• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI
Notifications
Loading...
    • Categories
    • Recent Discussions
Animating transformation from one character morph to another
UpL8RenderingUpL8Rendering Posts: 129
January 2021 edited February 2021 in Blender Discussion
Hello,
I put together a tutorial and a Blender script to help in animating the transformation from one character morph to another.
https://imgur.com/f6Q68SA
*Still haven't figured out posting gifs
You can find the script and tutorial on my github page:
https://github.com/GNVR-Dev/BlenderScripts-DazBone-Morph-Constraints
I will also post the tutorial part below:
I very much welcome any feedback/comments/questions - good/bad or otherwise that you might have
Post edited by UpL8Rendering on February 2021
  • UpL8RenderingUpL8Rendering Posts: 129
    January 2021 edited January 2021
    Start by importing your two characters
    For this example we will transition from Basic Male 8 to Arch Demon
    I have removed the eyelashes from the Basic Male 8 character because the Arch Demon doesn't have them
    I have removed the horns from the Arch Demon character because the Basic Male 8 doesn't have them
    I imported the Basic Male 8 first so he will be the Gensis8Male
    I imported the Arch Demon second so he will be the Genesis8Male.001
    Click on the Scripting tab at the top and click New to Create a new text data block
    Paste the script
    Change the Add_Constraints('Genisis8Male','Genesis8Male.001') to match your characters
    and click Run Script
    This will move all the bones in the 'Genesis8Male.001' Arch Demon character to the same locations as the  'Genesis8Male' Basic Male character
    Select the Genisis8Male.Shape.001 first then CTRL select the Genesis8Male.Shape second
    Open the Object Data Properties panel
    In the ShapeKeys area click the little down arrow and select Join as Shapes
    This will add the Arch Demon shapekey (without bone transforms) to your Genesis 8 Male character
    Click on the Genesis8Male.001 rig and go into Pose mode
    Hit the "a" to select all the bones
    Go up to Pose - then Constraints - and Clear Pose Constraints
    This will put the Arch Demon back to his original shape
    Go into the Animation Tab at the top
    It might be helpful to hide the Genesis8Male.001 (Arch Demon) shape and rig
    Make sure the Timeline scrubber is set at the beginning of the timeline
    Click on the Genesis8Male Rig
    Press "a" to select all the bones
    Right click on the rig and Insert Keyframes
    And choose Whole Character
    Go back into the Scripting Tab
    Change the order of the characters
    So change:
    Change Add_Constraints('Genisis8Male','Genesis8Male.001')
    to this:
    Change Add_Constraints('Genisis8Male.001','Genesis8Male')
    Run the script again
    Go back into the Animation Tab
    Move the timeline scrubber up to something like frame 120
    Make sure all bones are still selected
    Go up to Pose - then Apply - and choose Apply Visual Transform to Pose
    The right click on the rig and click Insert Keyframes
    Next go back up to Pose - then Constraints - and Clear Pose Constraints
    You should now be able to scrub the timeline to see the bones animate between the two characters
    To animate the morph target/shapekeys:
    Change from Pose mode back into Object mode
    Click back on the Genesis8Male.Shape
    Make sure the animation scrubber is back at the beginning of the timeline
    In the shapekey area select the Arch Demon Shapekey (Genesis8Male.shape.001)
    Make sure it's value is set to 0
    Click the little dot to the right to Animate property
    Once again move the scrubber to 120 (or where you set it before)
    Change the Value to 1
    And click the dot to the right again to Animate porperty
    Scrubbing the timeline will now animate the bones and shapekeys together to transition from one character to another.
    Post edited by UpL8Rendering on January 2021
    Adding your own animation:
    Go back into Pose Mode and select a bone
    Scrub along the timeline to the point you want to add the animation keyframe
    Rotate or move the bone
    Right Click and Insert Keyframe
    This time select Location and Rotation
    Keep adding animations as needed.
    Bonus tutorial not included on Github read me file:
    Animating the transition from one texture to another while your character is changing
    Open the Shading tab at the top and the Material Options panel on the right
    Select the first material in the list
    Right click on the Texture node and Duplicate
    On the new texture node there is a little arrow to the left of the texture name
    This will let you bowse to a different texture
    Because this is the Face material we will look for the second characters face texture
    In this case AD_DemonFace_TX-Red
    Now click Add -> go down to Color -> and select MixRGB
    And connect as shown below:
    To animate the change go into the Animation Tab and set the timeline scrubber back to the beginning
    In the Surface area of the Material Panel click the drop down arrow to the left of Base Color  Mix
    Make sure that the Fac setting is set to 0.000
    Click the little dot to the right of FAC to Animate Property
    Scrub the Animation timeline up to 120 (or, again, what you set before)
    Change the Fac amount to 1
    Click the little diamond to the right to set this Keyframe amount
    Set up all the other materials and their keyframes the same way.
    Edit Note: Because Daz uses the same texture for multiple materials and material slots like Face, Lips, Ears, and Eye Sockets you can either set up each one seperatly or use my Daz Material Slot Combiner Script to remove all the extra slots.
    https://github.com/GNVR-Dev/BlenderScripts-Daz-Material-Slot-Combiner
    Documentation how to use it is included in the README file
    Scrubbing the timeline will transition the character, shapekeys, and material texures at the same time
    January 2021
    Just in case post
  • mindsongmindsong Posts: 1,755
    January 2021
    Very cool how-to, much appreciated for your efforts there! (pdf-d)
    Bravo,
    --ms
    February 2021 edited February 2021
    Thank you.  There might not be a lot of people looking to do this kind of animation but if it helps a couple of people I think it is worth while.
    I also have to admit I am a bit behind on the different importers and bridges. If they offer an easier way to achieve this please let me know.
    If anyone uses this to make an animation I would love to see how it came out.
  • brainmuffinbrainmuffin Posts: 1,285
    February 2021
    Wow!!!
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
