Carrara Community Art Gallery - Show us your Renders!!!
1…1718202223…62
    Dinos heart
    dunno why surface replication giving me a hard time.  i've done it before no problem.
    trying to scatter a herd of bessies
    1280 x 720 - 565K
  • KhoeKhoe Posts: 347
    Love it. :)
  • DiomedeDiomede Posts: 15,461
    These additions have been spectacular.  Congrats, Khoe.  Congrats Bunyip.  Way to go, Carrarians.
    theres 5,000 cows in scene, scattered so far can only see a few.
    i converted the terrain to vertex.  deleted mose of the polies off to the sides to make a smaller area.
    didnt want to drop a plane in, wanted the cows on the hills.  poor bessie lookin lonely
    1280 x 720 - 423K
    Try this:
    1. Make a square image in your favorite image editor
    2. Make it fully black
    3. Paint a small white shape in the center (assuming we're looking at the center of the terrain
    Back in Carrara
    1. Double-click the replicator in the Instances Tray
    2. Right side of working box, click the button to adjust the shader
    3. Place your new image in the Color channel
    Adjust the painting to fit your needs
    I hope you love this tip!
    Khoe, love that Dino image!
  • StezzaStezza Posts: 9,257
    edited May 2021
    I just use a smaller terrain wink
    800 x 600 - 656K
    Post edited by Stezza on
    Me too. One smaller central terrain inside larger ones that go the distance.
  • Bunyip02Bunyip02 Posts: 9,345
    Excellent Dino drama !!!
    Thanks.
    i trimmed half of the pastuer away
    just notices surface replication has options for clustering.
    zooming the camera around looking for the lost moo-ers, lost the production frame.  zoom default brought it back.
    Do shep and the moo-ers and the roos hang out in the pastures together?
    the toon cow has pose erc instead of pose presets.  is nice, cause can pose to varying degrees.
    i've never seen a cow sit, do they sit like a dog does?
    1280 x 720 - 425K
    RE: replicating on small portions of large terrains
    Here are two options I have tried.  Which I use depends on the scene.  My level of success varies.  I tend to start with a duplicate of the terrain.
    - duplicate terrain.  create new shader for duplicate.  use 3d paint tool and paint black/white area to replicate. save as map.  In replicator distribution, use the black white map as shader
    - duplicate terrain.  select duplicate and set lower resolution.  convert to other modeler (vertex).  select portion where want objects.  invert selection.  delete.  replicate on reduced version.
    cute cow, Misty.  yes
    edited May 2021
    just around the corner from me in the paddock the roos and horses mingle, and up the road the roos and cows mingle but the llamas keep to themselves smiley
    except for the emus.... the emus invade their space
    nice to know they haz a social life. heart
    been playing with this last several hours https://www.daz3d.com/juan-carlos-8
    think i done it wrong lol
    640 x 480 - 62K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,633
    Nostalgia from 2010
  • magaremotomagaremoto Posts: 1,238
    edited May 2021
    another try looking for realism/speed optimization
    no post work, native resolution 2880x
    Post edited by magaremoto on
    edited May 2021
    pbr plugin
    oh, when i turn the plane round, the displacement map is the inverse on the back of the plane.  was wondering why it was sinking in instead of out
    1280 x 720 - 1M
    1280 x 720 - 1M
    Post edited by Mistara on
    looks good
    thx Misty, a good compromise between an AO cached map and GI sky light; maybe with a LUT filter I could get a more cinematic realism.
    here the same scene rendered in D/S 3delight at 1920x, no post work as usual
    Nagarian command center with medieval bricks.  imported to carrara with pbr plugin
    hdri Creek Falls AutumnFalls01.hdr
    needs a nice landing pad for the centruion troop carrier
    1280 x 720 - 2M
    edited May 2021
    testing G8 skin (sss and translucency mostly)
    a 59" render, carrara rocks!
    3440 x 1935 - 940K
    That's really nice shading, Magaremoto! I can never seem to lock down a decent SSS setting. Always ends up too glowy for my liking. This looks really good!
    edited May 2021
    thx DB, well it mainly depends on good maps and lighting; G8 Hersilia has very good maps suitable for testing sss in carrara, what I actually do is create a skin shader usable for any lighting condition, by tweaking color and sss channels
    here are 2 screenshots: in the first you can see how doubling the map and invert its color you can make skin more or less reddish (it counts a lot), in the second one you can check my simple sss settings; normally I act on color tab and intensity slider only.
    maps with white or pink background (like Hersilia's) work better in carrara; translucency is needed only for ears shader most of times
    about lighting, I suggest to keep it simple, just a good irradiance map and a bit of sky light, as in my shot, it speeds up rendering times considerably
    699 x 418 - 62K
    676 x 426 - 53K
    edited May 2021
    The Front Gate smiley
    898 x 599 - 1M
    Buppy sighting.  is that Baxter?heart and E-or
    i had to kill the 300 hour render.  from now on i'll do a test batch of a 10 frames to get the average frame time estimate
    This 1 frame took an 58 minutes.
    not saying is not worth the wait.  Is a gorgeous set.
    anyone tried the murky volume?
    i'm guessing is for like under ocean scenes?
    1280 x 510 - 592K
    1280 x 510 - 572K
    1280 x 510 - 447K
    The doors do open.  hoorahh  and hopefully those stairs will stop rampaging daleks
    1280 x 720 - 855K
    a dubious lil dragon
    the toon giraf was a bit weird.  theres 3 xtra geometry parts for eye targets.  i kept losing the eyeballs.  couldn't reset it, had to delete and reload the figure.to get the eyes back.
    1280 x 720 - 429K
    1280 x 1847 - 1M
    1280 x 720 - 434K
    1280 x 1847 - 1M
    May be an image of 9 people
    apparenty according to forum software this maybe an image of 9 people
    edited May 2021
    ps nice renders all.  Mystiara, you are more patient than I !
    Post edited by Headwax on
