Gizmo too small
https://www.daz3d.com/mesh-grabber-win
I am starting to use the mesh grabber but the gizmo is so small I keep droping it. Is there a way to make the gizmo bigger?
  • NorthOf45NorthOf45 Posts: 5,760
    With Mesh Grabber active go to Tool Settings. Look in the second grouping called Gizmo for the Size control.
  • dennisgray41dennisgray41 Posts: 860
    Thanks! I was not using the tab.
  • davesodaveso Posts: 7,939
    simpler than a purple pill.
  • McGyverMcGyver Posts: 7,097
    I was going to say maybe the water was too cold, but then I realized it's the Mesh Grabber gizmo... not the... oh never mind.
    McGyver said:
    I was going to say maybe the water was too cold, but then I realized it's the Mesh Grabber gizmo... not the... oh never mind.\
    If you know a safe way to double the size of that gizmo, my wife will be forever in your debt.
    laugh
    edited May 2021
    That just tempts me to make a model of a Ronco type "order before midnight tonite" kinda device with one of my typical satirical ads... none of which I'm guessing would be TOS compliant.
    At least none of the ones that first came to mind...
    Post edited by McGyver on
    Drug-free, contactless, non-invasive...
    500 x 500 - 30K
    Not to forget the rest of that tool bundle,
    505 x 416 - 19K
  • daveso said:
    laugh
    Switch to metric. 1 inch equals 2.54 centimeters. 6 inches equals 15.24 centimeters. If that doesn't satisfy her, learn to do censered
  • margravemargrave Posts: 1,822
    You're not supposed to get Gizmo wet at all. Didn't you listen to the three rules?
    ROFL my censored in forum off...
