getScriptFileName() alternative?
Is there an alternative to getting the current script file name? Because getScriptFileName() keeps returning an empty string.
Nevermind.
For some reason, if you don't assign it to a variable it won't return anything.
It doesn't return anything until the script is evaluated...rats! I can't call it at the start of my script!
Ok, now I officially figured it out.
So um... don't have anything else in the first line, not even comments. :\
I'm not sure how you are testing, but IIRC, getScriptFileName() works on scripts that are either loaded or saved - but not modified.
I don't know what's happening inside DS, but from the outside it looks like once you modify a script in the script pane, a new anonymous DzScript object is created for you to work with, until you save, at which point this function should work. Once you make a change, it is once again duplicated into a new anonymous DzScript object.
Does this match with what you are seeing?
Here is a thread where the issue is discussed: Bug since DS v4.11.0.236 DzSIReloadAction: Sets getScriptFileName() == ""
I tested the function in another script - and it initially didn't work (which is why I commented); but after reloading the script in the Script IDE, it returned the script's absolute path. What I ended up doing after crying a river - was copying and pasting the code into a new file and hit Execute, and all of a sudden it worked. I did a file comparison to see what was different between the two scripts, the only difference was the ASCII Daz Header at the top.
So, what I originally had was something like this:
As you can see, it returns nothing if you try to execute it in the Script IDE, Debugger, or any other way.
But when I did this:
It worked.
Yes, I did notice that the function would return nothing if you executed the script while the file was modified outside of DAZ or not saved; but not updated in the Script IDE. However, if you opened in (for example) the Content Library, it would work like it's supposed to.
I just tested it again today and all of this still applies. It's amazing what a comment can do ;D
Redacted
In case anyone having this problem reads this old thread:
It seems that the problem happens only if the .dsa file uses CRLF (0x0D 0x0A) as End-Of-Line characters.
If the .dsa uses only LF characters as EOL then the problem disappears.
I have reported this in Support Ticket # 504845
See also this thread:
https://www.daz3d.com/forums/discussion/748191/bug-in-ds-v4-24-0-3-beta-dzsireloadaction-sets-getscriptfilename#latest
