UltraScenery [Commercial]
Adding to Cart…
© 2025 Daz Productions Inc. All Rights Reserved.You currently have no notifications.
Updates appeared in DIM for Accelerator and UltraScenery and I installed them both but the tangy orchard trees and hedgerows are not showing up after running the script and after a render. Bummer.
everytime I view this topic I get incentive to create. Thanks
camera positioning: What is the best way to position the camera within US. I would like it to be at eye level, as if someone is taking a photo.
Nah it is quick to build, what I meant to say was that unlike the other eco systems it takes a very long time to initiate rendering.. After investigating why, have found that some of the texture files needed for the Australian packs compared to the textures used in the other products are huge..
We are talking about nearly 14, 15, 18 meg PNG's, and unfortunately for my little PC it just can not handle so many large texture files being loaded.. :(
Don't think there's one particular technique. Don't know if there's a tool to tell you height distance from the displaced terrain at a given XZ point.
Wireframe viewing, use of the numeric params, correct use of the frame view function, learn the different co-ordinate options for the translate & rotate tools, using parenting/unparenting in place vs none to jump things into position, multiple cameras for examining, hide cluttering geom, lots of spot renders...
In short, what ever works.
Oh ya. I was going to mention markers or such that don't render.
I was looking for a view mode that showed when intersecting geom was occurring, but not finding it. Probably thinking of my other 3D app. I always have trouble seeing the water layer. Maybe there's a way of changing its visibility mode or such.
Here's something I was playing with recently & having similar issues. Little subtle stuff that's hard to see, hence a WIP. Having a lot of fun using the Rebuild feature though to try out different Ecos with same features & terrain settings. Unfortunately, a bit taxing with the laptop with some. This was 2 Hrs to get to 27%.
Well I managed to fix my issue with the Australian pack by scrunching down the large texture files, and also unticking the CPU option in iRay as well..
Great to hear you are back in business!
Even at 27%, it looks great.
I though I might as well go ahead and render my Australian Bush 1 Bridge 1 scene. Here it is.
Throw a couple of Roo's in there now...
I tried that once. My old graphics card is a little feeble for UltraScenery and Catalyzer at the same time. I did get a scene to render finally, but it was a struggle.
Here is a scene I made with UltraScenery, Alienator Pro, and Small World Camera.
Here it is without the Small World Camera. I love the colors and shapes in these.
I am just overwhelmed with the possibilities of custom height maps in UltraScenery.
Below is my latest creation.
I was able to render a few (not all) Tango orchard trees before yesterday's update, now I can't render a single orchard tree no matter which orchard or combination I select.
Please document all the details so people can try to reproduce your problem.
Awesome work! Bright and cheery
why are there 2 updates in my DIM for acceleratror? One that says Accelerator for UltraScenery and the other Accelerator for UltraScenery for DAZ Studio 4.5+ (Win 64-bit)
Which one should I install, or both ??
Here is my attempt found an awesome Wallaby/Kangaroo freebie..
Tried to insert a larger version of the image but it keeps telling me I have 357000 or so characters too long?
Good question to ask before you install any. I installed both and now none tangy orchards will not populate the terrain.
Thanks for your help. I am at work and cannot check the log file(s). I will check when I get home. All I know is that I have the latest updates for all the ultrascenery products including accelerator. The last update for accelerator was installed yesterday via DIM. I am using the tangy orchard and it is not populating any trees. Thanks.
The picture is awfully dark, but I think I can make out a kangaroo on the right, right?
It is but then again early morning and late evening are supposed to be dark..
There are 4 roo's in the scene, foreground left, two in the middle and one background right..
The 64bit contains the plugin, the other one the script.
Those just showed up in my DIM ready to download this morning as well. Both are already installed so assuming since these are listed as updates, looks like both are used.
So can you try using any of the tangy orchard with accelerator to populate a terrain and see if yours work? If yours work well then it has to be on my end that something went wrong.
I'll give it a test pretty soon. I do know there were some issues with the TAO itself that were getting addressed.
I have tried it, using
My script version is 1.3.1, accelerator version is 1.0.1.2 (for macOS)
Everything did work fine. Build times are arount 41 sec, plus / minus. The scene is populated correctly, the texture preview show the placeholder trees, and the IRay preview and render is working as expected.
