Way to use boolean to fill large amounts of holes at once?
kylegonyerkylegonyer Posts: 20
edited June 2021 in Carrara Discussion
So I use boolean alot to take away, but wondering how to use it to add to. In the example below I have a big box and the lower half has holes that I want to plug (yellow object to plug) Union merges, intersect takes away all but where the big box and yellow cube intersect, Box minus cube take out where yellow was including the box as expected and cube minus box for some reason is just like union. What I want to do is box minus yellow cube except where they intersect. Hope this makes sense. Holes are all the way around the bottom all side but left some and not doing so you can see. what is there
Post edited by kylegonyer on
  • HeadwaxHeadwax Posts: 10,466
    edited June 2021
    had a brief play with a donut like cylinder and a cube
    the only way to get what you I could find  want was to to make the sure the walls of the cube were aligned exactly with or slightly below the box walls
    before alignment
    box in cube
    box minus cylinder
    result - interestingly you loose the box colour
    2100 x 1353 - 527K
    2004 x 1320 - 405K
    2105 x 1353 - 463K
    2232 x 1259 - 490K
    Post edited by Headwax on
  • kylegonyerkylegonyer Posts: 20
    thanks for reply, It seems to loose the box though. I am wondering if I am going about it all wrong and if boolean is not the way to fill a hole left from a boolean. For very simple shapes with a hole I did see I could use bridge (must do on both sides of the wall or object, but with the current box and lots of holes would take alot of time. I did see some videos where users are using blender and it has a fill operation if you select the edge of the circle/s .....again not a quick plug of all the holes in two clicks thing, but does anyone know if carrara has a fill type tool, operation or modifier? or is that pretty much what bridge is?
    sure it's in the model room
    just make sure you select the vertex object withh the holes first
    1335 x 1043 - 366K
  • WendyLuvsCatzWendyLuvsCatz Posts: 40,624
    wouldn't it be simpler to just duplicate yellow cylinders to plug them?
    edited June 2021
    The best I was able to do is copy the objects along the same axix and only do a side at a time. That is if I want to do the long way. Just a test for now
    Which results in a union of the filled holes (minus the ends, ill get into that later) + what overlap was there for the box
    Then 2 more boolean operations needed to take box section out
    Which no matter how it is done results in no end caps for plugs, so a selection of just the edges and fill (Thanks for showing Headwax) gives me a row of exactly spaced and sized  "plugged" (but unfortunately only 1 side a time ....very tedious)
    Yes WendyLuvsCatz, this can be used to just shift back along the same axis and plug using duplication your idea got me going this route
    However, I was looking for a 2 click or very simple way to do it all with Boolean. I am not sure if Carra is capable (at least not in the assembly room)
    I think what I want to do is use some of the other 8 (of 12) but they are not accessable from the assembly room and in modeling I can only have the one object. Unless I am doing something wrong
    744 x 435 - 73K
    350 x 521 - 33K
    915 x 457 - 17K
    965 x 744 - 180K
    243 x 101 - 7K
  • StezzaStezza Posts: 8,930
    probably quicker to just delete the section and redo with no holes.... enlightened
