Post Your Renders - Happy New Year yall
13567100
  • magaremotomagaremoto Posts: 1,238
    makma said:
    5thElement - I like your models and renders. Any details on modelling, lighting and rendering possible?
    Magaremoto - same questions about models and rendering. Did you use light rigs?
    Marek
    Hi Marek,
    due mostly to photon mapping limitations, - here: http://www.cs.cmu.edu/afs/cs/academic/class/15462-f10/www/lec_slides/a1-jensen.pdf - you need to assemble a rig for lighting in carrara just like do other biased renderers, mental ray, vray or redshift to mention only few. In this wip for example there are a sunlight, 2 soft direct lights, a volumetric emitting dome, and a couple of anything glows lights, parented to an infinite plane and an emisphere, ambient occlusion, sky light and irradiance map to mix all together. Every light brings up the GI. In this particular case I am focusing on shadows and greenery rather than else
    2000 x 860 - 2M
  • DartanbeckDartanbeck Posts: 22,115
    two more
    Very Cool!
  • SileneUKSileneUK Posts: 1,980
    edited July 2014
    Marek
    Hi Marek,
    Hi Mag,
    Wow, an impressive 100 page manual. So I went to the main directory and found the course programme:
    I enjoyed reading Lecture 1... don't know if I know enough to keep on reading but will see what is in there to help explain" how" 3D works.
    Cheers for that!
    :coolsmile: Silene
    Post edited by SileneUK on
  • makmamakma Posts: 54
    Thank you Magaremoto!
    Inspirational explanation and interesting reading.
    Marek
    edited July 2014
    my pleasure Marek. Well done Silene, I bet it's gonna be worth reading and learning all over
    Post edited by magaremoto on
    w.i.p. - testing shaders with and without sunlight
    2000 x 860 - 1M
    2000 x 860 - 2M
  • stu sutcliffestu sutcliffe Posts: 274
    Some more "Thing" fun, inspired by Mike Ploog. ( the original is on my blog.)
    This was meant to be a 100 percent Zbrush after my recent purchase and learning frenzy! But I managed to paint myself into a corner with it, and ended up with my usual workflow of 3DCoat to Carrara for hair and render. Though zbrush did find a place in my workflow and actually saved about 2 days work at the "retopology" stage ,which was being a proverbial brick wall in 3dcoat....
    Dont have nightmares....
    1164 x 864 - 368K
    Looks a bit like Tony Blair from this angle.....
    :lol: Silene
    Cool modelling!
    wip - playing around with caustics, AO based lighting
    1440 x 619 - 76K
  • BC RiceBC Rice Posts: 591
    Screen shots from my current animation.
    1920 x 1080 - 302K
    1920 x 1080 - 371K
    Those look really cool. What are you using for the cell shaded look?
  • ringo monfortringo monfort Posts: 945
    edited July 2014
    Lee 6
    1000 x 1300 - 269K
    1000 x 1300 - 379K
    Post edited by ringo monfort on
  • DiomedeDiomede Posts: 15,410
    Yes, are you using one of the plugins like YAToon, or something else? Looks fantastic. Bravo.
    Thanks! I use YA toon and Toon Pro in Carrara 7.2
    edited July 2014
    Thanks! Answer above! :)
    Post edited by BC Rice on
  • RobertEVRobertEV Posts: 11
    My first render in Carrara in quite a while.
    1172 x 800 - 474K
  • bighbigh Posts: 8,147
    mmm - street walkers :)
    edited July 2014
    Nice job!
    bigh, those 'hos be clearly walking on the sidewalk, not the street. Duh! ;-P
  • Rashad CarterRashad Carter Posts: 1,830
    Nice job!
    Ha!!! Very funny.
  • HeadwaxHeadwax Posts: 10,529
    yes only one of them is street er side walk walker, t'other is a street stander ..
    nice render by the way
    My imagination has done a runner,so another favourite character to pass the time until I can have an original idea. Not quite as I intended in my head but the boredom factor sets in after a week.
    1200 x 900 - 334K
    I didn't know you knew my sister in-law! Rimshot!
    it does look just like her :roll:
    Dammit! ...I could have used a life model!:lol:
    testing DOF and glare
    1538 x 2000 - 487K
    A Space Man...
    935 x 1183 - 320K
    A Space Man...
    neato - from where
    Just made up, but sort of going for a Dan Dare 50s/60s pulp type thingy type thing....( it started off as a caricature of "an actor" but quickly went pear shaped...or should I say alien head egg shaped!)
  • arcadyarcady Posts: 340
    edited August 2014
    Genesis 2 morphed down to a child with the "Growing Up" morph-kit.
    Waiting for the bus. :)
    EDIT: redid the lighting.
    1920 x 1200 - 501K
    Post edited by arcady on
    yep - best to leave the driving to Gus
