• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
mcjTeleBlender:Daz Studio scenes/animations w/Blender's Cycles Engine
«1…19202122232425…49»
  • mCasualmCasual Posts: 4,607
    September 2014 edited September 2014
    ladaga said:
    I apologize for the wrong link to download MDD Importer for DAZ Studio 4.6 and for my english:) Instead of that, use this.
    http://amarijun.wordpress.com/2014/08/23/mdd-importer-for-daz-studio-4-6/
    also recorded a short video tutorial on how to use the plugin.
    http://www.youtube.com/watch?v=6cqpa7mUZhU&feature=youtu.be
    please explain how to use the plug-in for the successful transfer of the animation in blender?
    example 2,
    i loaded Md3_output_frame0.obj in daz studio
    applied a texture
    added a light
    exported the scene for a single-frame-render using mcjTeleBlender
    as you can see the exporter/importer system created a material suitable for Blender-Cycles renders
    since Daz Studio's OBJ exporter did not make any effort to preserve the vertex count and the vertex order
    we can not apply the MDD to the dress - Blender displays an error message
    we delete the dress that came from Daz Studio ( but this did not delete the materials !!!
    we import Md3_output_frame0.obj using Blender's importer
    it's very important to activate the "vertex order" option during the import
    we apply the blender-cycles-dress material to Md3_output_frame0.obj
    we apply the "mesh cache" modifier to the dress, we specify we will use Md3_output.mdd
    and we now can render the whole animation using Blender Cycles
    177 x 250 - 538K
    1746 x 676 - 482K
    472 x 756 - 93K
    1258 x 626 - 474K
    Post edited by mCasual on September 2014
  • HellKoreaHellKorea Posts: 17
    September 2014 edited December 1969
    Thank you for quick update..
    There is another problem.
    TeleBlender does not export "Specular Strength" image map.
    would you fix it? please~
    Thank you again.. I love mcjTeleBlender.
    1600 x 1800 - 2M
    you know what i did just now ?
    i wrote a Windows-PC-exe OBJ-sequence-to-MDD converter
    as you know, mcjTeleBlender and other programs, can export animations as a sequence of obj files
    once converted to MDD format,
    in blender, you can import only the first frame's OBJ file
    the whole scene is one big mesh
    then you load the mdd file ( as a mesh cache modifier )
    which is a bit like 1 morph channel per animation frame added to the big mesh
    and there you have it an animated scene, which can be rendered
    it's not "rigged" so you cant change the Figure poses, but you can add objects and lights and cameras, tweak the materials etc
    so, very soon i'll publish the free PC-Windows Obj-to-Mdd utility
    and i'll share my C source code which is only 160 lines long for now
    in the example below the figure is a low poly Aiko3-like figure
    so it works quite well
    but for figures like Victoria 4, or the real Aiko3 or Genesis etc .... the data load on Blender will be quite severe
    ( 100K data points per frame )
    748 x 436 - 2M
    maybe if you place that map on the Specular color channel you'll get the desired effect
    it was set up like that in TB2 because the Daz Studio obj/mtl exporter exports only the Specular
    Color map. The .obj format doesn't support specular strength maps
    since TeleBlender3 can export maps separately ... yes soon i may export them too
    ok. i got it. Thank you for explain.
  • siocsioc Posts: 328
    Trouble with TeleBlender3.1 beta
    I just tried the new beta export with cycles choice and all default values and ... no lights exported.
    In that scene I have a distant light and a spot light (both with luxus settings)
    Any idea ?
    Post edited by sioc on September 2014
  • SzarkSzark Posts: 10,634
    I think but I am not 100% certain, that your issue is Luxus Settings, have you tried with removing the Luxus settings?
    So I tried to investigate more:
    I removed Luxus parameters => same trouble.
    I deleted all lights and added a distant light => same trouble.
    Save and restart Daz Studio (tried with both 'stable' and beta) using the file with the new light => same trouble
    Worth a try though. I will have to leave this with Casual. Also I just realised I have never had any lights exported in my scenes either but for me that isn't a problem as I mainly use Area and HDRI's. For the Sun I use this http://blenderartists.org/forum/showthread.php?297721-Script-Connect-Sun-with-Cycles-Sky-Texture&p=2617757&viewfull=1 to line up the Sky Texture and Sun
    I reinsalled mcjBlendBot and that fixed it... Weird
    And no normal map, wasn't that one of the new supported futures ?
    Lighting study , just the basic setup
    i may improve on it later
    outside the window there's a large emissive panel, strength = 1
    behind the camera there's a pink spotlight
    H.S.V. = 0.999 0.0500.300
    Strength 80
    there's a 4 m. x 4 m. white plane as the floor
    there's a strength 80 sunlight behind the window light panel but i think it doesn't contribute much since it's blocked
    the environment light is the beach sphere very weak 0.05 strength
    Based on a photo of Jen Selter
    http://www.jenselter.com
    http://instagram.com/p/q44p1PGkTX/?modal=true http://www.jenselter.com
    Fig 2 - the areaLight plane object's Ray Visibility was set to not cast shadows
    then a sun light with power 3.33 and size 0.3 was positioned to cast light perpendicular to her chest
    800 x 800 - 176K
    900 x 900 - 123K
    i had them, then i basically re-designed the whole thing and forgot to put them back in
    the normal maps will be back today (99% sure about that )
    for standard daz studio lights it should work
    as long as you updated the mcjBlendBot files in the Blender/scripts/modules folder for the current version of Blender you are using
    also there's 2 checkboxes in TB3's "auxiliary" Tab
    812 x 456 - 130K
  • nakamuram002nakamuram002 Posts: 818
    Why not export all cameras in the DAZ Scene? I think the original mcjTelebelender did that...
    i'll add it as an option checkbox,
    only the user-created cameras, and the perspective camera, not the orthogonal ones
    eventually i could add animated cameras like what mcjExportCamToBlender does http://www.daz3d.com/forums/discussion/17032/
    for orbiting cameras, or ... upcoming ... to render obj-sequences converted to MDD format( or directly to Blender's mesh-cache modifier )
    i strayed into the world of bra-rchitecture but am re-focusing on TeleBlender 3 ...
    expected release in the night
    1920 x 1080 - 192K
    640 x 640 - 129K
    upcoming version
    all the cameras will be exported
    the camera names will be exported and used in Blender
    this will remain compatible with old blendBots
    if 'addCamera2' in dir( mcjBlendBot ):
     addCamera2( 4.022, -0.002, 2.67, 68.683, 0, 89.77, 137.143, True, "Camera_Main" )
    else:
     addCamera( 4.022, -0.002, 2.67, 68.683, 0, 89.77, 137.143 )
    addCamera2( 2.637, -2.602, 1.454, 80.49, 0.003, 42.926, 59.429, False, "Camera_Pose" )
    addCamera2( 3.703, 1.001, 1.828, 74.875, 0.003, 101.94, 59.429, False, "Camera_side" )
    addCamera2( 0.054, -0.407, 0.792, 98.71, 0.004, -5.363, 59.429, False, "Camera_Hands" )
    640 x 640 - 116K
    746 x 476 - 158K
    as long as you are using the newer version of mcjBlendBot with mcjTeleblender 3 Beta
    https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    the normal maps applied to the surfaces with the Default Daz material do work
    next i'll see if it's the case when the normal map is part of a ''shader''
    Fig 3 - the Normal maps for Shader materials like AoA's SSS shader will be exported to Blender and used by blender
    as long as the shader uses the property name "Normal Map"
    ....... in teleblender 3 beta 3.02 posted veryverysoon
    the other shaders i have dont use normal maps
    600 x 600 - 102K
    707 x 1000 - 110K
    640 x 640 - 66K
    UPDATE TB3.02 beta UPDATE TB3.02 beta UPDATE TB3.02 beta UPDATE TB3.02 beta UPDATE TB3.02 beta
    Teleblender 3.02 Beta and mcjBlendBot were updated
    there's now an option to export all cameras
    but i have to fix something i forgot about : apparently, when exporting into an existing Blender scene, the default camera setting doesn't seem to be acknowledged by blender )
    and better support for Shaders with 'Normal Maps' as long as that shader uses the very specific name "Normal Map"
    note that this is TB3's Home > https://sites.google.com/site/mcasualsdazscripts4/mcjteleblender3
    1920 x 1080 - 230K
    1024 x 1024 - 561K
    900 x 900 - 191K
    600 x 600 - 46K
    Sorry, but I still have issues:
    why the camera focal change (50 mm in daz => 45.71 mm in blender) ? I got that before and after mcjBlendBot update.
    Thank you update..
    but.. there is error.
    in mcjMakeCyclesNodes.py
    >>> "links.new( mulNode.outputs[0], glossNode.inputs[0] )"
    905 x 442 - 172K
    Post edited by HellKorea on September 2014
    ‘Normal Maps’.
    In daz studio with as shader the "Daz Studio default", I have a normal map image in the surface of an object and no normal map in blender.
    I have the same result with both TB2 Legacy Mats and new one.
    Also why the camera focal change (50 mm in daz => 45.71 mm in blender) ? I got that before and after mcjBlendBot update.
    about the focal lengths - in Daz Studio the focal length is relative to the vertical aperture of the camera for a backplate 35 mm tall
    in Blender the focal length is relative to the horizontal apperture of the camera for a backplate 32mm wide
    in your case apparently you were using a square screen ratio, so 50 mm * 32mm/35mm = 45.71mm
    using the way mcjTeleBlender computes it, so far i always had almost-pixel-perfect results
    it's important to use the default Export scale of 1% in teleblender's "Aux Settings" tab
    for the normal maps - see Figure 2 - the material editor is where you can see if the normal map was imported
    you can then check if the specific image is the problem, maybe its the normal strength that is too low
    Note that in TeleBlender's Aux Settings tab, there is a setting called "Normal Maps Strength" the default value is 0.5
    For now i dont think ( not sure ) if TeleBlender uses it, but in the next version it will
    if you exit blender and re-launch it using the .bat file created by mcjTeleBlender ( in the same folder where your .obj files are written to ) , you will have access to the Blender Console, and in it you can see messages that are displayed during the import process - if you see an Error message, please tell me what is written
    351 x 838 - 119K
    1000 x 1160 - 382K
    jerrycrow said:
    Thank you update..
    thanks !
    i didnt test the mix node a lot [ insert Sir Mix-a-Lot pun here ]
    i see it has serious problem
    i'll fix it today
    676 x 342 - 116K
    coming up in the next minutes - i fixed the renders for TB3 & Glossy Mix renders
    ( thanks JerryCrow )
    but i still have to fix the issue where you have a pre-existing scene with non-glossy-mix materials
    and you are importing a daz scene with glossy-mix materials
    ( normally mcjBlendBot is supposed to leave pre-existing materials alone ! )
    oh i also see TeleBlender and BlendBot should not attempt to tweak materials in Blender that are not even exported from DS because they are invisible in the Daz Scene
    960 x 540 - 88K
    Important Update TeleBlender 3.03 Beta and mcjBlendBot
    2014 September 15 6:45 PM - Version 3.03 beta -
    TeleBlender 3 with GlossMix was repaired
    i added a bOld property to all objects, so "old" objects in the initial .blend scene are tagged as old
    and disregarded when processing the objects imported from Daz Studio
    mcjTeleBlender now saves the Normal Map Strength value on exit
    mcjTeleBlender now doesn't attempt to get mcjBlendBot to fix objects and materials
    that are not actually exported from Daz Studio
    Both your mcjBlendBot and the mcjTeleBlender script need this update
    Thanks to everyone for pointing the things that need fixin' like that coffee machine in the little café just around the bend
    540 x 540 - 42K
    960 x 540 - 98K
    empty
    sioc said:
    Thanks for the focal explaination.
    I reinstalled my blender then your scripts to be sure I didn't broke something.
    Sorry but I still got the trouble see the screen-shots below
    And the normal map image (V4C_MAT_RIBBED_NML.jpg) is not copied in the \Maps subfolder of the script export
    thanks for posting the screen copy, looks like it;s the bump map that's causing the problem
    i should be able to correct the problem !
    it's normal that the normal map is not collected in the maps folder
    because map collection is handled by Daz Studio's obj/mtl exporter
    so until i post the fixed code for the bump map
    if you remove the bump map from that material
    you should be able to see the normal map and avoid the error
    empty
    sioc said:
    I updated my previous post :) You answered too fast :p
    I removed from the scene the objects having bump map
    I do the test with the same cloth I had trouble with last time I asked for help and you made me add the normal map by hand.
    well i was looking for the exact line number where the bump map error occured, did you keep the old image? :)
    sure :
    1286 x 802 - 89K
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
