Adding to Cart…
just a couple more Renders of Hye
I was going for Half Korean when I dialed her in
Hye 5'4"
for fun , trying to recreate someones character in a game, still a WiP, only have the neck up done, without a selection of clothes or hair, it's more of an approximate
trying something new, not using any paid dials or anything paid tried to go totally free.
had to use the paid hair, well didn't have too, it just seemed to looked best with what I dialed in
it was just with quickie with lighting for a render, something I have saved that I really have to add more lights to, it just a starter thing I have made
so this is what I came up with
Calanthe
okay use some of my paid dials
so here be Calanthe P
did another all free model, only things not free was hair,eyes ( I need to have good eyes to be satisfy)
DieTrying's 182 V4 Morphs for Genesis
and
Tween Morphs for Genesis
starting with
Elka for Genesis
all can be found at ShareCG
and here is Waleria
Another one of Waleria
the lighting here, I'm still working on
the first post above I not yet adjust her height, this one it has
EDIT: opps, I see I forgot to give Waleria any expression
the pose I forgot where I picked it up from, just some minor adjustments, then saved to use later
had enough pennies, with the help of the 85% off I picked up Young Teens 5 Julie and Justin
used the Julie dials on Toni
and now have Toni 3
too bad I'm stuck using the machine I have . . would really like to add more props for a better scene, and not just single pose and lights (and limited to how many and which type of lighting)
found some more freebie's to download, did some mixing of most of them in this image with a new model, Seija
gonna try something in GIMP, this is one render that should have post work, something I still have yet to learn
I had another idea for a pose and prop, . . . other then the jedi way, . . . just need to find me a shield, and do another render of what I was really going for
oh and below is a little reworking of Hye
bit sloppy, something I did to pass the last hour
here is a unfinished Nemo in other words WiP
going for some warrior type
dialed Libby a few weeks ago . . just now getting to rendering her
another Libby
seems she has Cataracts, I'm think it may be with something with my render settings causing it
I wanna see if I can figure it out on my own first, had this happen before , and I forgot what I did to fix it
never did finish figuring what I did wrong with Libby's eyes
rather then get stuck and possible frustrating situation, I dialed in Sheona
forgive the lighting mistake with the shadow , I was going to use a different set of light, but knowing that the render takes too long when the lights I want ed to use, and being very tired at the time , I decided to just use another set that just doesn't take long to render, also was too lazy to correct it.
was more a test render any ways
did some rework on Cin
this is were you'll see the before image http://www.daz3d.com/forums/discussion/2100/P15/#337207
here is Cin 2
new one
made some adjustments after this render, just need comp for something else then I'll do a render again
Thalia
another one of Sheona
it's not exactly;y the render I wanted to do, just couldn't find a image I was searching for, but this one worked as a background.
it kinda gave me what I was going for
dial in me a new model
Luna
just playing with Genisis2
Not much I can do in the dial department, have picked up a freebie, mainly that's all I used
was sweating it on this render, getting close to the moment of crash. really need to add some shaders to the mini gun, and many other adjustments, but I wanted to get the first render of Taimi
having a bad insomnia day, so created this scene, body is jelly, but me brain won't slow down, can't get to sleep
cool render. For a second I thought she was holding a leaf blower machine. lol. Nice lighting
thank you
I don't recall where I downloaded it from, I think it was a special freebie,or is a freebie, or it was part of something I bought, but the lighting came from 'FWSA Stacia for Victoria 6'
bit loopy from no sleep forgive me for not searching the link,
I suspected the mini gun needed some shaders, and it shows that they're needed after I did the render,
still had not been through all my models since the paid new dials, from a while back. .
Remember Agnes http://www.daz3d.com/forums/discussion/2100/P30/#434443
here is the new Agnes v2.0 :D
did this real quick, made an adjustment to one of the lights ( a preset I created) and try to recreate the scene like in the first Agnes, Obvious different skin mat and lighting, and of course the new dials, speaking of which, with the new lighting, I see I need to play with those dials some more, somethings I didn't notice till after the render
still making adjustments, another slight change to the lighting, Skin MAT, itsy bit on body
Still see more needs to be done till I'll be happy
Every get that gut feeling that something not good is about to happen
a little something I've been trying to recreate, need to work on them dials some more, might have to create a deform or 2 to do it, but see what I can do with the dials first.
this is one of my characters I play , a screen shot I'm working from (link would work, so posting the image here
don't really have any male clothing to go with what I'm doing nor the beard, so may be unfinished till I can find these things.
here is how far I have gotten so far
okay this guy was dialed just to get some skins for Genesis Male saved, for me to use
the one on the right is a freebie M4 Tan, on the left was after some adjustments to it. Unfortunately no matter what I do to the face, it just won't change.
any ideas what I need to do to get it adjusted better to match the rest ?
I still see I need to work on it some more, but that face I wanted to get fixed somehow
today's creation
Faustina
felt safer using FWArt Lights from the Stacia
pretty much used Shaders on all the materials. mixed some bump and opacity maps, to give more texture
and another new girl
Kitti
having a tough time putting together a scene , and it's getting late, I tested her with some of my lights, and just wasn't what I was looking for, ended up changing her clothes .. ended with Hongyu's CowGirl4. Spent hours going through my library, for something to use, but like I said it's getting late, so tonight I ended with this, I have some ideas for later, so you'll be seeing Kitti again
ok ok . .couldn't fall asleep right away, kept thinking what I wanted to do, so played a little with the Chopper, using what shaders I had on the whole thing. I think I'll keep toying with the frame, Tank, and Fender colors
still need to find more to add, and not crash
here is another of Kitti
struggling getting a whole scene with Kitti and her toys , too many shaders for this poor old machine, needed a break.
so dialed another new Genesis model,Neilina as early 20's and early teen. I'll add the early teen version later, I haven't decided totally yet on which hair for Neilina for now it's Longhair_EVO_V3, I did change the Diffuse color.
top is the Half T-shirt from OpiTex
pants are from Hongyu’s CowGirl4
for the top and Pants I used Wilmap's Assorted Textures, and Lace Design
Fast Metals shaders for the buttons
Lights from FWArt Stacia (Character lights)
Pose was a mix from AS-Team Pose01 (Aery Soul) with some minor adjustment and a slight hand pose change
okay, I really need to find more clothes, this took me longer just trying to find something for a early teen
this is Neilina early Teen
