directly affect the shadowed areas 9then adjust Tone Mapping to get the desired look)
  • beachlegsbeachlegs Posts: 532
    edited January 2022
    Thank you I will go have a play now...Noise not dots noted lol
  • SpaciousSpacious Posts: 481
    Here's a link to a nice GUI for both the intel and nvidia denoisers.  You can run anything though it - renders, photos, whatever you want.  It was put together by a  DAZ forum menber.
    https://taosoft.dk/software/freeware/dnden/
    edited January 2022
    Thank you Spacious, I will have a look of that.
  • Richard HaseltineRichard Haseltine Posts: 112,208
    edited January 2022
    Well, they are dots - but their cause is, almost certainly, noise due to incomplete convergence. There are other things which can leave dots on he render that are not noise.
    I should add a couple of things - first, the render will stop after two hours, by default, regardless of convergence so you may need to give ti more time before adjusting the threshold. Also, another way to make DS render longer is to raise the Render Quality, which makes it more exacting about what it counts as converged.
  • McGyverMcGyver Posts: 7,112
    edited January 2022
    I use glue traps or those big bug zappers... usually that keeps the pixies in check, but if I find a big nest outdoors I'll use a can of Pixie Spray.
    EDITED TO CORRECT: Oh... Pixels... Thought you had a pixie problem. Never mind.
    Post edited by McGyver on
  • MoogooMoogoo Posts: 136
    Just for information sake the biggest cause of noise is low light conditions, alot of people to avoid this will render with more light then knock back the light in photoshop/ gimp or with the tone mapper/ enviroment options.
  • AllenArtAllenArt Posts: 7,176
    edited January 2022
    Or, if you set the Max Time to zero under Progressive Rendering, it will take as long as it needs to reach convergence - given you have the other settings set up correctly :)
    Post edited by AllenArt on
    edited January 2022
    Thank you,  I am using Stonemasons new set, I had this problem with another of Stonemasons sets his lighting is awesome just shows alot of noise on my renders for some reason. Going to start again with new settings and see how it goes :)
  • If it is dropping to CPU and you are suing the default maximum time then it may well be that you need to give it longer (or, as AllenArt says, up to forever) - though Stonemason's sets in themselves are usually pretty efficient about resource usage.
    edited January 2022
    I have it working after your advice to give it longer and AllenArt, It is looking great thank you and everyone who gave advice I appreciate all your help :)
