• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
[Diffeo] Geo Shell stocking renders only normal map
acdum1857acdum1857 Posts: 105
October 2021 in Blender Discussion
Figure : G8F
Item : Stocking Settings For G3F G8F (01 Sheer)
Export : Export To Blender (not HD)
Image 1: Rendering in Daz
Image 2 : (EEVEE) only normal map is rendered (same for Cycles)
Image 3: Nodes in Legs
Image 4: Warning after import
I'm not familiar with Blender's advanced procedural texturing, but I know the basic texture structure.
So I tried changing the settings to render the texture properly, but it didn't work.
Please advise what is wrong.
  • PadonePadone Posts: 4,203
    October 2021 edited October 2021
    As for the warnings some minimum quality settings are required for cycles and eevee and the scene lights for the rendering to work fine. You can choose to warn or update in the global settings panel.
    https://diffeomorphic.blogspot.com/p/global-settings-version-16.html
    As for the stocking it's not a geoshell. The artist is using the metallic flakes section of the uber shader in a very "strange" way. Specifically the density is set to 100 in order to get the opaque part of the stocking. This would normally be done with the cutout section or a geoshell.
    I'll see what I can do for the metallic flakes, but this will take some time and I don't grant anything since as I said this is a very "strange" way to use it.
    https://www.renderosity.com/rr/mod/bcs/stocking-settings-for-g3f-g8f/124513
    255 x 371 - 40K
    Post edited by Padone on October 2021
    As a side note the daz bridge 2.4.0 doesn't get this material too. Not that the daz bridge is too smart about materials in general.
    Meanwhile as a workaround you can add a geoshell yourself using the cutout section with the stocking mask. This will export fine. Example scene included stocking-fix.duf.
    As a side note, as for diffeomorphic, geoshells work "better" in blender than in daz studio itself. Because in blender they are implemented as a material layer, that's not possible in the uber shader and that's why shells are used instead. Thus in blender you don't get the typical shells "artifacts" as unwanted shadows casted from the shell, or a possible pokethrough of the shell geometry.
    381 x 596 - 62K
    duf
    duf
    stocking-fix.duf
    151K
    515 x 219 - 31K
  • acdum1857acdum1857 Posts: 105
    October 2021
    Padone
    Following your last comment, I made a shell and put all the textures in it, then I imported it through Diffeo and rendered it.
    The results were very satisfactory. (Image 1)
    The offset is also adjustable, so I think the shell is a much better way.
    I really appreciate your advice and work. yessmiley
    One more question.
    I tested 'Mystique 2 for Genesis 8 Female(s)' and found that the material was not rendering properly. (Image 3)
    So, I increased the normal map intensity in the node, but there was no change.
    I guess the roughness was probably not translated properly.
    Do I have to add related nodes or do I just need to set some simple settings?
    1533 x 1533 - 2M
    3840 x 2160 - 5M
    3840 x 2160 - 4M
    2298 x 1893 - 573K
    4096 x 4096 - 3M
    As for mystique it is hard to tell what/if is wrong. For a start are you sure you use the same lights ? Because from your pictures it doesn't seem so. Just export the default hdri with no other lights and compare the renderings. Then it may also be the tone mapping. You should compare with something else in the scene that could provide you some reference, not just the dress alone especially if it's black/white.
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
Create An Account
