"Ocean Delight"-shore module- water FX project
16791112
  • 3CPO3CPO Posts: 156
    edited November 2021
    @chris-2599934
    Rest assured, I am not loosing any sleep over pretty much anything. Maybe you didn't understand the whole context of how this project came to be. Why it took so long? Just because it is a hobby project and for me it was rather a personal challenge to make it the best I could and not being constrained by any time-frame or other considerations. And as of yet, there is no equivalent product in the Daz ecosystem that can produce the effects this one does. I don't mind working on it and polishing it as I see fit but certainly I wouldn't like working in vain like an idiot trying to adjust it to some proven bug-ridden versions just for the sake of an early release and having to update it for the next good version once it finally comes out. Knowing what it entails makes me really reluctant to do so. And I think you agree, adjusting it for a specific version requires that version to be published and tested first. So, joking about adjusting it for version 5 or even 6 is not very funny. And I coudn't care less if it didn't hit the store at all...So, here we are, don't hold your breath either.
    Post edited by 3CPO on
  • kyoto kidkyoto kid Posts: 40,620
    ...what I've seen so farI really like.  it looks much more realistic than many other "seascape" and ocean products I've seen.  peronally, I'm not averse to tweaking settings (I do it all the time) to get the results I need.
    I would love to see how this would enhance the scene below :(of course teh scene would need to be converted to Iray as the original was rendered in 3DL).
    1250 x 1400 - 1M
    Post edited by kyoto kid on
  • ChumlyChumly Posts: 793
    Well, what started out as a hobby for you, could literally turn in to the Aquatic Equivelent of "Ultra-Scenery".
    Ultra-Aqua?
    Ultra-Oceanus?
    anyone?
  • GordigGordig Posts: 9,263
    Ultra-Aqua?
    Ultra-Oceanus?
    anyone?
    Ultramarine?
    Hello again,
    Unfortunately, my initial enthusiasm with regards to the rendering compatibility of my project developed in Daz Studio v.4.12.1.118 with newer 4.15 versions was short lived.
    After more extensive tests with both general release version 4.15.0.30 and latest beta version 4.15.1.96, I came to the conclusion that both versions have broken functionality, each with different kinds.
    The fact that my underwater scenes render the same as in 4.12 in the latest beta, but not the beach scenes, and the other way around in the latest general release of 4.15, confirms the fact that renders made with the older 4.12 version can be considered as a normal reference.
    Since my project uses extensively geometry shells with opacity maps and makes full use of transparencies, reflections and refractions in an overlayed manner, it is inherently affected by the currently introduced bugs still present in the 4.15 versions of Studio.
    Considering the procedures and requirements for a product to pass and be published, it seems like at the moment, the best course of action to take on my part is to keep this project on hold until a proper, functionally correct version gets published.
    In my opinion, trying to adjust parts of the project to one still broken version or another can lead to unnecessary complications and customer confusion that can ultimately be detrimental to the success and popularity of my product. Although it is rather complex in its design, it is meant to be simple and hassle-free to use. I hope you understand...
    In the meantime, I can concentrate on working on something else, for example on the "deep sea" module of the project, meant to be a complementary addition to the current "shore module".
    I thank those trying to suggest a name for my project, but it was already named, with complete product cover and all...
    So, sadly, sometimes things are as they are...
    726 x 846 - 1M
  • nonesuch00nonesuch00 Posts: 17,944
    3CPO said:
    Hello again!
    Today I worked on a underwater scene trying to match the render output of version 4.12.1.118 to the output of version 4.15.0.30. This is as close as I could replicate it and looks almost the same. Probably with a few more careful tweaks, I could get it even closer. What you have attached are raw untouched renders done in the respective versions mentioned above. There are some differences as well but I think those differences in terms of looks are less important. What surprised me most was the render times!! Version 4.12 rendered the scene twice as fast, in 33m 26s. Version 4.15 rendered it in 1h 5m 34s. Honestly, I did not expect such a huge difference on the part of a newer software, with a newer IRay version implemented, which is supposed to be better. I personally fail to see the progress!
    Granted, the render made in  version 4.12 has some fireflies but looks cleaner and richer colorwise, with better skin color rendition. The render made in version 4.15 seems a bit noisier with darker volume shadows, worse skin color rendition but with almost no fireflies. If you ask me, hard to tell which one I prefer. But what I can say is I would definitely trade some easily removable fireflies for render speed.
    Please let me know what you think, any comments are welcomed. Also, I would like your input weather I should go with a dual version release or stick with just the latest.
    Thank you for your time.
    I've always felt iRay renders look better "snowy" but no one else does. laugh
    Ultra-Aqua?
    Ultra-Oceanus?
    anyone?
    LOL, Aquafresh laugh
  • PraxisPraxis Posts: 241
    3CPO said:
    Hello again,
    <snip>
    Just want to add my voice:  Based on the images you have posted, I would definitely buy both your "shore" module and "deep sea"  module in a flash, regardless of what DAZ Studio version they worked best with.  I would happily install whichever DS version was necessary to get results like that, for the duration of my project.  (I have archived DAZ Studio installers from v4.5 onwards).
    I hope you keep working on this, and that we can buy some of this magic SOON! smiley
  • HavosHavos Posts: 5,312
    I am disappointed to hear that the opacity bug has still not been fixed in the latest beta release. The problem of waiting for this issue to get cleared up is we have no idea when that might happen, it could be months or years away. I think the issue was first flagged about a year ago, and I am pretty sure the NVidia engineers are aware of the issue, but I imagine the fix is not easy, or it would have happened by now. Daz Studio has had multiple Iray version releases in the last year.
    Has anyone heard of any rumors of when (or if) this bug will be fixed?
    Post edited by Havos on
  • Seriously, do not give up!  You've been putting this project together for over two years.  This product is generating a lot of interest and you've got something here.
    What I would do it partner up with the DAZ team and see if they can help you with your 4.15 problems.  Point the development team to this thread and say it has a lot of interest.  A product that has trapped a consumer base's attention for two years?  DAZ is going to want to dip there toe in this pond (no pun intended...I lied, pun intended).  Who better to help you out with the problem you're facing than the actual creators of the program you're using to create the product.
    You're near the finish line...not the time to quit the race.
    We believe in you!
  • Please do bear in mind that product development threads are allowed only on the understanding that the product will be offered to the Daz store - this is not the venue for discussing other options
  • AllenArtAllenArt Posts: 7,145
    Urgh. This place is such a killjoy sometimes.
    I think the OP WAS planning to submit to the Daz store. "Was" being the operative word now sad
    Post edited by AllenArt on
    Hope is never totally lost...Checked my ocean project scenes against this latest beta (4.16.1.2) and discovered that, in uber shader at least, even the slightest amount of top coat weight strengh, regardless of the layering mode used, darkens and dulls the overall glossy effect instead of brightening it. Can anyone else confirm this weird behavior?  This might explain the obvious color change in similar surfaces.
    Similarly, using SSS Mono mode effect, found that by comparison with version 4.12, in order to get equivalent effects, the transmitted measurement distance needs to be about 40% higher in the latest beta, kind of the same as in 4.15.
    I asked the developers or anyone in the know in the Daz Studio Discussion thread if the shader will remain as is in the current version of Studio or is it still in the process of debugging and subject to further modifications. I hope someone will answer and clarify so I can decide which path to take...
  • Richard HaseltineRichard Haseltine Posts: 97,271
    Se the last entry in the change log, currently (the only one under the Private Build header) http://docs.daz3d.com/doku.php/public/software/dazstudio/4/change_log
    • Implemented a partial workaround for NVIDIA Iray thin-film changes
      • Approximates (does not replicate) the previous behavior
      • Cannot fully match the previous behavior, but does match color characteristics to some extent
      • Affects reflection and transmission - the previous behavior only affected reflection
      • Cannot match three-or-more color variations
    also see the thread on Iray versions https://www.daz3d.com/forums/discussion/529616).
    I was told in the Daz Studio Discussion thread that "The change in Iray is deliberate, and will presumably remain, as the old behavior was not physically correct."
    That may very well be, but based on human perception, which of the renders below look to you more "physically correct"? Or just esthetically more pleasing? Can you spot the differences? :)
    ...and I ask myself, rethorically, where is the claimed rendering improvement? And by the way, Studio v.4.16 was not able to render that exact same scene on GPU on my machine.
    2800 x 1192 - 5M
    2800 x 1192 - 5M
    The one on the left looks more correct because most any camera would include motion blur from the movement of the water.
    The one on the right the water is like a static prop floating above the beach.
    (had left & right switched backwards earlier)
    Post edited by nonesuch00 on
  • barbultbarbult Posts: 23,224
    I like the one on the left much better.
    3CPO said:even the slightest amount of top coat weight strengh, regardless of the layering mode used, darkens and dulls the overall glossy effect instead of brightening it.
    I noticed this just yesterday as I was prepping a new freebie. Disappointing.
    ...indeed the one on the left.
    I grew up about a mile from the Atlantic Ocean... and the one on the left looks better to my eye....
    You are probably right to wait until Daz Sorts out its side (Dare I say, Daz5....?)
    That being said...
    UltraMarine is a killer name!  Thanks Gordig!!!!
    UltraMarine:Shoreline
    UltraMarine:DeepBlue
    UltraMarine:Lagoons
    UltraMarine:Hurricanes
    Etc Etc....
    We have a winner!
    ...then I am sure you saw something like this, some of the time at least...
    It will be included as one of the presets...
    2800 x 1192 - 4M
  • McGyverMcGyver Posts: 7,008
    That's pretty cool... we get that around here, but it's not as common as the tiny bioluminescent jellyfish... unfortunately even though there's a little beach area at the end of my street, I haven't been fortunate enough to see them in a number of years... mostly I just snag photos of sunsets...
    But I really like your product and feel it's one of the best I've seen at reproducing the look of a beach environment, or water in general... it's genuinely impressive.
    Keep forging ahead, you've got a great product there!
    @McGyver
    Many thanks for the kind and encouraging words. Beautiful and inspiring sunset shots you got there...
    oooooohhhhh....
    How about a: UltraMarine: Floodwaters
    too cool!
  • 3dLux3dLux Posts: 1,225
    It looks like a photograph!  surprise
    On another note, I live in the Philippines and we used to go to beaches every summer up until mid college cool
  • cherpenbeckcherpenbeck Posts: 1,409
    I would like the dual version, but in the end, I will take whatever you offer, as it is so much better than anything we have now.
    ...This
  • GreymomGreymom Posts: 1,104
    Still very interested in this product!!
    edited December 2021
    Like I mentionned in an earlier reply, this project will remain on hold until a good working general release will be available. Good news is, the latest two beta iterations, versions 4.16.1.17 and 4.16.1.21 seem to have resolved at least the shader rendering issues I have been having with my scenes as it now appears to be almost identical as in general release 4.12.1.118. So, if that will hopefully remain valid for the next general release, there would be no need for a "dual" version anymore. And that I think is a good thing...
    Until then, all we can do is wait and hope that next year will bring us a better and a more satisfying version for everyone...
    Happy new year and best wishes to all!
