Gizmo too small
dennisgray41
in The Commons
https://www.daz3d.com/mesh-grabber-win
I am starting to use the mesh grabber but the gizmo is so small I keep droping it. Is there a way to make the gizmo bigger?
With Mesh Grabber active go to Tool Settings. Look in the second grouping called Gizmo for the Size control.
Thanks! I was not using the tab.
simpler than a purple pill.
I was going to say maybe the water was too cold, but then I realized it's the Mesh Grabber gizmo... not the... oh never mind.
If you know a safe way to double the size of that gizmo, my wife will be forever in your debt.
That just tempts me to make a model of a Ronco type "order before midnight tonite" kinda device with one of my typical satirical ads... none of which I'm guessing would be TOS compliant.
At least none of the ones that first came to mind...
Drug-free, contactless, non-invasive...
Not to forget the rest of that tool bundle,
Switch to metric. 1 inch equals 2.54 centimeters. 6 inches equals 15.24 centimeters. If that doesn't satisfy her, learn to do censered
You're not supposed to get Gizmo wet at all. Didn't you listen to the three rules?
ROFL my censored in forum off...
