Disable Tonemapper
Does anyone know how to remove the tonemapper? I don't want it in my render
It's always on afaik, even when it's on default settings. If you mean it's in your scene tree, it's quite harmless.
Tone Mapping Enable is a toggle in the Tone Mapping group of render Settings or on the Tonemapper Options node via the Parameters pane. I would not suggest turning it off unless you are rendering to .exr files via Canvasses as the regular 8 bit per channel renders don't have enough data to tone map in post work.
