getScriptFileName() alternative?
Is there an alternative to getting the current script file name? Because getScriptFileName() keeps returning an empty string.
  • DafaDafa Posts: 97
    edited July 2021
    Nevermind.
    For some reason, if you don't assign it to a variable it won't return anything.
    It doesn't return anything until the script is evaluated...rats! I can't call it at the start of my script!
    Post edited by Dafa on
    edited July 2021
    Ok, now I officially figured it out.
    So um... don't have anything else in the first line, not even comments. :\
    // I'm a baloney// DAZ Studio version 4.15.0.2 filetype DAZ Scriptconst x = getScriptFileName();print(x); // returns ""
  • OmnifluxOmniflux Posts: 442
    I'm not sure how you are testing, but IIRC, getScriptFileName() works on scripts that are either loaded or saved  -  but not modified.
    I don't know what's happening inside DS, but from the outside it looks like once you modify a script in the script pane, a new anonymous DzScript object is created for you to work with, until you save, at which point this function should work. Once you make a change, it is once again duplicated into a new anonymous DzScript object.
    Does this match with what you are seeing?
    I tested the function in another script - and it initially didn't work (which is why I commented); but after reloading the script in the Script IDE, it returned the script's absolute path. What I ended up doing after crying a river - was copying and pasting the code into a new file and hit Execute, and all of a sudden it worked. I did a file comparison to see what was different between the two scripts, the only difference was the ASCII Daz Header at the top.
    So, what I originally had was something like this:
    As you can see, it returns nothing if you try to execute it in the Script IDE, Debugger, or any other way.
    But when I did this:
    // DAZ Studio version 4.15.0.2 filetype DAZ Scriptconst x = getScriptFileName();print(x); // returns script absolute path - YAY!
    It worked.
    Yes, I did notice that the function would return nothing if you executed the script while the file was modified outside of DAZ or not saved; but not updated in the Script IDE. However, if you opened in (for example) the Content Library, it would work like it's supposed to.
    I just tested it again today and all of this still applies. It's amazing what a comment can do ;D
  • cridgitcridgit Posts: 1,765
    edited May 2022
    Redacted
    Post edited by cridgit on
  • PraxisPraxis Posts: 293
    edited September 4
    ...<snip>...
    In case anyone having this problem reads this old thread:
    It seems that the problem happens only if the .dsa file uses CRLF (0x0D 0x0A) as End-Of-Line characters.
    If the .dsa uses only LF characters as EOL then the problem disappears.
    I have reported this in Support Ticket # 504845
    See also this thread:
    https://www.daz3d.com/forums/discussion/748191/bug-in-ds-v4-24-0-3-beta-dzsireloadaction-sets-getscriptfilename#latest
    Post edited by Praxis on
