Tone Mapping Enable is a toggle in the Tone Mapping group of render Settings or on the Tonemapper Options node via the Parameters pane. I would not suggest turning it off unless you are rendering to .exr files via Canvasses as the regular 8 bit per channel renders don't have enough data to tone map in post work.
It's always on afaik, even when it's on default settings. If you mean it's in your scene tree, it's quite harmless.
